Winamp 5.22
Lien direct de la news : Winamp 5.22
Et hop voici une nouvelle version de Winamp qui sort sans prévenir. Quelques nouveautés que je vous laisse découvrir
![]() Winamp 5.22 * New: loading of additional playlist formats: ASX/WAX/WMX/WVX, WPL, B4S * New: [gen_ff] modern skin unicode support * New: [in_wm] burning of DRM protected files (if allowed by content provider) * New: [ml_pmp] transfer of playlists to portable devices * Improved: More informative CD burning status window * Improved: [gen_ff] modern skinning engine speed optimizations * Improved: [gen_jumpex] jump-to-file search response * Improved: [gen_tray] enhanced icon pack support plus more... (thanks DrO) * Improved: [in_wm] seeking improvements * Improved: [in_wm] gapless WMA support * Improved: [ml_nowplaying] Redesigned 'Now Playing' media library view (it actually works now) * Improved: [pmp_ipod] Loading times for iPods reduced * Fixed: Winamp won't restore after being minimized with a dialog box open * Fixed: $abbr() title formatting lockup * Fixed: Add Folder adds tracks BEFORE the last track * Fixed: Clicking 'Next' in Fullscreen video OSD acts like clicking it twice * Fixed: Rating in pledit right-click context menu always shows "No Rating" * Fixed: Stop with fadeout (Shift+V) just stops playback, no fadeout * Fixed: CD burning bugs and crashes * Fixed: Delete key not working in Online Services or SC Wire search * Fixed: [gen_jumpex] handling of playlist with more than 65,536 files * Fixed: [gen_jumpex] 'on end of queue' fixed * Fixed: [gen_jumpex] modern skin pledit docked toolbar mode not remembered * Fixed: [gen_jumpex] ML size/position not remembered when switching from Classic to Modern and back to Classic skin * Fixed: [gen_jumpex] misc bug fixes * Fixed: [gen_ml] playlists root view slowness bug * Fixed: [gen_ml] Modern skin: Media Library > View (menu) > Devices * Fixed: [in_midi] corrupt header crash * Fixed: [in_mp4] metadata writing crash * Fixed: [in_mp4] seek bug when using right arrow key * Fixed: [in_mp3] MPEG-2 and MPEG-2.5 Layer 3 playback crash * Fixed: [in_mp3] Winamp crashes when trying to play any wrongly named .aac file * Fixed: [in_wave] WAV burning fix * Fixed: [in_wave] Locking files (wav's can't be renamed/deleted) * Fixed: [in_wm] lockup on wma with expired/unrenewable drm license * Fixed: [in_wm] out of sync audio/video on some WMV streams * Fixed: [in_vorbis] fullpath shown in playlist for tagless files with atf disabled * Fixed: [ml_pmp] Duplicates being synchronized * Fixed: [ml_pmp] Several crashes during transfers * Fixed: [out_ds] Can't select different Output Device with two active instances of out_ds * Fixed: [out_ds] incorrect enumeration of stereo outputs for two of same pro soundcard Télécharger Winamp 5.22 Final Full Télécharger Winamp 5.22 Final Lite
Bon maintenant on peut vraiment dire que Winamp est un bouffeur de ressources...
41 Mo en RAM dès le démarrage... (avec une pointe à 55-60Mo) Bravo ![]() Pour un lecteur supra léger, il pèse 4 fois plus en RAM que WMP11... (qui lui a l'étiquette d'un lecteur lourd) Ironie... quand tu nous tiens ![]()
Essaie avec les skins old school, juste pour comparer, j'aimerai savoir...
Chez wam c'est 14Mo avec le skin classic, quelques plugins virés, d'autres ajoutés et une media library plus que chargée
Et certes WMP semble plus léger mais c'est pas vraiment comparable niveau features et il est impossible d'avoir une vraie estimation de la consommation RAM de WMP puisque c'est intégré au evilsystem.
Une fois minimisé, ça retombe à 12 Mo. Mais bon, ce n'est pas vraiment 12 Mo (je ne récupère pas les 36 Mo restants)
Bizarre tes 48Mo/60Mo...
