Communauté Informatique NDFR.net : The Bat 2.1 le 15 Avril - Vos news
Old 12-04-2004, 12:43
BeClaude's Avatar
BeClaude BeClaude is offline
The Bat 2.1!
Ritlabs annonce officiellement la sortie prochaine "le 15 avril 2004" de The Bat! 2.1 .
Pour rappel The Bat! un un client email.
Elle serra disponible sur cette page:
http://www.ritlabs.com/en/products/thebat/download.php
Voici la liste des nouveautés et amélioration de ce dernier.
The Bat! 2.1. on April 15, 2004.
There are the following improvements in the upcoming version:
- Virtual Folders
Virtual folders will contain messages which are just links to the messages in the regular physical
folders. You just need to specify the search expression to filter the messages into virtual folders.
A single message can reside in several physical folders. If you delete it physically, it will be
removed from all virtual folders at once.
- Folder View Modes
If you will need to quickly change the position of columns in a message list, adjust the sort order
or do other customization, you would be able create View Mode Profiles and switch them on-the-fly
using shortcut keys or via menu.
- An updated HTML editor. You will have the opportunity to insert and
edit tables and lists.
- An updated BayesIT! plug-in for Spam protection.
The quality of spam detection will be as high as 99.6%, which is currently the highest
figure in the world.
- Interface will be improved for better compliance with of Windows XP Themes.
- Bugs of previous versions will be fixed.
Edition du 17 Avril
http://www.ritlabs.com/bitrix/redire...bat2.10.00.exe
The Bat!. Version 2.10
Date: Fri Apr 16 2004.
What's new in The Bat! 2.10?
[ Legend: ]
[ + Added feature ]
[ * Improved/changed feature ]
[ - Bug fixed (we hope) ]
[!] It is now possible to create Virtual Folders: "New|Virtual Folder" in the folder tree pop-up menu or "Virtual
Folder" button in the Message Finder
[+] Folder set tabs for viewing limited sets of folders like folders with unread messages, Virtual Folders and
folders associated with a particular Colour Group
[+] New HTML editor with support of tables and lists
[+] Marking all messages as read is now working for sub-folders and entire accounts[*] Selection cursor in HTML and Rich Text Viewer[*] Speed of loading messages into HTML/Rich Text viewer is improved[*] When a message base size is about 2GB, an explanation error box is given.[*] Common Virtual Folder name decoration can be changed in Options/Preferences/Global
[-] (#0002223) View mode: Entire message condition disappeared from Filter section
[-] (#0002645) "No message loaded" ws displayed when a message did not have a textual body
[-] (#0002753) %OCHARSET macro was not functional
Thank you for your choice!
Le SP2 obligatoire dès le 12 avril Benjy Actualité 54 26-02-2005 19:42
Patchs cumulatifs pour Outlook Express (Avril 2004) Werner Actualité 0 13-04-2004 21:46
1er avril classer X BeClaude Discussions 6 07-04-2004 13:41
Comme on est plus le 1er avril Werner Discussions sur le site et/ou le forum 24 06-04-2004 11:41
Ou en est le 1024 avec Free dda42 Windows NT4/2000/XP Client 19 07-03-2004 01:04
