Winamp 5.22
* New: loading of additional playlist formats: ASX/WAX/WMX/WVX, WPL, B4S
* New: [gen_ff] modern skin unicode support
* New: [in_wm] burning of DRM protected files (if allowed by content provider)
* New: [ml_pmp] transfer of playlists to portable devices
* Improved: More informative CD burning status window
* Improved: [gen_ff] modern skinning engine speed optimizations
* Improved: [gen_jumpex] jump-to-file search response
* Improved: [gen_tray] enhanced icon pack support plus more... (thanks DrO)
* Improved: [in_wm] seeking improvements
* Improved: [in_wm] gapless WMA support
* Improved: [ml_nowplaying] Redesigned 'Now Playing' media library view
(it actually works now)
* Improved: [pmp_ipod] Loading times for iPods reduced
* Fixed: Winamp won't restore after being minimized with a dialog box open
* Fixed: $abbr() title formatting lockup
* Fixed: Add Folder adds tracks BEFORE the last track
* Fixed: Clicking 'Next' in Fullscreen video OSD acts like clicking it twice
* Fixed: Rating in pledit right-click context menu always shows "No Rating"
* Fixed: Stop with fadeout (Shift+V) just stops playback, no fadeout
* Fixed: CD burning bugs and crashes
* Fixed: Delete key not working in Online Services or SC Wire search
* Fixed: [gen_jumpex] handling of playlist with more than 65,536 files
* Fixed: [gen_jumpex] 'on end of queue' fixed
* Fixed: [gen_jumpex] modern skin pledit docked toolbar mode not remembered
* Fixed: [gen_jumpex] ML size/position not remembered when switching from Classic to Modern and back to Classic skin
* Fixed: [gen_jumpex] misc bug fixes
* Fixed: [gen_ml] playlists root view slowness bug
* Fixed: [gen_ml] Modern skin: Media Library > View (menu) > Devices
* Fixed: [in_midi] corrupt header crash
* Fixed: [in_mp4] metadata writing crash
* Fixed: [in_mp4] seek bug when using right arrow key
* Fixed: [in_mp3] MPEG-2 and MPEG-2.5 Layer 3 playback crash
* Fixed: [in_mp3] Winamp crashes when trying to play any wrongly named .aac file
* Fixed: [in_wave] WAV burning fix
* Fixed: [in_wave] Locking files (wav's can't be renamed/deleted)
* Fixed: [in_wm] lockup on wma with expired/unrenewable drm license
* Fixed: [in_wm] out of sync audio/video on some WMV streams
* Fixed: [in_vorbis] fullpath shown in playlist for tagless files with atf disabled
* Fixed: [ml_pmp] Duplicates being synchronized
* Fixed: [ml_pmp] Several crashes during transfers
* Fixed: [out_ds] Can't select different Output Device with two active instances of out_ds
* Fixed: [out_ds] incorrect enumeration of stereo outputs for two of same pro soundcard
Télécharger Winamp 5.22 Final Full
Télécharger Winamp 5.22 Final Lite
24 commentaires pour “Winamp 5.22”
41 Mo en RAM dès le démarrage... (avec une pointe à 55-60Mo)
Bravo
Pour un lecteur supra léger, il pèse 4 fois plus en RAM que WMP11... (qui lui a l'étiquette d'un lecteur lourd)
Ironie... quand tu nous tiens
Et certes WMP semble plus léger mais c'est pas vraiment comparable niveau features et il est impossible d'avoir une vraie estimation de la consommation RAM de WMP puisque c'est intégré au evilsystem.
Une fois minimisé, ça retombe à 12 Mo. Mais bon, ce n'est pas vraiment 12 Mo (je ne récupère pas les 36 Mo restants)
Chez moi ça tourne entre 8 et 20 Mo selon si c'est minimisé ou affiché.
Par contre avant d'installer le version 5.22, j'ai tout désinstallé.
Et réinstallé Winamp 5.22 full, puis winamp 5.21 french, le pack ultime et french radio v2.
