La longue liste des changements pour les intéressés :
- Added: Verify option for ISO Write mode (DVDs only)
- Added: ISO Write mode now displays the media's supported write speed in the log
- Added: Additional debug information during initial program startup - when debug mode is enabled
- Added: Dialog box with 'Yes to all' and 'No to all' when decryption is detected in a file on a supposedly non protected disc
- Changed: Techniques used to determine the correct write parameters to use in ISO Write mode
- Changed: 'Failed to decrypt disc key' no longer stops the program in its tracks
- Changed: General improvements to CSS cracking techniques
- Changed: 'semaphore timed out' errors now display the actual timeout value
- Changed: Brute Force cracking failures no longer display an error dialog box if they're a result of the 'Detect Mastering Errors' option being enabled
- Fixed: Setting the write speed to 2.4x (or 2,4x !) on systems that don't use a '.' for their decimal point
- Fixed: 'Failed to Set Write Parameters' on Matshita drives
- Fixed: Hang up on 'Searching for SCSI / ATAPI devices' when people have a certain Samsung CDROM drive in their machine
- Fixed: Incorrect naming of AC3 files demuxed in File mode
- Fixed: Big bug in ISO Read mode where files following 0 bytes files weren't decrypted
- Fixed: Brute Force cracking on unauthenticated discs could fail silently
- Fixed: Authentication on some discs would just repeat over and over again during reading without any error
- Fixed: Polling for completion of certain I/O at the end of a burn in ISO Write mode would fail on certain drives
- Fixed: I/O Errors using SPTI where the actual API call failed would often mean sense area information wasn't displayed in the dialog box
- Removed: The option to 'Force CSS Present' - This has been made obsolete by recent improvements
