NDFR : MetaProducts Offline Explorer Pro/Enterprise 3.1
Offline Explorer est un puissant aspirateur de sites Web et FTP (et à mes yeux le meilleur, mais bon, je ne suis pas très objectif). La version Pro permet même la capture de flux RTSP, MMS, et le version Enterprise propose en plus une interface OLE (HS : si vous savez ce que c'est, faites- moi signe, je ne voudrais pas mourir idiot). Je ne vous mets que le changelog de la version Enterprise, puisqu'il rassemble celui des deux autres versions :
  • Added "Original URLs" feature to the Export dialog
  • Improved ASX files detection
  • Added Additional=SkipIFrames URLs field parameter
  • Improved evaluation of script expressions
  • Improved downloading forms with drop-down lists
  • Added drop-down menu to the Suspend button
  • Improved recognition of some Flash links
  • Improved automatic redirects to MMST protocol when MMS fails
  • Improved parsing script links with colon symbols
  • Improved parsing script comments
  • Improved UTF-16 encoding support
  • Added /LogFilter= command-line parameter
  • Added Additional=DepthFirst URLs field parameter
  • Improved browsing HTML forms offline
  • Added Queue management functions to IOEProject
  • Improved Referer assignment in JavaScript files
  • Improved search (Ctrl-F) feature
  • Added "Highlight Active Connections" to the Connections Panel menu
  • Improved URLs Substitution
  • Added "Abort & Disable" to the Queue Manager menu
  • HTTP Server log now shows resulting status code
  • Java class parser will now try to extract more links
  • Improved authorization on several sites when downloading a Project
  • Improved MMS stream end detection
  • Bug Fix: Fixed infinite parsing bug when forms exploration is enabled
  • Bug Fix: Fixed a minor HTML editor syntax highlight issue
  • Bug Fix: Fixed improper translation of some script links
  • Bug Fix: Fixed creating contents.htm file when exporting to ZIP, CHM or MHT
  • Bug Fix: Fixed ability to use improper symbols in a folder name
  • Bug Fix: Fixed adding original URLs to redirect files during Export
  • Bug Fix: Fixed links translation in some script expressions during export
  • Bug Fix: Fixed loading system links from the Internal Web server
  • Bug Fix: Fixed bug when switching to the Queue tab
  • Bug Fix: Fixed assigning a modified MS IE User Agent
  • Bug Fix: Fixed a rare bug when stopping a Project download
  • Bug Fix: Fixed loading forms that require a user input
  • Bug Fix: Fixed displaying stopped state of a Project
  • Bug Fix: Fixed adding a URL with commas from the command line
  • Bug Fix: Fixed loading Java applets with dot symbols in URLs
  • Bug Fix: Fixed getting improper URLs from script expressions
Plus d'infos sur le site officiel
Télécharger une version d'essai de Offline Explorer (multilangue)
Télécharger une version d'essai de Offline Explorer Pro (multilangue)
Télécharger une version d'essai de Offline Explorer Enterprise (multilangue)
5 commentaires pour “MetaProducts Offline Explorer Pro/Enterprise 3.1”
  1. Kaspof a dit (le 27-03-2004 à 22:30)
    Originally Posted by LeMoi
    Offline Explorer est un puissant inspirateur de sites Web
    Pour tous ceux qui ne savent pas ce qu'ait un inspirateur de sites web; c'est tout simplement un programme qui donne de l'inspiration lors de la création de vos pages persos...
  2. LeMoi a dit (le 27-03-2004 à 22:34)
    c vrai que c pas évident pour tout le monde
  3. Samva a dit (le 27-03-2004 à 23:16)
    LoL Kaspof
  4. whynot a dit (le 28-03-2004 à 13:20)
    lol. Petit retour au sujet désolé .
    Juste pour vous conseiller HTTrack, qui est lui aussi un excellent [groslourd mode on] inspirateur de sites ouaibe (krrr krrr krrr :rolleyes mais qui a l'avantage d'être totalement gratuit puisque opensource, et dispo pour moultes plates-formes.
    Et peux pas comparer, j'ai encore jamais essayé celui que propose LeMoi.
  5. LeMoi a dit (le 28-03-2004 à 14:08)
    moi je préfère offline explorer car il peut capturer facilement les sites en asp, ce dont j'avais besoin et que ne faisaient pas correctement les autres que j'ai testés
Afficher l'actualité “MetaProducts Offline Explorer Pro/Enterprise 3.1” sur le forum