Chez moi ça tourne entre 8 et 20 Mo selon si c'est minimisé ou affiché. Par contre avant d'installer le version 5.22, j'ai tout désinstallé. Et réinstallé Winamp 5.22 full, puis winamp 5.21 french, le pack ultime et french radio v2. Affichage avec le modern skin. |
patch fr dispo http://www.winampfr.com/indextele.php
vers. 1,6 ps: enfin bientot (bien que la newsletter est parue)
"Il y a au moins deux solutions à un problème "![]() "Internet tue des bébés loutre" Last edited by streets; 05-06-2006 at 22:11. |
streets
![]() merci en fait je me flagelle tout seul le texte a bien été validé....mais l'exe est pas passé le webmaster américain...seul à bord du site (non mais c'est fou !!) planche sur le probleme on en a ch** sur ce patch je vous dit pas
Les gelflings sont zen...sauf quand on leurs prends le choux
La nouvelle devteam est fidèle aux traditions de leurs ancêtres. Voilà venir une build 666
![]() Lien FileForum (chuis fainéant là)
PS: pour les lien de telechargement c'est les meme:remplacer le 2 par un 3 ![]() sinon voir le post en dessous ![]()
"Il y a au moins deux solutions à un problème "![]() "Internet tue des bébés loutre" Last edited by streets; 08-06-2006 at 00:15. |
Winamp 5.23 build 670 effectivement
Changelog Télécharger Winamp 5.23 Full Winamp 5.23 * Improved: [gen_jumpex] jump-to-file speed improvements * Fixed: playlist saving with network share files * Fixed: Media Library preferences not loading in correct order * Fixed: main window not hilited when restoring from minimized state in classic skin. * Fixed: slow loading of playlists with URLs * Fixed: CD burning using third party input plugins * Fixed: classic skin winshade playlist time display * Fixed: [gen_ff] Wasabi XML font-related fixes from Martin Poehlmann * Fixed: [gen_ff] Map.getHeight() maki script function returning width instead * Fixed: [gen_ff] winshade global hotkeys broken w/ modern skins * Fixed: [gen_jumpex] 'Add to Queue' issues * Fixed: [gen_jumpex] NT4 incompatability * Fixed: [gen_jumpex] misc bug fixes * Fixed: [gen_ml] icon changes on drag+drop items * Fixed: [in_mp3] playback of AAC streams * Fixed: [in_mp4] seek bug when using right arrow key * Fixed: [in_wm] Playback restarts from beginning when editing tags of a currently playing .wma file * Fixed: [in_wm] protocol/extension reversed in config > filetype > edit * Fixed: [in_wm] 'Audio only' always checked for ASF/WMV in config * Fixed: [in_wm] seek bug when using right arrow key * Fixed: [ml_bookmarks] 'Edit Bookmarks' menu item not working when Media Library is hidden * Fixed: [ml_local] crash while rearranging media library views * Fixed: [ml_local] crash on close * Fixed: [ml_local] sort arrow reversed in some columns * Fixed: [ml_playlists] Import Playlists uses containing dir for title instead of filename * Fixed: [ml_playlists] No "Recurse" checkbox in Import Playlists From Folder * Fixed: [ml_playlists] Add Dir adds all filetypes (not just all-supported) * Fixed: [ml_playlists] rt-click enqueue not working & other issues * Fixed: [ml_playlists] Not saving playlists in some situations * Fixed: [ml_playlists] crash when loading badly formed WPL playlists * Fixed: [ml_playlists] drag&drop into playlist not adding to correct position * Fixed: [ml_playlists] root playlist screen not updating when adding new playlist * Fixed: [ml_playlists] reverting changes on send-to: playlist * Fixed: [ml_playlists] drag+drop m3u files broken * Fixed: [ml_pmp] Syncing duplicates finally fixed (thanks gordol) * Fixed: [ml_pmp] Removing items from a playlist not saving issue (thanks Nick) * Fixed: [ml_wire] some podcasts only display one item * Fixed: [pmp_ipod] Playlist sort now works again * Fixed: [out_ds] stop with fade (shift+v) issue * Updated: [in_cdda] CDDB 2.0.1.25 Télécharger Winamp 5.23 Lite
Apparement il y a eu une update dans la journée vers la build 5.23.0672
un bug dans la Media Library en serait la cause. Quote:
1for-matik
grace à toi .....je sais pas comment te remercier !! je passais par hasard alors qu'on entame la trad ...De la médiatheque donc on aurait sorti un patch mauvais !! arffff et on a trouvé une parade de malade pour le patch : on fera ..une deuxieme fiche (puisque la creation /soumission) ne pose pas de probleme c'est la mise à jour du patch donc là ce sera plus rapide ! youpi! MERCI
Sioupayrmaaaaaaaaan... col mi Sioupayrmaaaaaaaaaaaaaaaaaan
Mais je fais mon boulot de newser mon cher gelflings
| (pas à pas) n'importe quelle radio/TV sur winamp | gelflings | Logiciels | 0 | 21-05-2006 18:17 |
| WinAmp 5.0 Finale | streets | Actualité | 50 | 26-12-2003 23:40 |
| Après la RC2 la RC8 de WinAMP 5 | Werner | Actualité | 8 | 21-11-2003 19:00 |
| Winamp 5 beta 2 | streets | Actualité | 0 | 29-10-2003 01:42 |
| WinAmp 2.90 Beta & WinAMP 3 Build 498 | Werner | Actualité | 16 | 03-04-2003 05:02 |
