Au menu des nouveautés, on notera des informations plus détaillées dans les propriétés des fichiers, la possibilité d'extraire les pièces jointes aux fichiers multimedia, la mise à jour du décodeur Matroska l'apparition d'une base de données, des effets de shaders, etc.
changelog complet
- The tray icon mode bahaviour has been changed a bit. Like it or not, now there is a taskbar button when the main window is not minimized. This change was needed to make mpc appear in taskman and the alt+tab window, and because the taskbar button was not always activating together with the window (bug in windows I guess).
- The playlist remembers its items after closing and relaunching the player.
- In capture mode, presets can be added to the playlist just like files and saved into a new playlist file format created for this purpose in the first place (.mpcpl).
- Image saving to the root directory fixed.
- A few "after playback" actions (close, shutdown). It can be found under the Play menu.
- Pixel shader effects and a little editor with basic autocomplete abilities. Requirements: dx9 renderless output mode + textured 3d blending + video card with pixel shader support (v2.0+ prefered). Besides the fun it can be used as a little sandbox to experiment with shaders in real-time. The code you write gets compiled on-the-fly and applied onto the video. Disassembled code and other compiler messages can be viewed in the output window. Even if you can't program in any language, there are a few samples to get you started.
- Left alt + numpad keys can rotate the picture with certain renderers (see the Output page in the options). Useful when you need to mirror the picture for some reason, or to correct the perspectivity a bit.
- Edge-transparency bug of the subtitle renderer fixed. It occured when more shapes were painted on top of eachother.
- New capture format: dsm, in addition to the already existing avi, ogm (needs external muxer) and matroska formats.
- Online subtitle database. The player can upload, search and download subtitles for recognized movie files in a semi-automatic way. The website was designed to run at different places at the same time, accessing a common database. If you want you can host a mirror yourself, just contact me about it.
- Internal webserver can also serve external files now (please don't forget to contribute nice pages
. To extract the pages for the first time, go to the options of the webserver and use the Deploy... button. There is also a new player interface page (an MPC look-a-like!) with cool javascript supported features to update everything in real-time without reloading the page, you should arm yourself with the latest browsers though. Be warned, what you can see, others can see too!
To prevent that, there is a checkbox to allow localhost connections only.
- Internal source filters can reopen files seemlesly when their file handle becomes invalid (wifi...). This has annoyed me for a long time, you'll be pleased if you experience similar problems
The read-ahead buffer was also increased from 1 to 5 megabytes.
- Real's API changed the volume level behind MPC's back, but now it is trapped and eliminated using the detours lib (2k/xp only).
Misc changes to the main menu:
File:
- properties/details: A short summary about the currently used codecs. The details depend on how well the source filter can fill in the mediatype structure. Don't be surprised if there is not bitrate or frame-rate, it's normal.
- properties/resources: Viewer tab for embeded files inside mkv or dsm. This page is only visible when there is something to view. Save As... button can save the files onto the hard disk, while double clicking opens them in the default browser served using MPC's webserver, when enabled of course.
- utils/dsm muxer: With this you can remultiplex your favorite files/streams into dsm. It has a clean and simple interface, conversion should be easy for anyone. Just be sure to try the right mouse button everywhere to find the available options, the context menu is different for different tree item types. Tagging, chapters, attached files and of course video/audio/subtitle streams can be saved into dsm.
Options:
- output: There is "lock back-buffer before..." checkbox to fix VMR9's vsync problems. Though it might not work for everyone, or with every video card.
- subtitles: "round up to power of two". In the past this option was always on, now it can be turned off to save a little video memory bandwith at higher resolutions. Older video cards don't support it, or have problems texturing the 32bpp subpictures on 16bpp desktop.
- subtitles/def.style: "position subtitles relative to the video frame". You will notice that this checkbox have three states. It is undefined for every custom style, therefore the value you set here for the default style gets inherited by them.
Filters:
- New mp3/aac source filter. Handles vbr files much better than the mpeg-i splitter of dshow. Another improvement is how the duration becomes more accurate as more samples are played. This filter is also more error resistant to corrupted id3 tags.
- Dirac decoder was upgraded to use the 0.5.0 lib.
- Mpeg splitter can seek discontinous streams much more reliably now. It just falls back to "seek by bitrate" mode when it detects something wrong in the continuity of the timestamps. Also, it is now able to play streamed mpeg over http (for example vlc's output).
- Latest DSM splitter and muxer included.
- New decoder for ps2's mpeg audio formats: pcm, adpcm (mostly found in .pss files). Please note that such files can't be seeked by design. If you try the sound will simply mute. It's because the data can be decoded only by starting from the beginning of the file.
- Matroska splitter can seek newer mkv files and display their duration.
