BSPlayer est un lecteur multimédia universel permettant de lire la plupart des formats video/audio. Entre autres fonctions il permet des réglages video, audio, sur les sous-titres, de faire des captures, de gérer des signets, etc.
Les changements de la version gratuite
pan scan settings are now remembered
fixed some problems with file association
fixed bug in skin engine, some skins were not properly loaded
fixed -nsub command line option, was working properly only for current file
fixed some problems with subtitles, last line was still visible in some cases after subtitles were turned off
some changes in subtitle loading, added more strict checking, so subtitle for another movie shouldn't be loaded anymore
some other bug fixes and internal changes
added more friendly interface to bspfilters.dat and improved filter management a lot, it's now possible to define black list (filters in black list won't loaded), white list (only filters in white list will be used), VSFilter and similar filters will now be loaded (optional), it's also possible to define which filter will be used for playing specified media type, you can also register, unregister filters and set merit from BSplayer
added support for Audio CDs and CDDB
added option to set default audio stream, by index and iso-6392 language code (language code only for mkv files)
added option to define more subtitle paths, path can also be relative (ex. '..\subtitles')
added option to set default subtitle, by index and iso-6392 language code (language code only for mkv files)
added option to set default audio stream for every item in playlist
added option to set default audio stream for every item in playlistLes changements supplémentaires de la version pro
network buffer for mkv files was always enabled, fixed
improved support for tuner devices, added channel list and channel scan, you can also set channel names, channel list is integrated in playlist
Télécharger BSplayer 1.2 Build 815 ou BSplayer Pro 1.2
Site officiel : BSplayer
Source : FileForum
9 commentaires pour “BSplayer 1.2 Build 815 et BSplayer Pro 1.2”
BSPlayer will now be named TCMP5 ("The Core Media Player 5"). Thanks to CoreCodec leader, Ludovic Vialle ("BlackSun") for signing the papers. We hope this acquisition can be for the best of all, and we look forward to acquiring new competition products as soon as possible.
All users who bought a license for BSPlayer will have to buy it again, this time with extra taxes due to CoreCodec's policies. Licenses will be around 75 euros PER YEAR, and will renew automatically. Thanks for understanding.
Our main focus will be bringing our paid customers latest technologies, so they can enjoy a player like TCMP5 will be.
et tout ceux qui ont acheté une licence devront en racheter une autre.
Info ou intox ?
Info ou intox ?
De toutes façons la version payante de TCMP (du moins jusqu'a présent) n'avait comme avantage que la lecture des DVD.
http://www.bsplayer.org/index.php?p=download
fixed bug in 'advanced graph building mode', player crashed if DivX 6 was installed and 'Support decoding of Generic MPEG-4 video' in DivX decoder was disabled
Même lien
