NDFR : DVD Decrypter 3.2.2.0
DVDDecrypter est l'outil de référence pour ripper vos DVD vers votre disque dur.
La version 3.2.2.0 apporte les changements suivants :
Ajouts :
  • 'RCE Protection Found' dialog box
  • Apply button to the 'Change ISO volume name' dialog box
  • Eject / Reinsert of disc before the verify stage
  • Support of brute force disc key cracking
  • The ability to have the program not ask you if you want to erase / overwrite a disc in ISO Write mode
  • CLI support for '[DISC_LABEL]' in destination path names
  • CLI support for '/SPLIT 1GB' - Only for IFO mode
  • Additional error checking to IFO patching code so that 'invalid' IFO files are easily spotted and pointed out to the user
Changements :
  • 'Pack Header Not Found' warnings are now also shown in ISO Read mode so as to warn the user of potential problems
  • What's displayed in the info panels in ISO Read/Write mode is now not so dependent on what the 'Current Profile' is. It now also works by the discs 'Book Type'
  • Some of the code behind setting the drives 'Write Parameters'. This may work out better for people who said they were having bad burns from 3.2.1.0
  • Some of the disc initialisation code to use single commands to get and display the 'state' of a disc (i.e. Empty, Complete), so that what's displayed in the info panel in ISO modes is what the program uses.
Corrections :
  • Problem with drives (i.e. AOpen ones) that make use of multiple AGID values as part of Authentication
  • Write speed control wasn't correctly being set to its last saved value
  • Older Pioneer writers (i.e. Pre 107) weren't burning some CD images properly
  • Ejecting the disc after erase, before burn - it shouldn't have been happening
  • Problem with invalid characters in filenames (generated from the disc's volume label)
Télécharger DVD Decrypter 3.2.2.0
Télécharger la version traduite par Matze
Source : Unite-Video
3 commentaires pour “DVD Decrypter 3.2.2.0”
  1. sim140680 a dit (le 25-04-2004 à 22:04)
    Aucun des mirroirs de téléchargement n'est à jour pour le moment
  2. LeMoi a dit (le 25-04-2004 à 23:10)
    effectivement
  3. LeMoi a dit (le 26-04-2004 à 12:25)
    bon g rajouté dans la news un lien vers la vf de Matze
Afficher l'actualité “DVD Decrypter 3.2.2.0” sur le forum
