En voici grâce à Kaspof le changelog depuis la 1.062 (on pourra noter entre autres le fait que le programme soit désormais gratuit
):- + Display IP/Port when connecting with Passive/Active mode at Data channel
- + Jump to parent directory when the 4th button(BACK) of 5 buttons mouse pressed
- + Improved monitor of local file window for file/folder changed
- - Local Tree Combo lost image when dropdown ShellTree with "show full path" mode
- - Xml parsing error when xml property value includes ">" or "<"
- - Now Server will stay at current folder(remote/local) when pause a transfering queue
- - Now "LIST" of anti idle command force a refresh evenif FTP cache option enabled
- - Slow exiting when close UltraFXP with local file window is visible
- - PWD function trimmed space at address bar, so the remote patch is wrong when folder includes space
- - for PopupMenu of local window, if click "delete" item with Shift key down, still sent to recycle bin