Affichage avec le modern skin.
vers. 1,6
ps: enfin bientot (bien que la newsletter est parue)
merci
en fait je me flagelle tout seul
le texte a bien été validé....mais l'exe est pas passé
le webmaster américain...seul à bord du site (non mais c'est fou !!) planche sur le probleme
on en a ch** sur ce patch je vous dit pas
Lien FileForum (chuis fainéant là)
à peine la 5.22 patché fr ke la 5.23 sort lol
Winamp 5.23
Winamp 5.23
PS: pour les lien de telechargement c'est les meme:remplacer le 2 par un 3
sinon voir le post en dessous
Winamp 5.23
* Improved: [gen_jumpex] jump-to-file speed improvements
* Fixed: playlist saving with network share files
* Fixed: Media Library preferences not loading in correct order
* Fixed: main window not hilited when restoring from minimized state in classic skin.
* Fixed: slow loading of playlists with URLs
* Fixed: CD burning using third party input plugins
* Fixed: classic skin winshade playlist time display
* Fixed: [gen_ff] Wasabi XML font-related fixes from Martin Poehlmann
* Fixed: [gen_ff] Map.getHeight() maki script function returning width instead
* Fixed: [gen_ff] winshade global hotkeys broken w/ modern skins
* Fixed: [gen_jumpex] 'Add to Queue' issues
* Fixed: [gen_jumpex] NT4 incompatability
* Fixed: [gen_ml] icon changes on drag+drop items
* Fixed: [in_mp3] playback of AAC streams
* Fixed: [in_wm] Playback restarts from beginning when editing tags of a currently playing .wma file
* Fixed: [in_wm] protocol/extension reversed in config > filetype > edit
* Fixed: [in_wm] 'Audio only' always checked for ASF/WMV in config
* Fixed: [in_wm] seek bug when using right arrow key
* Fixed: [ml_bookmarks] 'Edit Bookmarks' menu item not working when Media Library is hidden
* Fixed: [ml_local] crash while rearranging media library views
* Fixed: [ml_local] crash on close
* Fixed: [ml_local] sort arrow reversed in some columns
* Fixed: [ml_playlists] Import Playlists uses containing dir for title instead of filename
* Fixed: [ml_playlists] No "Recurse" checkbox in Import Playlists From Folder
* Fixed: [ml_playlists] Add Dir adds all filetypes (not just all-supported)
* Fixed: [ml_playlists] rt-click enqueue not working & other issues
* Fixed: [ml_playlists] Not saving playlists in some situations
* Fixed: [ml_playlists] crash when loading badly formed WPL playlists
* Fixed: [ml_playlists] drag&drop into playlist not adding to correct position
* Fixed: [ml_playlists] root playlist screen not updating when adding new playlist
* Fixed: [ml_playlists] reverting changes on send-to: playlist
* Fixed: [ml_playlists] drag+drop m3u files broken
* Fixed: [ml_pmp] Syncing duplicates finally fixed (thanks gordol)
* Fixed: [ml_pmp] Removing items from a playlist not saving issue (thanks Nick)
* Fixed: [ml_wire] some podcasts only display one item
* Fixed: [pmp_ipod] Playlist sort now works again
* Fixed: [out_ds] stop with fade (shift+v) issue
* Updated: [in_cdda] CDDB 2.0.1.25
Télécharger Winamp 5.23 Lite
un bug dans la Media Library en serait la cause.
The installers have now been silently updated to include the above fix.
A new ml_disc.dll is also included which fixes a ripping bug with m3u generation.
The installer and your winamp.exe version # should now be 5.2.3.672
If you've still got 5.2.3.669 from the 8th June then we recommended updating.
grace à toi .....je sais pas comment te remercier
je passais par hasard alors qu'on entame la trad ...De la médiatheque
donc on aurait sorti un patch mauvais !! arffff
et on a trouvé une parade de malade pour le patch : on fera ..une deuxieme fiche (puisque la creation /soumission) ne pose pas de probleme c'est la mise à jour du patch
donc là ce sera plus rapide !
youpi!