File:
Options:
Filters:
Télécharger Media Player Classic 6.4.8.3 FR (attention la version zip est corrompue pour l'instant)
37 commentaires pour “Media Player Classic 6.4.8.3”
Le lecteur par défaut a voir sur son pc
Mais le Lecteur Windows Media Player 10 n'est pas censé être mieux ?
Trop Lourd
Merci fonji je vais l'installer vive l'anglais
Mais d'un coté... 500Ko en plus pour l'installateur... ça cache quelquechose :rolleyes:
le zip a été reuploadé (avec comme bonne idée que je n'ai pas modifié le nom, et donc que pour savoir si vous téléchargez la bonne version, c'est pas évident). Le zip doit faire 1.7mo (et non 1.2mo comme précédement).
Sinon, je la trouve plus lente que la version CVS que j'avais pu utiliser en janvier... aucune idée pourquoi
Parce que moi la version 10 ne me déplaît pas. Plus lente peut-être, mais sur mon ordinateur j'ferais pas la différence
Et en tout cas plus esthétique.
Faut voir quoi !
WMP 6 j'trouve ça plus destiné aux petits ordinateur, peu de mémoire RAM, ou encore les vieux OS genre 98.
Même s'il en a l'apparence, il est beaucoup plus évolué que celui-ci. Plus rapide, plus de fonctions, plus de formats....
Et ce n'est parce qu'un logiciel a une interface qui ne pompe pas de ressources qu'il est déstiné à un petit PC. A quoi bon changer d'ordinateur si les logiciels ne tournent pas plus vite ?
Perso j'utilise ta version CVS de janvier, et je n'arrive pas à trouver le menu de configuration des codecs dessus ... je vais essayer celle là, elle tourne sans doute mieux.
Bravo pour ton taf, et merci à Gabest
EDIT : oui bon je vais le re-télécharger on verra
XP Pro SP2 avec la version de mon nami Veekee
fonji > Aucune idée. Le problème du menu fichier est qu'il charge automatiquement les DVD pour récupérer les titres et que c'est peut être la raison pour laquelle ca plante (ca mis à part, c'est un menu statique). Dans tous les cas, je te conseille de passer par la page des bugs (http://sourceforge.net/tracker/?grou...03&atid=565649) )
- remembering playlist items can be turned off in the context menu
- fixed shaders randomly disappearing from the menu
- aspect ratio presets at view/video frame/override aspect ratio (default, 4:3, 5:4, 16:9)
- ctrl held during resizing keeps the window tight around the video
capture mode:
- better compatibility with terratec cinergy and other cards which output audio themselves
- the television standard can be set indirectly by the country code at the open device dialog (there is no other way in directshow...)
- a deinterlacer filter is loaded when the height is larger than 288 lines, only for previewing (the following color formats are supported: yuy2/uyvy/yv12/i420/iyuv)
- if there is only one video format offered by the video capture pin (320x240 for example) then mpc adds several other standard resolutions to the combo box
vmr9 renderless: (changes by Haali)
- bilinear + bicubic resizers, using pixel shader 2.0 (3d mode only)
- speed issues on secondary display may be fixed now (the file has to be opened there)
webserver:
- fixed the bug of serving external files from certain paths
- cgi support (tested with php only)
- default page can be set (index.html, etc.)
A ma connaissance, seul le splitter mp4 a été mis à jour.
http://sourceforge.net/project/showf...ease_id=367150
En attendant la traduction française
http://sourceforge.net/project/showf...ease_id=367903
MPC 6.4.8.6
1) The playlist is now automatically hidden when one file is opened, since there's no need for a playlist when it's only one file. Of course, this is provided that you had the playlist on from the previous session (this feature isn't working properly for me, sometimes it hides, sometimes it doesn't).
2) Meta tags reading in mp4 files, Winamp/iTunes style. I haven't checked if the latest Winamp 5.11 tags mp4 files in accordance with the way iTunes does it, but if it does, then iTunes tags in mp4 will be readable by MPC as well. Would be nice if someone could check this up and corroborate.
3) MPC now displays the artist/album/track/title/year in MSN, so it's a little bit improved when compared to how it was before. This applies for mp4 files with meta tags, and mp3 files with id3 v1 tags.
4) Version number has been updated to 6.4.8.6 BUT, this is not the next stable release, yet...
5) Font type of the "white on black" texts in mpc has been changed to a different font, and it now supports unicode. It looks the same though. It used to be on "MS Sans Serif", and that didn't support unicode, now it is set to "Microsoft Sans Serif", which does.
6) Shuffle (right click on the playlist) has been added, as an alternative to the randomize function. This works in a similar way to Winamp's shuffle mode.
