Communauté Informatique NDFR.net : DVD Decrypter 3.2.3.0 - Actualité
Old 07-07-2004, 09:19
Werner's Avatar
Werner Werner is offline
cOWboy attitUDe
Lien direct de la news : DVD Decrypter 3.2.3.0
Une nouvelle version de DVD Decrypter est disponible depuis hier. Pour rappel, ce programme permet de riper un DVD afin d'en sauvegarder le contenu sur son disque dur...
Voici la "petite" liste des changements :
  • Added: Option to save the log on exit
  • Added: Additional debug code to IFO mode that shows 'skipping' of unwanted cells
  • Added: A log entry for the 'L0 Data zone Capacity' when burning DVD+R DL discs
  • Added: A new option to the 'ISO Write' page in the settings - 'Cycle Tray Before Verify'
  • Added: Crash recovery for 'Checking for RCE Protection' code - so corrupt IFO files shouldn't mean the disc can't be copied - as all other IFO parsing can be avoided if required
  • Added: ISO Read / Write modes now display the % done of a background format on drives that support it. It will say 'Formatted: No (In Progress) (X% Complete)'. You have to perform a 'refresh' to make it update
  • Added: 'F8' now enables/disables I/O Debug Mode
  • Added: 'F9' to minimise the program to the system tray
  • Added: 'F12' to load up another instance of the program
  • Added: 'Browse' to the file menu for people who demand keyboard shortcuts!
  • Added: 'Exit' to the context menu on the system tray icon
  • Added: 'Firmware Updates...' to the drive context menu - links to http://forum.rpc1.org's web search engine
  • Added: 'Source Media Type' (i.e. DVD-R, DVD+R) to the log in IFO/File/ISO Read modes. It also displays Disc ID (i.e. RITEKG04) where possible
  • Added: Support for enabling 'SpeedRead DVD' on the Plextor PX-712A. This disables 2x locked reading on CSS media (not permanent)
  • Added: Support for another I/O Interface (Patin-Couffin)
  • Added: Support for just dragging a 'supported' image file onto the application icon and it automatically going into ISO Write mode
  • Added: Support for CLI error codes when in ISO Write mode - (1 = No media (Write couldn't start), 2 = Write failed, 3 = Verify failed)
  • Added: Support for '/SPEED ' CLI command
  • Added: Support for disabling 'Media Change Notification' under all I/O Interfaces. (Still need to be running Windows 2000, XP or 2003 though)
  • Added: Support for creation of 'Chapter Information - LBA' files in IFO mode
  • Added: Support for creation of 'Chapter Information - DVDLab' files in IFO mode
  • Added: Support for exclusive drive locking under ElbyCDIO in ISO Write mode
  • Added: Support for handling of corrupt IFO files. PGCs that don't really exist are now displayed as 'corrupt' in IFO mode
  • Changed: Changed CLI command /VERIFY to /VERIFY
  • Changed: Detection of 'end of disc' in ISO Read mode during the actual read phase. Implemented support for an additional error message
  • Changed: Detection of drive capabilities to work with drive that don't error out on a certain command but instead return blank information. This would previously have meant the drive would come up as 'Unknown' during initial drive scan
  • Changed: The order of a couple of commands in ISO Write mode. Aborting a failed 'exclusive lock failed' command would have left the disc in the 'Incomplete' state (i.e. non burnable) until you ejected / reinserted it
  • Changed: The volume is now dismounted and locked when it's locked in exclusive mode
  • Changed: The duration of exclusive locking. It now locks during verify too
  • Changed: Unsupported files in ISO Write mode now display more information as to why they're not supported
  • Changed: The method of finding out the current type of disc - so it may change the information in ISO Read / Write modes for burnt discs. (Bits may have been missed out in previous versions)
  • Changed: 'RCE Protection Found' dialog box to include ALL region. The program now also greys out options that aren't applicable - i.e. if the media isn't region 1,2,3,4,5,6,7,8
  • Changed: File mode logging when 'Detect Mastering Errors' is enabled. It now shows the correct LBA for the disc instead of for the file. (Keep things standard throughout the program)
  • Fixed: A problem using Device ID strings for the source / destination via CLI
  • Fixed: A problem with the DoItFast4U CLI switch whereby the CC (closed caption) data was copied over before it was decrypted
  • Fixed: A problem with possible oversized WAV files
  • Fixed: A problem with renaming of files and not checking the free disk space properly
  • Fixed: A problem with blank discs not coming up as 'Disc Is Empty' in the 'Read' modes
  • Fixed: A problem with 'Shutdown after write' on Windows 9x machines
  • Fixed: 'Failed To Set Write Parameters' error on Panasonic DVDRAM burners
  • Fixed: A problem with NSIS installer on Windows NT 4
  • Fixed: A problem where aborting a read in ISO mode could give you a 'pack header not found' warning in the log
  • Fixed: A problem with some corrupt IFO files causing access violation errors
  • Fixed: A problem where files with names < 12 characters in length wouldn't line up in the File mode file listing box
  • Fixed: A problem where ISO Read mode would hang if files other than IFO/BUP/VOB's were in the VIDEO_TS folder
  • Fixed: A problem where all files in the VIDEO_TS folder (other than VOBs) would get processed by IFO/BUP patching code in File mode
Télécharger DVD Decrypter 3.2.3.0
Visiter le site officiel
Source : fileforum.com
Old 07-07-2004, 15:58
rooo, Formatman, pourquoi que t'utilises pas les petites icones de changelog (fix, et add)
DVD Decrypter 3.2.2.0 LeMoi Actualité 3 26-04-2004 12:25
DVD Decrypter 3.2.1.0 LeMoi Actualité 0 15-03-2004 14:06
Extraire les bonus DVD avec DVD Decrypter LeMoi Logiciels 0 14-03-2004 15:43
DVD Decrypter 3.2.0.0 streets Actualité 2 08-03-2004 23:10
DVD Decrypter 3.1.9.0 streets Actualité 0 28-12-2003 20:02