MERCI
Mais je fais mon boulot de newser mon cher gelflings
http://winampfr.com/?newzyland=478
Fixed: [in_midi] crash bug & potential security vulnerability
c'est une correction du plugin in_midi.dll donc on ne fera pas de patch adéquat.
EDIT : 23/06/2006 à 06h10
Bon ok l'autre patch était 100% compatible mais vous auriez eu quelques messages d'alertes. Donc le patch est sorti, recompilé pour que ce soit un patch compatible et agréable à installer !
Et maintenant tout semble refonctionner sur Winamp.com c'est donc un patch officiel !
Petite modification .......
Téléchargement : ici
* New: Unicode filename and title support
* New: M3U8 (Unicode) playlist support
* New: [ml_pmp] Playback now works for playsForSure and Creative NJB devices
* New: [ml_pmp] "Copy to Library" - transfer songs from any device to your local library (uses CD rip settings)
* New: [pmp_usb] USB Drive/Portable device support
* Improved: [in_mp3] streaming id3v2 support
* Improved: 24bit EQ support
* Improved: [in_mp3] 24bit MP3 playback, 64bit internal precision
* Improved: [in_mp3/in_mp4] 24bit AAC playback
* Improved: fullscreen video seekbar
* Improved: [ml_pmp] Only relevant columns shown in song views
* Improved: [ml_pmp] "Getting Metadata" now much faster
* Improved: ATF updates
* Improved: DC filter on spectral visualization, to remove bass bias
* Fixed: Burning files that require resampling
* Fixed: multiple copies of Winamp when opening too many files/folders from explorer
* Fixed: freeze when exiting via System Tray icon
* Fixed: Delay/hang when loading dead stream url's
* Fixed: [enc_lame] broken vbr presets
* Fixed: [gen_ff] layerfx not being redrawn on colortheme change
* Fixed: [gen_ff] gradient drawing glitch and crash
* Fixed: [gen_ff] custom color themes bug
* Fixed: [gen_jumpex] hang when suspending or hibernating
* Fixed: [in_cdda] cutoff of last few sectors
* Fixed: [in_midi] truncated playback of some MIDI files
* Fixed: [in_mod] title display bug for module streams with no title
* Fixed: [in_mp3] crash when editing ID3 tags
* Fixed: [in_mp3] ID3v2 and ID3v1 Comment & Genre tags shared
* Fixed: [in_mp3] Inaccurate Time Remaining display for AAC files
* Fixed: [in_wm] DRM Video playback on certain hardware
* Fixed: [in_wm] freezeup when seeking a paused wma
* Fixed: [in_wm] Hang with dead WMV link in pledit in Repeat mode
* Fixed: [ml_disc] CD ripping / playlist generation bug
* Fixed: [ml_playlists] losing stream titles
* Fixed: [ml_playlists] sort by title
* Fixed: [ml_playlists] Send To from local media to ml playlist replaces instead of enqueues
* Fixed: [ml_playlists] Enqueue as default broken in left pane
* Fixed: [ml_playlists] Playlist title > rt-click > New Playlist = broken
* Fixed: [ml_playlists] tracklength bug
* Fixed: [ml_playlists] playlist paths issue
* Fixed: [ml_pmp] Transfers stalling after encountering a dupe
* Fixed: [out_ds] volume not hitting 0dB when using log or hybrid volume control
* Fixed: [pmp_ipod] Artist list on iPod not sorting "The" correctly
* Updated: [gen_jumpex] Jump-to-File 0.97.5
* Updated: [gen_ff] Freetype 2.2.1
* Updated: [libmp4v2] MPEG4IP mp4v2 1.5
Le changelog que tu viens de mettre est celle de Winamp 5.25 bêta 787.