7) Decoding of m3u playlist files saved by Winamp, has been improved to filter out unsupported text encoding in the playlist.
9) Chapter times in mp4 has been fixed.
10) AVC in *.mov plays, but the audio doesn't so far.
11) Skippy AAC playback in mp4 has been fixed. Damn this post has gotten huge
https://sourceforge.net/project/show...ease_id=369770
EDIT : ne prenez pas, la traduction semble complètement buggée, le menu filtre est inaccessible, plus de chapitres, plus de switch audio, ni sub, veekee, si tu passes par là, essaye de revoir ta traduction ^^
Tu dois avoir un programme qui se réveille de temps en temps et te fait sortir de ton plein écran
- CDDA Reader 1.0.0.1
- CDXA Reader 1.0.0.1
- DSM 1.0.0.4
- DTS/AC3 Source 1.0.0.1
- Matroska Splitter 1.0.2.7
- MPC 6.4.8.7
- MP4 Splitter 1.0.0.1
- MPA Decoder 1.0.0.1
- MPA Splitter 1.0.0.1
- MPEG Splitter 1.0.0.1
- MPV Decoder 1.0.0.1
- Ogg Splitter 1.0.0.0
- RealMediaSplitter 1.0.1.1
- VSFilter 2.37
https://sourceforge.net/project/show...ease_id=374402
- two pass bicubic shader, bilinear more optimized
- dropped subtitles are loaded instead of opening them as a media file
- thumbnail image generator
- dsm demuxer can output individual streams into files (context menu -> demux...), the raw data is corrected if possible, like subtitles are output to srt/ssa/vobsub, frame header added to aac, wave header to pcm, etc.
- better support for quicktime files by the mp4 splitter, more track types are recognized and also reads zlib compressed headers
- dvd navigator's software dvd region check is disabled using the detours lib, there is still a hw region check built in the firmware of the drives, unless it was flushed with a region free firmware it will still not work and may cause strange problems like freezing the player
- the mpeg ts splitter can repack h264 streams in "mp4 style" packets for decoders so they won't crash (ffdshow, coreavc)
- "next aspect ratio preset" command
- yv12/i420 is no longer a disallowed format when using "vmr9 (renderless)" as the renderer, holding the ctrl key when loading a file will still disable it, the current display drivers should not have that color conversion bug anymore but just in case...
- vmr9 (renderless) mixer mode available, it allows deinterlacing and other vmr9 features, off by default because it is slightly slower
- Haali's video renderer can be directly selected in the options (subtitling works, shaders don't)
- mpeg decoder sse2 optimizations (most noticable at hdtv resolution), optional interlaced output, new "field shifter" deinterlacing mode
- nero's "vobsub" inside mp4 supported
- clicking another window on a different monitor while mpc is playing in fullscreen will not restore it to normal size anymore, if another application grabs the focus, its name and window title will be displayed on the status bar of mpc
- graph builder of the filter graph manager was rewritten (again), let's hope nothing is more broken than it was
- new built-in async reader for udf sources, currently only works with the internal mpeg splitter because others aren't prepared for constantly growing files, use the following syntax as the file name: udp://[<multicastgroupip>]:<port>/[<mediasubtypeguid>], where "multicastgroupip" is optional and "mediasubtypeguid" can be used to specify the subtype of the stream, for example udp://:1234/{e06d8023-db46-11cf-b4d1-00805f6cbbea} means transport stream, it will also work fine without the subtype, just selecting the right splitter will take a little longer
- the checked state of the "enable subtitles" menu item is preserved, this means you can disable subtitling with the vmrs now without having to turn it off for each newly opened file
- floating toolbars are saved, next time mpc opens they will appear floated and at the same position on the desktop
- normalizer/booster was moved to the audio switcher, to avoid high spikes lowering the volume too much the normalizer regains 5% per second now
- "quick open file" menu (similar to vlc's)
- options/filters section was redone a bit, the internal filters have their own property pages, mpc won't be controlling them directly anymore
- there is a changelog this time!
other fixes:
- random crash when seeking files with mp3 audio streams and using the internal decoder
- compatibility with the oggds/vorbis decoder restored (it is a bug in the ogm vorbis decoder btw)
- blank checklist elements in options (external filters now, overrides before)
- run-time error when loading files with certain unicode characters in the filename
- unicode id3 tags, byte order of le/be utf-16 tags was mixed up
- repeated languages loading vobsub subtitles
- dvd angle switching (angle number was off by 1 for many years lol
- long delay when doing "seek to keyframe" with the avi splitter
- fading dvd subpics (~ multiple entries in DCSQT)
bad news:
- resource ids were cleaned up and renumbered, the old command assignments are lost, sorry.
Bientot la VF j'espère
