Opera 8.50 gratuit
#31
Et hop... La beta RC vient de sortir... en build w8371, m3345 et u240 et voici un récapitulatif des changelogs depuis la précédente build posté ici.
Changelog Changes (w8371, m3345, u240) * Stability fixes. Changes (w8367, m3336, u236) * Stability fixes. * Save directory only reset to Download directory when Download directory is changed. * Fixed viewing messages in GMail. * "Cycle without showing list" now includes also minimized pages. Unix specific * X clipboard fixed. * Fixed RSS stylesheet on Unix. Télécharger Opera 9.0 Beta RC build 8371 (Windows Installer) Télécharger Opera 9.0 Beta RC build 8371 (Windows Classic) Télécharger Opera 9.0 Beta RC build 3345 (MacOS X) Télécharger Opera 9.0 Beta RC build 240 (Unix/Linux) Page de développement d'Opera 9.0
#32
Apparament un beta1 officiel viens de sortir sur le site
est-ce la meme que la RC?
#33
#34
Update:
Windows Classic http://snapshot.opera.com/windows/o90w_8372.exe Windows MSI http://snapshot.opera.com/windows/o90w_8372m.exe Macintosh http://snapshot.opera.com/mac/o90w_3347.dmg Unix http://snapshot.opera.com/unix/Weekly-241/ |
#35
Hop sortie d'une nouvelle weekly (toujours en beta) en build w8393, m3359, u256.
Changelog Widgets UI changes: * Widgets are no longer displayed on a faded screen. * New widgets menu, providing options to add, open, and manage widgets. * New widget management window. Other changes * Fixed handling of multiple changes to document.body.style.backgroundColor. * Fixed behavior of range.compareBoundaryPoints. * document.compatMode now gives 'BackCompat' for documents being rendered in quirks mode. * Improved XSLT error reporting. * Allowed custom headers to be displayed in the quick mail headers toolbar * Fixed some bugs in the MSI installer. * Improved handling of "Stop executing scripts on this page" tickbox on script dialogs. * Support copying attribute nodes in XSLT with copy-of. * Refuse invalid namespace declaration attributes. * User CSS is enabled by default in Author Mode. * Temporary downloads are now cleared when deleting cache. * Improved deleting of single messages from trash in IMAP accounts. * Fix for duplicated messages in IMAP. * Fixed SSL negotiation problem for servers that does not tolerate TLS 1.0 version in the record protocol of the client hello. * Added system tray icon on Unix. Known issues * Opera might fetch some old feed entries double * Opera might not start in some Unix desktop environments when using a menu entry to start Opera: start it from conosle instead. * you need to use a clean toolbar setup to get the widget menu and the widget panel Télécharger Opera 9.0 Bêta build 8393 (Windows Installer) Télécharger Opera 9.0 Bêta build 8393 (Windows Classic) Télécharger Opera 9.0 Bêta build 3359 (MacOS 10.2 et +) Télécharger Opera 9.0 Bêta build 256 (Unix/Linux)
#36
Et hop une Mid-Weekly pour Opera 9 beta qui sort en build w8406, m3375, u272
Changelog * Several display fixes. * Several IMAP fixes. * Added context menu for widget panel. * Added always below for widgets. * Added folders in widget panel. * Fixes for NTLM. * Fixed issue where having installed many many fonts could confuse opera. * Several stability fixes. * Fixed bug with illegal nested tables. * Multitracker support for BT. * BT file hash check saved in meta data file to reduce the need for checking files on resume. * Fixed bugs where opera re-downloads old feeds. * added widget panel into panel customization dialog. * Fix for larger images getting scrambled Unix specific: * Fixed deadkeys in input. * Fixed installation with X.org 7. * Stability fixes with Java applets. Télécharger Opera 9 Bêta build 8406 (Windows Installer) Télécharger Opera 9 Bêta build 8406 (Windows Classic) Télécharger Opera 9 Bêta build 3375 (MacOS X v10.2+) Télécharger Opera 9 Bêta build 272 (Unix/Linux)
#37
Weekly again... w8410, m3379, u376
Changelog * Fixed session handling for widgets. * Fixed bug with creating folders in widget panel. * Fixed wrongly nested tags freezer. Known issue * betanews.com still broken Télécharger Opera 9.0 Bêta build 8410 (Windows Installer) Télécharger Opera 9.0 Bêta build 8410 (Windows Classic) Télécharger Opera 9.0 Bêta build 3379 (MacOS X v10.2+) Télécharger Opera 9.0 Bêta build 376 (Unix/Linux)
#38
j'allais poster
, tu es rapide 1for-matik
#39
Weekly again... w8414, m3385, u284
Changelog * Fixed display on betanews.com. * Cache is not shared between widgets and pages opened from widgets. * Fixed Bittorrent downloads on Unix. * Fixed crash that could occur when exiting pages with Flash 8. * Fixed IPv6 on FreeBSD. Télécharger Opera 9.0 Bêta 2 build 8414 (Windows Installer) Télécharger Opera 9.0 Bêta 2 build 8414 (Windows Classic) Télécharger Opera 9.0 Bêta 2 build 3385 (MacOS X v10.2+) Télécharger Opera 9.0 Bêta 2 build 284 (Unix/Linux)
