NDFR : Media Player Classic 6.4.8.8 v2
Une nouvelle mouture du lecteur vidéo Media Player Classic est dès à présent disponible. Cette version apporte son lot d'optimisations et de corrections de bugs en tout genre, dont voici la liste complète en anglais :
- two pass bicubic shader, bilinear more optimized
- dropped subtitles are loaded instead of opening them as a media file
- thumbnail image generator
- dsm demuxer can output individual streams into files (context menu -> demux...), the raw data is corrected if possible, like subtitles are output to srt/ssa/vobsub, frame header added to aac, wave header to pcm, etc.
- better support for quicktime files by the mp4 splitter, more track types are recognized and also reads zlib compressed headers
- dvd navigator's software dvd region check is disabled using the detours lib, there is still a hw region check built in the firmware of the drives, unless it was flushed with a region free firmware it will still not work and may cause strange problems like freezing the player
- the mpeg ts splitter can repack h264 streams in "mp4 style" packets for decoders so they won't crash (ffdshow, coreavc)
- "next aspect ratio preset" command
- yv12/i420 is no longer a disallowed format when using "vmr9 (renderless)" as the renderer, holding the ctrl key when loading a file will still disable it, the current display drivers should not have that color conversion bug anymore but just in case...
- vmr9 (renderless) mixer mode available, it allows deinterlacing and other vmr9 features, off by default because it is slightly slower
- Haali's video renderer can be directly selected in the options (subtitling works, shaders don't)
- mpeg decoder sse2 optimizations (most noticable at hdtv resolution), optional interlaced output, new "field shifter" deinterlacing mode
- nero's "vobsub" inside mp4 supported
- clicking another window on a different monitor while mpc is playing in fullscreen will not restore it to normal size anymore, if another application grabs the focus, its name and window title will be displayed on the status bar of mpc
- graph builder of the filter graph manager was rewritten (again), let's hope nothing is more broken than it was
- new built-in async reader for udf sources, currently only works with the internal mpeg splitter because others aren't prepared for constantly growing files, use the following syntax as the file name: udp://[<multicastgroupip>]:<port>/[<mediasubtypeguid>], where "multicastgroupip" is optional and "mediasubtypeguid" can be used to specify the subtype of the stream, for example udp://:1234/{e06d8023-db46-11cf-b4d1-00805f6cbbea} means transport stream, it will also work fine without the subtype, just selecting the right splitter will take a little longer
- the checked state of the "enable subtitles" menu item is preserved, this means you can disable subtitling with the vmrs now without having to turn it off for each newly opened file
- floating toolbars are saved, next time mpc opens they will appear floated and at the same position on the desktop
- normalizer/booster was moved to the audio switcher, to avoid high spikes lowering the volume too much the normalizer regains 5% per second now
- "quick open file" menu (similar to vlc's)
- options/filters section was redone a bit, the internal filters have their own property pages, mpc won't be controlling them directly anymore
- there is a changelog this time!
other fixes:
- random crash when seeking files with mp3 audio streams and using the internal decoder
- compatibility with the oggds/vorbis decoder restored (it is a bug in the ogm vorbis decoder btw)
- blank checklist elements in options (external filters now, overrides before)
- run-time error when loading files with certain unicode characters in the filename
- unicode id3 tags, byte order of le/be utf-16 tags was mixed up
- repeated languages loading vobsub subtitles
- dvd angle switching (angle number was off by 1 for many years lol
- long delay when doing "seek to keyframe" with the avi splitter
- fading dvd subpics (~ multiple entries in DCSQT)
bad news:
- resource ids were cleaned up and renumbered, the old command assignments are lost, sorry.
En bref, la nouvelle version est plus stable et aboutie .
Télécharger Media Player Classic 6.4.8.8 (en anglais)
source : LeMoi
42 commentaires pour “Media Player Classic 6.4.8.8 v2”
  1. LeMoi a dit (le 05-03-2006 à 21:57)
    Vivement la VF ^^ (message subliminal à veekee inside)
  2. shp13 (non inscrit) a dit (le 06-03-2006 à 00:20)
    en cours : http://forum.toutfr.com/index.php?s=...ndpost&p=19153
  3. LeMoi a dit (le 06-03-2006 à 12:02)
    [...]En bref, la nouvelle version est plus stable et aboutie .
    En gros support du Matroska v2, et meilleur support des différents .mp4 et .mov, support des sous-titres Nero en .mp4, et correction de pas mal de bugs
  4. LeMoi a dit (le 06-03-2006 à 20:11)
    Je rajout que d'après veekee, une v3 est prévue ce soir (ou 6.4.8.9 ?)
  5. mustang89 a dit (le 07-03-2006 à 07:33)
    veekee, tu t'es encore couché trop tard : 2h16 du mat
    mais merci pour le mpc 6.4.8.8. v2 en français
    c'est ICI que ça se trouve.