Faudra un peu plus de précisions (et les liens de téléchargements)
Fixes the following 5.25 specific bugs:
- bad Layer 1 & Layer 2 playback (double speed + distorted)
- slow enqueue/play from media library views
- hiliting of playlist entries for jump-to-file broken
- open playlist from media library broken (in playlist editor)
- saving playlists to PLS format
changelog between build 801 and build 812
warning when selecting 24bit output
fixed: [ml_disc] Play tracks after CD Ripping fix
fixed: [ml_local] bg scan crash when media library DB isn't loaded
fixed: [ml_history] Ctrl+H shortcut
fixed: registry keys created even on unregistered file types
fixed: systray tooltip not showing
fixed: crash on uninstallation
fixed: [in_wm] freeze when stopping streams that have rebuffered
fixed: freeze when exiting Winamp while minimized
fixed: burning with 24bit enabled
fixed: [in_dshow] AVI >2GB fix
fixed: [playlist] PLS loading fix
Fixed: playlist extension registry writing
Fixed: remote playlists nested within a playlist
Fixed: dialog fixes (font change had knocked some things out of whack)
Fixed: xp themed dialogs
Fixed: rogue winamp agent registry Run key
Fixed: [dsp_sps] 24 bit fix
Fixed: [in_dshow] seek to key frame
Fixed: [in_mp3] do Viz after DSP
Fixed: [in_mp3] made genre dropdown bigger again (only effects pre-XP os's)
Fixed: [gen_jumpex] Crash when clicking 'switch to vis/video' button
Fixed: [gen_ml] tree icon fixup (working around an OS bug that was causing CreateDIBSection to sometimes crash (divide-by-zero in ICM32) using V4 bitmap header struct)
Fixed: [ml_local] fix for setting the watch folders extension list
Fixed: [ml_local] fixed crash when trying to create a new view before mldb has loaded
Improved: expanded 24bit warning
Updated: [gen_jumpex] jtfe 0.97.7h (build 57)
build 834 -> build 843
* Fixed: unicode titles for streams (build 834-specific bug)
* Fixed: [in_mp3] icecast utf-8 stream title support
* Fixed: [in_mp3] lame vbr header reading (build 834-specific bug)
* Fixed: [ml_local] crash when deleting files (via watcher) before ml has loaded
* Improved: bumped up gain of spectral analyzer
* Improved: [in_mp4] better sample duration calculation when the decoder is outputting at a different samplerate than specified in the MP4 data
* Improved: [pmp_usb] metadata reading in background, general touch-ups
* Improved: [in_mp3] faster preparation during burning, transcoder support
* New: [in_mp3] replaygain support for MP3 playback (enable in Prefs > Playback)
* New: [ml_rg] replaygain scanner (beta only, for now - access via Send To menu)
* Updated: [enc_lame] LAME 3.97b3
Build 825 -> 834 :
* Fixed: [in_mp4] detection of HE AAC in file info box (Alt+3)
* Fixed: [enc_aacplus] more compatible HE AAC MP4 file creation
* New: "Close Winamp" option after installation (after clicking 'Send')
* Fixed: crash when aacPlusDecoder.w5s isn't present
* Fixed: Sonic Engine install under Win98SE/ME
* Fixed: ReplayGain preamp resets to -6.0 dB (b843-specific)
* Fixed: ReplayGain info not being saved for files with id3v1 tags only (b843-specific)
* Fixed: [in_mp3] %bitrate% & time display in pledit for mp3 streams (5.25-specific)
* Fixed: [in_wm] freeze on seek with right keyboard cursor (5.25-specific)
* Fixed: [ml_disc] auto add ripped files to mldb (5.25-specific)
* Fixed: [ml_rg] crash on unsupported formats (b843-specific)
* Fixed: [ml_rg] Abort button now working (b843-specific)
* Improved: fixes for video plugin detection
* Improved: [in_mp3] minor id3v2.4 tag reading fixes
* Improved: [in_mod] 24bit/surround/stereo options moved to Prefs > Playback
* Improved: [in_mp3] increased streaming info box size
* New: aac/m4a/ogg replaygain support
* New: [in_mp3] aac/mp3 replaygain in alt+3 dialog box
* New: [ml_pmp] auto-transcoding for incompatible formats
* New: [ml_playlists] added 'playlist entry' and 'read extended info' to menus
* Updated: Sonic Burning/Ripping Library (requires reboot)
