Communauté Informatique NDFR.net : BSplayer 1.2 Build 815 et BSplayer Pro 1.2 - Actualité
Old 23-02-2005, 23:44
Steven's Avatar
Steven Steven is offline
Ex-Boulet
Voici la toute dernière version du célèbre lecteur multimédia, BSPlayer.
BSPlayer est un lecteur multimédia universel permettant de lire la plupart des formats video/audio. Entre autres fonctions il permet des réglages video, audio, sur les sous-titres, de faire des captures, de gérer des signets, etc.
Les changements de la version gratuite
pan scan settings are now remembered
fixed some problems with file association
fixed bug in skin engine, some skins were not properly loaded
fixed -nsub command line option, was working properly only for current file
fixed some problems with subtitles, last line was still visible in some cases after subtitles were turned off
some changes in subtitle loading, added more strict checking, so subtitle for another movie shouldn't be loaded anymore
some other bug fixes and internal changes
added more friendly interface to bspfilters.dat and improved filter management a lot, it's now possible to define black list (filters in black list won't loaded), white list (only filters in white list will be used), VSFilter and similar filters will now be loaded (optional), it's also possible to define which filter will be used for playing specified media type, you can also register, unregister filters and set merit from BSplayer
added support for Audio CDs and CDDB
added option to set default audio stream, by index and iso-6392 language code (language code only for mkv files)
added option to define more subtitle paths, path can also be relative (ex. '..\subtitles')
added option to set default subtitle, by index and iso-6392 language code (language code only for mkv files)
added option to set default audio stream for every item in playlist
Les changements supplémentaires de la version pro
network buffer for mkv files was always enabled, fixed
improved support for tuner devices, added channel list and channel scan, you can also set channel names, channel list is integrated in playlist
Télécharger BSplayer 1.2 Build 815 ou BSplayer Pro 1.2
Site officiel : BSplayer
Source : FileForum
Old 09-03-2005, 20:40
Bonne/Mauvaise nouvelle ?
Originally Posted by BsPlayer
Today, 8:00 GMT CET BSPlayer.org and all it's products have been acquired by CodeCodec Inc.
BSPlayer will now be named TCMP5 ("The Core Media Player 5"). Thanks to CoreCodec leader, Ludovic Vialle ("BlackSun") for signing the papers. We hope this acquisition can be for the best of all, and we look forward to acquiring new competition products as soon as possible.
All users who bought a license for BSPlayer will have to buy it again, this time with extra taxes due to CoreCodec's policies. Licenses will be around 75 euros PER YEAR, and will renew automatically. Thanks for understanding.
Our main focus will be bringing our paid customers latest technologies, so they can enjoy a player like TCMP5 will be.
http://forum.bsplayer.org/viewtopic.php?t=6426
Old 09-03-2005, 22:03
Oulà, ça sent pas bon ça, le seul qui pouvait rivaliser avec MPC devient douteux, bon ben , c'est décidé, mon HDD sera MPC only...
Steven's Avatar
Ex-Boulet
tu aurais pu traduire LeMoi !!! pense à ceux qui ne savent pas lire l'anglais (moi ce n'est pas mon cas )
Old 09-03-2005, 22:06
Puisque c'est pas ton cas et que tu te proposes si gentiment, nous attendons la traduction ...
Old 09-03-2005, 22:07
en gros The Core Media Player vient d'acquérir BSplayer et BSplayer deviendra donc TCMP 5
et tout ceux qui ont acheté une licence devront en racheter une autre.
Info ou intox ?
Old 09-03-2005, 23:36
Info ou intox ?
euh, si c'est l'admin du forum de bsplayer qui le dit, et vu qu'on est pas le 1er avril, c'est surement une intox ^^.
De toutes façons la version payante de TCMP (du moins jusqu'a présent) n'avait comme avantage que la lecture des DVD.
Old 21-06-2005, 20:38
Bon en attendant BSPlayer a quand même été mis à jour (de plus le topic semble avoir disparu sur leur forum???) :
Version 1.30 (build 818), Pro et free :
partial support for Unicode file names
some changes to be more compatible with new DivX 6 Media Format, no direct support for menus and other features yet
added option to add all files in current directory to playlist, so when one file is opened all files will be added to playlist and you can quickly view next or previous with 'Next' and 'Previous' shortcuts
files that are still recording or downloading will now be reopened at the end, so playback will continue
some other bug fixes and changes
Pro :
added simple teletext viewer
some bug fixes with TV tuner and capture
http://www.bsplayer.org/index.php?p=download
Old 23-06-2005, 21:37
version 1.31 (b819)
fixed bug in 'advanced graph building mode', player crashed if DivX 6 was installed and 'Support decoding of Generic MPEG-4 video' in DivX decoder was disabled
version 1.32 (b820)
Même lien
Old 13-12-2005, 20:44
Version 1.37 du 11/12/2005
support for utf8 encoding in external ssa subtitles
VobSub subtitles can now be moved, like normal ones
some VobSub subtitles were not displayed, fixed
mp3 shoutcast fixes, some streams didn't work
some fixes with tuner/capture, wrong name displayed after capture etc...
Added 'always on top' option for control window
fixed problem with desktop mode when icons were hidden
pan scan was not remembered properly, fixed
BSPlayer 1.01 build 811 LeMoi Actualité 4 15-09-2004 00:37
BSPlayer 1.00 RC1 build 808 LeMoi Actualité 8 29-04-2004 21:34
BSPlayer 1.00 RC1 build 803 LeMoi Actualité 20 22-02-2004 23:17
BSPlayer 1.00 RC1 build 800 LeMoi Actualité 11 12-11-2003 12:14