  6. shp13 (non inscrit) a dit (le 07-03-2006 à 21:08)
    dommage, il n'y a que les versions installables, j'attendrai les zip de la v3
  7. LeMoi a dit (le 07-03-2006 à 21:58)
    Raaa, j'ai perdu tous mes raccourcis clavier en installant cette version
  8. 1for-matik a dit (le 07-03-2006 à 22:53)
    Bon faut dire que la v2 version Veekee comporte un bug lors de la sélection "Fichier > ouvrir un fichier"
    Il me fait "An unsupported operation was attempted"
    Dommage
  9. veekee a dit (le 08-03-2006 à 11:22)
    ouaip, mais c'est corrigé depuis hier soir (non non, pas nuit )
    dommage, 1for-matik, à quelques minutes près, tu as loupé la mise à jour
  10. LeMoi a dit (le 08-03-2006 à 19:21)
    Toujours pas de version sans install ? Pas envie de re-perdre mes préférences
  11. streets a dit (le 08-03-2006 à 21:32)
    que veut tu dire ?
    apparament il y a une version sur le site de veekee avec le fichier seul
  12. LeMoi a dit (le 08-03-2006 à 21:53)
    En effet, elle y était pas hier, merci de l'info ^^
  13. veekee a dit (le 09-03-2006 à 11:56)
    note : et même avec une version *avec* install, tu ne perds pas tes préférences (yé copie juste le fichier, aucune action en base de registre, sauf spécifié sur la page de sélection des composants...)... si ?
    ps : coucou
  14. LeMoi a dit (le 09-03-2006 à 19:22)
    Bah c'esy ce que je croyais en théorie, j'avais même décoché l'extension à l'explorateur dans l'install, c'est ptet ça qui a tout déréglé en fait
  15. Fred a dit (le 09-03-2006 à 19:50)
    Salut Veekee
    Marrant, c'est toujours mon layout que tu utilise sur ton site, ça fait plaisir ! Par contre, fallait me demander, j'aurais intégré le .net
    M'en vais tester cette nouvelle version sur mes épisodes de 24 tout de suite ^^.
  16. mustang89 a dit (le 09-03-2006 à 20:34)
    @ LeMoi : si tu regardes bien dans les options il y a une case à cocher pour enregistrer tes préférences dans un fichier *.ini.
    En cas de défaillance à l'installation, il te suffit de juste de réinstaller dans le même dossier et le fichier *.ini joue son rôle de sauvegarde.
  17. veekee a dit (le 09-03-2006 à 20:45)
    pas mieux pour le passage dans le .ini. LeMoi, tu testeras ma nouvelle version de l'install, ca te permettra de me critiquer
    Fred (salut, coucou) > intégrer le .net ? maaais, il est très bien comme cela (c'conceptuel)
  18. LeMoi a dit (le 11-03-2006 à 02:02)
    Et v'là la version finale
    http://sourceforge.net/project/showf...ease_id=400410
    6.4.8.9 finalement ^^
    Pas de changelog a priori
  19. KnuX a dit (le 11-03-2006 à 11:43)
    "version finale" c'est vite dit nan ?
  20. dda42 a dit (le 11-03-2006 à 12:15)
    Salut
    Pour les anglophiles mais pas pour les francophiles
  21. LeMoi a dit (le 11-03-2006 à 12:38)
    Media Player Classic 6.4.8.9
    [NEW] FLVSplitter: plays Flash Video (.flv). FLV1-encoded FLVs (decoded by ffdshow) and MP3 sound supported
    [NEW] MatroskaSplitter: WavPack in MKV/MKA supported
    [NEW] AudioSwitcher: Normalize - Regain volume (?)
    [FIX] MatroskaSplitter: Crash bug
    [FIX] MP4Splitter: non-ANSI ("Unicode") char in Chapter was b0rked, thx to nero
  22. veekee a dit (le 13-03-2006 à 20:10)
    et une vf dans les nuages ...
    => http://www.veekee.net/?p=list-85
  23. 1for-matik a dit (le 13-03-2006 à 20:17)
    Alalala Veekee... imagine après le Micro Hebdo, un bain de foule avec tes fans
  24. mustang89 a dit (le 20-03-2006 à 20:44)
    Et hop une version 6.4.9.0 cet après midi avec ce gigantesque changelog :
    Changes in Media Player Classic 6.4.9.0
    - Nothing new really, just a couple of more bugs were fixed.
    - Rien de vraiment nouveau, juste quelques bogues corrigés
    téléchargement (en anglais) : ICI
    pour la version française notre ami veekee va y passer toute la nuit, mais on l'aura bientôt :cool: .
  25. veekee a dit (le 21-03-2006 à 12:30)
    coucou
    oui, ca devrait partir d'ici quelques dizaines de minutes
  26. streets a dit (le 21-03-2006 à 12:59)
    coucou
    Y’a un bug dans ta version veekee
    Sur mon xp anglais + mui fr
    Des que je lance mpc fr ca marche pas et je perds toute les associations de fichier(tout même exe) donc plus moyen de lancer quoi que ce soit a part rebooter et relancer l’image disque !!!!!
