Communauté Informatique NDFR.net : DVD Decrypter 3.2.1.0 - Actualité
Old 15-03-2004, 14:06
Lien direct de la news : DVD Decrypter 3.2.1.0
Le célèbre logiciel de rippage de DVD est disponible en version 3.2.1.0
La longue liste des changements pour les intéressés :
  • Added: Verify option for ISO Write mode (DVDs only)
  • Added: ISO Write mode now displays the media's supported write speed in the log
  • Added: Additional debug information during initial program startup - when debug mode is enabled
  • Added: Dialog box with 'Yes to all' and 'No to all' when decryption is detected in a file on a supposedly non protected disc
  • Changed: Techniques used to determine the correct write parameters to use in ISO Write mode
  • Changed: 'Failed to decrypt disc key' no longer stops the program in its tracks
  • Changed: General improvements to CSS cracking techniques
  • Changed: 'semaphore timed out' errors now display the actual timeout value
  • Changed: Brute Force cracking failures no longer display an error dialog box if they're a result of the 'Detect Mastering Errors' option being enabled
  • Fixed: Setting the write speed to 2.4x (or 2,4x !) on systems that don't use a '.' for their decimal point
  • Fixed: 'Failed to Set Write Parameters' on Matshita drives
  • Fixed: Hang up on 'Searching for SCSI / ATAPI devices' when people have a certain Samsung CDROM drive in their machine
  • Fixed: Incorrect naming of AC3 files demuxed in File mode
  • Fixed: Big bug in ISO Read mode where files following 0 bytes files weren't decrypted
  • Fixed: Brute Force cracking on unauthenticated discs could fail silently
  • Fixed: Authentication on some discs would just repeat over and over again during reading without any error
  • Fixed: Polling for completion of certain I/O at the end of a burn in ISO Write mode would fail on certain drives
  • Fixed: I/O Errors using SPTI where the actual API call failed would often mean sense area information wasn't displayed in the dialog box
  • Removed: The option to 'Force CSS Present' - This has been made obsolete by recent improvements
A télécharger sur cette page
DVD Decrypter 3.2.3.0 Werner Actualité 1 07-07-2004 15:58
DVD Decrypter 3.2.2.0 LeMoi Actualité 3 26-04-2004 12:25
Extraire les bonus DVD avec DVD Decrypter LeMoi Logiciels 0 14-03-2004 15:43
DVD Decrypter 3.2.0.0 streets Actualité 2 08-03-2004 23:10
DVD Decrypter 3.1.9.0 streets Actualité 0 28-12-2003 20:02
