Communauté Informatique NDFR.net : WinAce 2.6 - Actualité
WinAce 2.6
Old 20-08-2005, 20:14
WinAce 2.6
Lien direct de la news : WinAce 2.6
Après plus de 8 mois de test et 5 versions beta, la version finale de WinAce 2.6 est enfin disponible.
Ce logiciel de compression/décompression d'archives reste moins connu que ses deux "confrères" que sont WinZip et WinRar mais reste relativement performant.
Voici un aperçu des caractéristiques de WinAce (en anglais) :
WinAce features
WinAce is not just another archiving shell. With it's own powerful compression format ACE and built-in support for other popular compression types like ZIP, RAR and MS-CAB (to name a few), WinAce could actually become the only archiver you need.
The feature list of WinAce includes:
* compression of the following formats: ACE, ZIP, LHA, MS-CAB, JAVA JAR
* decompression of: ACE, ZIP, LHA, MS-CAB, RAR, ARC, ARJ, GZip, TAR, ZOO, JAR
* multi-volume (disk spanning) archives for ACE, ZIP, CAB
* self-extracting archives (SFX) for ACE and ZIP
* password encryption & recovery records for data protection
* Integrity check for ACE, ZIP, LHA, MS-CAB, RAR, ARC, ARJ, GZip, TAR, ZOO, JAR
* Repair functionality for ACE and ZIP archives
* Authenticity verification for ACE archives
* comment files in HTML, ANSI or ASCII for ACE- and ZIP-Archives
* full command line access (compatible with DOS ACE)
* detailed information for all archive types
* Quickviewer for graphic files, Word Documents, HTML pages and ASCII files
* full drag&drop support
* complete file-management (copying, moving and deleting of files and directories)
* optimization of existing archives
* access to your archives in Windows Explorer and via the context menu (shell extension)
* table of contents in the "Properties" panel of ACE and ZIP files (shell extension)
* ... and so much more!
Site de WinAce : ici
Téléchargement : ici, ici et
Old 20-08-2005, 20:21
Ce serait sympa de mettre le changelog dans une autre couleur que le blanc mustang
Old 20-08-2005, 20:26
D'abord c'est pas le changelog, mais la liste de ce que fait le logiciel.
Ensuite un petit souci lorsqu'en édition on veut modifier la mise en page, ça m'a bloqué 4 fois de suite la page. Et donc obligé de redémarrer le navigateur, ce qui prend du temps. Et paf une remarque désobligeante
@ Benjy :
Est-ce normal ? J'ai eu ce problème en voulu newser la version 2.2 d'Everest vendredi midi, et du coup, j'ai abandonné cette news (qui a été reprose par LeMoi un peu plus tard).
Old 20-08-2005, 20:31
Editeur HTML ? Editeur BBCode ?
... j'ai abandonné cette news (qui a été reprose par LeMoi un peu plus tard).
Faux... Par Moi, pas LeMoi
Sinon ça me désole de voir que l'interface est toujours aussi... aussi... bof.
Commence un peu à faire tache à coté de WinRAR et WinZIP.
Old 20-08-2005, 20:48
Editeur de message du forum tout simplement. Pas le droit au HTML.
Originally Posted by 1for-matik
Citation: (Originellement posté par mustang89)... j'ai abandonné cette news (qui a été reprise par LeMoi un peu plus tard).
Désolé : Je corrige : j'ai abandonné cette news (qui a été reprise par Lui un peu plus tard)
Old 20-08-2005, 21:22
Ah bah non... ça m'aide pas...
Editeur Avancé : Intégration des codes HTML et blabla... bref Editeur HTML-like
Editeur basique : Tappage des BBcodes à la main avec une barre d'outil moins sophistiquée que celle de l'avancée (normal...)
Old 21-08-2005, 13:04
Mêmes remarques mais dans tous les cas : non, ce n'est pas "normal" de ne pas arriver à éditer un message.
Old 21-08-2005, 13:11
cirvent's Avatar
cirvent cirvent is offline
Send a message via ICQ to cirvent Send a message via AIM to cirvent Send a message via MSN to cirvent Send a message via Yahoo to cirvent
re
salut,
existe t-il un patch Fr pour winace 2.6 final ???
cirvent
Les Hommes naissent libres et égaux en droit.
Après, ils se démerdent .
Jean Yanne
Old 21-08-2005, 13:13
J'arrive bien à éditer mon message, à le modifier, mais parfois il ne veut plus valider la réponse. Ce qui a été le cas pour cette news.
Peut-être est-ce à cause du copier-coller de la page d'origine ?
Non pas encore. A suivre sur le site de Winace. Pour info le patch Fr 2.5 ne fonctionne pas avec la version 2.6.