#40
La Beta 2 est sortie : http://www.opera.com/download/index.dml?ver=9.0b
C'est la même que la 8414. |
#41
oui
c'est la meme
#42
Nouvelle petite weekly
![]() Opera Several IMAP fixes. Several Cookie fixes. Cookie site preferences now override general preferences. Fix for a situation where setting Cookies froze Opera. widget.setPreferenceForKey for Widgets now works. XHTML mobile profile rendering is fixed - fixes for example http://www.google.com/xhtml/ Fix for missing marker on floated list items. Doubleclick to select words now doesn't select punctuation. Opening images in mail by rightclicking image now works. Several content blocker fixes. Better visual feedback in UI for changes that depend on each other. Temporary download directory used for opening files in external applications can now be modified in opera:config.UNIX specific: Now using operapluginwrapper to detect plug-ins. Fixed several crashers related to multiple concurrent login dialogs. Java now not doesn't grab all keyboard input. Téléchargements :- Opera 9.0 build 8432 (Windows Installer) - Opera 9.0 build 8432 (Windows) - Opera 9.0 build 300 (Unix, GNU/Linux) - Opera 9.0 build 3398 (Mac OS)
#43
Nouvelle weekly.... Opera 9.0 en build w8455, m3412, u315
Changelog UI * Bookmarks exported to HTML are now in the Netscape Bookmark File Format, making them compatible with Yahoo bookmarks, Scuttle, MyBookmarks etc. * Further improvements to the new access key interface. Press Shift+Esc to enter access key mode where sites support it, eg http://www.opera.com or http://news.bbc.co.uk. * Multiline edit fields, compose mail and source viewer now have a horizontal scrollbar if needed. * Changing alignment of mail headers now doesn't hide or overlap headers Rendering * Added support for the CONTENTEDITABLE attribute. * Setting table height to 100% now works in quirks mode regardless of height of parent element(s). * Stand-alone images are now centered on the page - image.css is read again. * User set encoding is now window and site specific. * Baseline for CJK characters is now correct. Widgets * window.moveTo and window.resizeTo are now supported, as well as window.close. * Fixed unwarranted security violation errors. Mac specific * IRC DCC file sending now work again. * Fixed some general redraw issues. * Faster font reading during startup. UNIX specific * Ctrl+H now hides Opera to the systray if there is one. * Installation on Sun OSes now work. * No .1 linux packages today, our build machine died (donc pas de build pour Ubuntu Breezy ni Dapper) * And as usual: Several crash fixes. Known issue * Some links on some sites might not be clickable in the Windows build. Télécharger Opera 9.0 Bêta build 8455 (Windows Installer) Télécharger Opera 9.0 Bêta build 8455 (Windows Classic) Télécharger Opera 9.0 Bêta build 3412 (MacOS X 10.2+) Télécharger Opera 9.0 Bêta build 315 (Unix/Linux)
#44
Weekly again... w8460, m3418, u320
Changelog Known issues Changes from last Friday UNIX Télécharger Opera 9.0 build 8460 (Windows Installer) Télécharger Opera 9.0 build 8460 (Windows Classic) Télécharger Opera 9.0 build 3418 (MacOS X v10.2+) Télécharger Opera 9.0 build 320 (Unix/Linux)
#45
Again... build w8473, m3428, u328
Changelog Known issues * Searches are broken. * No FreeBSD 6 packages, and no .rpm or .deb packages available this time. Sorry… and then, on the brighter side, read the Changelog * Middleclick features (Paste'n'Go and Panning) are fixed. * Opening standalone files that require plugins are fixed. * opera: and mailto: links now work again. * Animated gif images no longer speed up! (Wheeee!!) * Completed support DOM level 2 CSS. * Added support for DOM level 2 Style Sheets. (Yay!!) * Improved handling of offsetTop, offsetLeft and offsetParent. * When enabling the status bar, link and form tooltips will not show the URL address anymore, and will display the content of the title attribute without the "Title: " prefix. * Multiple stability fixes. * IMAP fixes. * several NTLM fixes. Télécharger Opera 9.0 Bêta build 8473 (Windows Installer) Télécharger Opera 9.0 Bêta build 8473 (Windows Classic) Télécharger Opera 9.0 Bêta build 3428 (MacOS 10.2+) Télécharger Opera 9.0 Bêta build 328 (Linux/FreeBSD)
| Opera 7.52 | Mytheuzen | Vos news | 0 | 07-07-2004 19:57 |
| Opera 7.51 Final | Steven | Vos news | 5 | 03-06-2004 21:39 |
| Re Opera 7.11b en Français | nantesph | Logiciels | 1 | 28-05-2003 12:23 |
| Opera 7.1 finale est sortie | streets | Logiciels | 4 | 12-04-2003 23:53 |
| opera 7.02 fr | qkd | Logiciels | 15 | 14-03-2003 22:03 |
Several IMAP fixes.