    Je ne sais pas comment récupérer ca autrement :angry:
    PS:le mpc en anglais marche bien
  27. veekee a dit (le 21-03-2006 à 15:00)
    ca, cela s'appelle un bug dans l'installation et ca va devoir être regardé très très rapidement
    étrange, en tout cas, car je ne touche à absolument en base de registre sur les exe (entre autres extensions).
    si c'est le programme, c'est... anormal (et non reproductible actuellement, mais je regarderai chez moi (avec XP anglais, mais sans MUI) !
    ps : d'autres retours négatifs ?
  28. 1for-matik a dit (le 21-03-2006 à 15:48)
    Ouep, l'absence de lien sur ce forum pour pouvoir le télécharger :cry:
    Heureusement je suis là
    Télécharger Media Player Classic 6.4.9.0 Français
    Vouala, c'est miou
    EDIT: Remarque, il y avait juste le lien de Veekee plus haut... :confused:
  29. H@kk@s a dit (le 21-03-2006 à 16:39)
    Moi j'ai toujours le souci que sa sort du mode pleine écran. Et sa le fait pas que chez moi sa le fait chez d'autre aussi ou pas?
  30. 1for-matik a dit (le 21-03-2006 à 16:43)
    Quel soucis ?
    Moi pour ma part je n'ai aucun soucis
  31. veekee a dit (le 21-03-2006 à 18:20)
    quel soucis (2eme) ?
    streets > je te contacte par email pour ton pb
  32. streets a dit (le 22-03-2006 à 12:57)
    La version 7z (qui me va plus) marche un-pec
    Merci veekee
  33. mustang89 a dit (le 22-03-2006 à 13:50)
    Merci veekee
    pas de problème avec cette version, mais j'ai juste pris celle en 7z. Donc j'ai pas testé l'exe
  34. veekee a dit (le 24-03-2006 à 12:02)
    Coucou,
    Une nouvelle installation a été réalisée (et fournie en privée à streets pour tests (si possible)). elle semble corriger ce problème avec Windows sur les quelques postes impactés postes (en attente de retour de streets).
    J'ai corrigé, mais je sais toujours pas, cependant, ce qui posait réellement problème (et occasionnait ce plantage système complet).
    Bon, cette version devrait être mise en ligne publique ce soir !
  35. H@kk@s a dit (le 27-03-2006 à 00:45)
    Mon problème est quand je regarde un Divx je met la fenètre en pleine écran ( en double cliquant avec la souris ) et au bout d'un certain temps le Divx reviend en mode fenètre.
  36. 1for-matik a dit (le 27-03-2006 à 01:19)
    Ce doit être un programme extérieur à MPC... je n'ai vraiment pas ce problème. De plus il ne semble pas être répertorié dans la liste de bug sur Sourceforge (à moins que je ne l'ai pas vu )
  37. H@kk@s a dit (le 27-03-2006 à 08:54)
    Je doute que sa vienne d'un prog extérieur car j'ai éssayer des couper tous les process hormis ceux de windows enfin je sait pas c'était au cas ou quelqu'un aurais u le même problème que moi.
  38. mustang89 a dit (le 27-03-2006 à 11:00)
    salut H@kk@s
    Ca m'arrive aussi, mais j'ai trouvé le coupable : c'est mon notificateur d'arrivée de mails qui fait diversion et me ramène dans le mode de visualisation précédent. Mais hop un coup de double clic et je retourne en plein écran.
  39. JoE a dit (le 05-04-2006 à 22:11)
    un petit lien sur clubic qui ressemble fortement au même bug.
  40. streets a dit (le 05-04-2006 à 22:45)
    le bug a été bien corrigé depuis un moment
    mais je sais pas si veekee l'avais annoncé sur sont site
  41. veekee a dit (le 06-04-2006 à 11:27)
    salut
    J'avais mis à jour (de mémoire) les fiches sur ToutFr.com et mon site, et avais aussi publié l'information sur SourceForge (après avoir retiré le téléchargement le lendemain de son ajout du fait de bug assez "génant").
    Donc, oui, il s'agirait du même bug (dont je n'ai toujours pas réellement compris la cause et n'ai jamais pu le reproduire malgré mes tests), et certainement pas la faute d'un cheval de troie inclu (sachant que tous mes exe sont dans le même répertoire et que je les génère au même moment, soit ils auraient tous été infectés, soit aucun).
    PS : je réitère en tout cas la présentation de mes sincères excuses pour les victimes de ce malheureux problème dont je suis le seul fautif.
  42. JoE a dit (le 06-04-2006 à 23:08)
    salut veekee
    ne t'en fait pas ça arrive aux meilleurs dont tu fais parti.
    Je relayais juste l'info ici au cas où certains utilisateurs du forum ne l'auraient pas eue.
    Tu fais du bon boulot. Continue et merci
    PS: le trojan j'y crois pas non plus
Afficher l'actualité “Media Player Classic 6.4.8.8 v2” sur le forum
