- La virtualisation expérimentale de MacOS X (uniquement sur les ordinateurs de la marque Apple)
- Une fonction d'allocation dynamique de mémoire vive d'une VM sur un système hôte 64 bits
- L'ajout/suppression à chaud de processeurs virtuels pour les systèmes invités Linux et certains invités Windows (uniquement l'ajout)
- Nouvelles fonctionnalités de l'hyperviseur
- Support de la suppression de clichés à chaud lorsque la machine virtuelle est en cours d'execution
- Support de la gestion des moniteurs multiples dans les systèmes invités Windows
- Émulation de claviers/tablettes pour une meilleure expérience utilisateur si aucun drivers invité additionnel est installé
- Émulation du contrôleur LsiLogic SAS
- Et pleins d'autres nouveautés...
Voici le changelog complet :
VirtualBox 3.2.0 (released 2010-05-18 )
This version is a major update. The following major new features were added:
* Following the acquisition of Sun Microsystems by Oracle Corporation, the product is now called Oracle VM VirtualBox and all references were changed without impacting compatibility
* Experimental support for Mac OS X guests (see the manual for more information)
* Memory ballooning to dynamically in- or decrease the amount of RAM used by a VM (64-bit hosts only) (see the manual for more information)
* Page Fusion automatically de-duplicates RAM when running similar VMs thereby increasing capacity. Currently supported for Windows guests on 64-bit hosts (see the manual for more information)
* CPU hot-plugging for Linux (hot-add and hot-remove) and certain Windows guests (hot-add only) (see the manual for more information)
* New Hypervisor features: with both VT-x/AMD-V on 64-bit hosts, using large pages can improve performance (see the manual for more information); also, on VT-x, unrestricted guest execution is now supported (if nested paging is enabled with VT-x, real mode and protected mode without paging code runs faster, which mainly speeds up guest OS booting)
* Support for deleting snapshots while the VM is running
* Support for multi-monitor guest setups in the GUI for Windows guests (see the manual for more information)
* USB tablet/keyboard emulation for improved user experience if no Guest Additions are available (see the manual for more information).
* LsiLogic SAS controller emulation (see the manual for more information)
* RDP video acceleration (see the manual for more information)
* NAT engine configuration via API and VBoxManage
* Use of host I/O cache is now configurable (see the manual for more information)
* Guest Additions: added support for executing guest applications from the host system (replaces the automatic system presimparation feature; see the manual for more information)
* OVF: enhanced OVF support with custom namespace to preserve settings that are not part of the base OVF standard
In addition, the following items were fixed and/or added:
* VMM: fixed Windows 2000 guest crash when configured with a large amount of RAM (bug #5800)
* Linux/Solaris guests: PAM module for automatic logons added
* GUI: guess the OS type from the OS name when creating a new VM
* GUI: added VM setting for passing the time in UTC instead of passing the local host time to the guest (bug #1310)
* GUI: fixed seamless mode on secondary monitors (bugs #1322 and #1669)
* GUI: offer to download the user manual in the OSE version (bug #6442)
* Main: allow to start a VM even if a virtual DVD or floppy medium is not accessible
* Settings: be more robust when saving the XML settings files
* Mac OS X: rewrite of the CoreAudio driver and added support for audio input (bug #5869)
* Mac OS X: external VRDP authentication module support (bug #3106)
* Mac OS X: Moved the realtime dock preview settings to the VM settings (no global option anymore). Use the dock menu to configure it.
* Mac OS X: added the VM menu to the dock menu
* 3D support: fixed corrupted surface rendering (bug #5695)
* 3D support: fixed VM crashes when using ARB_IMAGING (bug #6014)
* 3D support: fixed assertion when guest applications uses several windows with single OpenGL context (bug #4598 )
* 3D support: added GL_ARB_pixel_buffer_object support
* 3D support: added OpenGL 2.1 support
* 3D support: fixed Final frame of Compiz animation not updated to the screen (Mac OS X only) (bug #4653)
* 3D support: fixed blank screen after loading snapshot of VM with enabled Compiz
* Added support for virtual high precision event timer (HPET)
* OVF: fixed mapping between two IDE channels in OVF and the one IDE controller in VirtualBox
* OVF: fix VMDK format string identifiers and sort XML elements from rasd: namespace alphabetically as prescribed by standard
* VBoxShell: interactive Python shell extended to be fully functional TUI for VirtualBox
* Linux Additions: support Fedora 13 (bug #6370)
* VBoxManage: fixed overly strict checks when creating a raw partition VMDK (bugs #688, #4438 )
Oracle VM Virtualbox 3.2.0 reste toujours disponible pour tous les systèmes d'exploitation Windows, MacOS et LinuxVirtualBox 3.2.0 (released 2010-05-18 )
Télécharger Oracle VM Virtualbox 3.2.0
Source : n'1fo[r-matik]
1 commentaire pour “Oracle VM Virtualbox 3.2.0”