Old 21-08-2005, 15:47
Je me sens obligé une fois de plus d'activer mon mode...
[tRoLl]
Utilisez IZarc, il supporte plus de formats, fait de la compression 7-Zip et il est gratuit
Site officiel
Site fr
[/TrOlL]
Bon, j'avoue, l'interface est encore plus moche que les autres, mais moi j'm'en fous
Old 21-08-2005, 16:47
Originally Posted by cirvent
salut,
cirvent
j'ai cru comprendre que Benjy était dans une phase de fainéantise
Old 21-08-2005, 17:35
Je pense juste arrêter les traductions en général, faute de temps... :rolleyes:
Old 22-08-2005, 02:11
wuub's Avatar
wuub wuub is offline
Je dirais pas que c'est moche... c'est sommaire et puis il est skinnable, non ?
Parcontre l'arborescence des répertoires archivés est quand même un plus que WinRar devrait s'offrir.
Old 28-08-2005, 17:11
Version 2.60
Added support for the extended Zip64 format. The file size of ZIP archives and the files contained in ZIP archives may now exceed 4GB. The number of files in a Zip64 archive is no longer limited to 65535 files.
Added compatibility to the new WinZip multivolume ZIP archives. ZIP multivolumes created with previous versions of WinAce are still compatible with WinAce.
Added support for AES password encryption in ZIP files. Encryption level (AES, Basic ZIP encryption) can be set optionally.
Taskbar (Ctrl+K) set to match Windows XP style.
Added "Pause"-Button to the progress window. WinAce can be set to "Pause" during extraction or compression in order to minimize CPU usage, if required.
Added new default icons for SFX files created with WinAce.
Path display mode in the address bar can now be set to show the full directory path.
It is now possible to encrypt multiple ace archives with a password in one go.
Added new encryption command for uncompressed files ("Encrypt/Encode" in the "File" menu)
* Fast and secure encryption of uncompressed files. Select from eight different encryption methods
In addition, the file names can be scrambled as well in order to disguise the file type and tell tale file names.
Files encrypted with WinAce bear the extension ".xef" and can be opened directly in WinAce.
* added full support for UUEncode, XXEncode and Base64 (*.uue, *.xxe, *.mim)
Added "volume.ini" control file in order to allow users to store customized multivolume sizes.
Manually entered volume sizes may now exceed 2GB.
Manually entered volume sizes will now be parsed and displayed correctly.
Added support for excluding files from compression when using the command line.
-x{files/@list}
Example
winace.exe a -x*.zip;*.ace;*.exe*.c?? test.ace *.*
or
winace.exe a -x@exclude.lst test.ace *.*
where exclude.lst contains a list of files (separated by line breaks) to be excluded from the compression
Customized icon bars can now be saved in a single set.
Added Antivir Personal to the list of supported Antivirus tools.
Added the new parameter vc - for "virus check" (>winace vc archive.ace)
Checking for viruses and testing archives can now be applied to more than one archive at a time
Added new items to the context menu: Encrypt, Check archive(s) for viruses, Test archive(s)
Added a new option to open target directories automatically after the extraction process
Fixed problems with handling GZip archives.
The option to seal archives will not be stored correctly in project files.
Fixed an occasional problem that occured when archives were analysed.
Fixed problems with certain ISO image files.
Sfx options are now stored and read correctly from project files.
Improved parsing for manually entered volume sizes.
The password dialog window will now longer pop up when using WinAce in commandline mode.
Archive files will now be checked for the correct archive type - there has been a problem when archives had incorrect or misleading file extensions.
Fixed a problem with the shell integration for filenames with more than 220 characters.
Passwords stored in project files are now encrypted.
Fixed an error that occured when archives were updated according to their file date.
Old 12-03-2006, 16:26
WinACE 2.61 du 08 mars 2006
The new version fixes a possible exploit concerning a buffer overflow in maliciously manipulated ARJ-Archives.
WinAce 2.6x contains several GUI fixes and improvements and updates for other compression formats.
WinAce now supports the "Zip64" format, which will break the 4 GB barrier for ZIP files.
Et non, le développement n'est pas mort
WinAce 2.6 Beta 3 + Patch FR Benjy Actualité 3 03-03-2005 21:45
WinACE Archiver 2.60 Bêta 4 en Anglais nantesph Vos news 3 17-12-2004 11:28
WinACE Archiver 2.60 Bêta 2 en Anglais nantesph Logiciels 10 12-10-2004 19:12
WinACE 2.3 Beta 2 Werner Actualité 12 16-11-2002 08:30
WinAce 2.3 beta 3 Benjy Actualité 4 14-11-2002 20:16
