:- Added: Lock volume during ISO Write or Erase
- Added: Disable Media Change Notification for currently selected drive
- Added: 'Untested' support for Double Layer +R media burning
- Added: Stream information in filenames for File mode Demuxing
- Added: CSS code now checks all VOBs in VTS set if the key for a single file cannot be found
- Added: CSS code now detects the presence of CSS in supposedly unencrypted VOBs
- Added: Quick drive letter change on destination path - in context menu
- Added: Command Line switch '/SHUTDOWN' for ISO Write mode
- Added: Region mismatch dialog box now displays the drive region and the disc region to make the problem easier to see
- Added: A lot more 'status' message to show the user what the program is doing at all times
- Added: A workaround for NEC drives that don't have their regional code set - they don't follow the specs
- Added: Code to put the system tray icon back in the system tray if 'explorer.exe' crashes
- Added: '% complete' for more of the 'lengthy' operations (Synchronising Cache, Finalising Disc etc)
- Added: 'Question' event sound to the 'File Replace' dialog box
- Added: ISO Read mode now uses the Filesystem specified capacity for the disc capacity when reading from DVD+RW media
- Added: ISO Read mode now silently (almost) terminates when it reaches the end of the disc before it originally thought it would
- Added: Setting 1x for 'Set Read Speed' will put Pioneer DVDROM drives into 'Quiet' mode. 'Max' will put them into 'Performance' mode
- Added: 'Vendor Specific' inquiry information is now shown in the device 'capabilities' page accessed via the device context menu
- Added: Support for XBOX images that have had their ISO filesystems removed
- Changed: CSS code has been rewritten to cope with strange happenings and should error out a lot less now
- Changed: Stream Processing in File mode - Shows information for more streams (i.e. DTS)
- Changed: CSS code I/O Debug mode logging to make it more useful in identifying problem
- Changed: I/O Debug mode logging to make it more useful in identifying problem
- Changed: VOB CSS 'Encrypted' flag is no longer removed if the program hasn't actually decrypted the file
- Changed: NSIS installer has been updated to be more 'user friendly' for reinstalls etc
- Changed: SPTI Device detection code has been cleaned up - code for NT4 no longer effects 2000 (and newer) OS's
- Changed: ISO Write mode code to hopefully make it more stable
- Changed: Sectors are no longer skipped in basic IFO/File modes due to 'Pack Header Not Found' errors
- Changed: Logic behind getting the free disc space. It no longer uses the root folder but instead the one you've actually selected
- Changed: Source device drop down list now shows 8 devices before scrolling
- Fixed: A problem in the Image File 'Format' detection code where it could error out trying to load small images
- Fixed: Set Read Speed - previous version always set it to 'Max' regardless of the actual setting
- Fixed: ISO Write mode displayed 'Decrypt' as the button tooltip instead of 'Write'
- Fixed: File mode stream processing via CLI no longer includes unwanted streams in the VOB
- Fixed: 'Set Hardware Read Error Reties' should no longer cause certain machines/drives to hang
- Fixed: A problem comparing drive/disc regions that could lead to a 'mismatch' when one didn't really exist
- Fixed: Misalignment of a few controls within the Settings
- Fixed: Tab order of a few controls within the Settings
- Fixed: Issues with PCM demux in IFO/File modes
- Fixed: Issues with PCM information in File mode stream processing dialog
- Fixed: A small problem with the IFO parsing code that could lead to the wrong video resolution being displayed
- Fixed: A bug where the Device Buffer thread could cause a 'Divide By Zero' error
- Fixed: NEC (and alike) drives no longer display 2.3x and 3.9x for supported write speeds in ISO Write mode
- Fixed: 'Pack Header Not Found' entries in the log caused by a previous 'Read Error'
- Fixed: A nasty bug in ISO Write mode when converting 2352 sectors to 2336 ones
- Fixed: A nasty bug in ISO Write mode when converting 2336 sectors to 2352 ones
- Fixed: A logic error when setting the write speed for 'Erasing' a disc
- Fixed: Copy + Paste issue in ISO label change dialog
- Fixed: A problem ('Failed to set Write Parameters') when burning on 'older' CD drives
- Fixed: A problem with file splitting code in File mode
Source: fileforum.com
2 commentaires pour “DVD Decrypter 3.2.0.0”
www.trad-fr.com
