XviD 1.0.2
#16
Changes since 1.0.2: * xvidcore - Fixed trellis optimization overflow for quant <= 2. - Don't read too short streams. This prevents from reading useless stream garbage. - Fixed 64 bit crashes because of addressing assuming 32bit integers. (Andre Werthman) - Fixed 2 diamond search bugs (one was causing searches in wrong directions, the other one was causing an early exit) * VFW frontend - Better stride calculation * DShow frontend - Better stride calculation pas de version compilée par Koepi pour l'instant http://www.xvid.org/downloads.html
#17
Hop, la version de Koepi est disponible : http://www.koepi.org/XviD-1.0.3-20122004.exe (621 Ko)
#18
Marchi
!Dis-moi LeMoi, c'était pas toi qui m'a dit "A mort le XviD" et tu le newses
#19
Bah il faut bien tenir les gens au courant
#20
Profitons-en pour signaler la sortie de Gordiank Knot 0.33
Changelog de la version 0.33 added DTS muxing support Default chapter dir is the same as input D2V file now OGG quality setting is changed to nominal bitrate DivX's connection to the internet is disabled to avoid crashes of GK all applications and filters updated with latest versions added ogg libraries to BeSweet package and lame_enc.dll updated to 3.96.1 some language translations are updated Smart bob deinterlacer produces original frame rate instead of double one Added Robot4Rip back into the pack*Some other unknown bugs fixed* site officiel : http://gordianknot.sourceforge.net/ téléchargement : http://sourceforge.net/project/showf...ckage_id=78323
#21
Xvid 1.1.0 en beta
Une version bêta du Xvid 1.1.0 est sortie.
changelog - {core}: Rate-Distortion mode decision for bvops. - {core}: Two new postprocessing functions, brightness and deringing. - {core}: VBV support in 2pass mode - {core}: Overal encoder speedup, especially for b-frames and all vhq modes. - {core}: Overal speedup of the decoder, merging decoding steps together in order to save significant memory bandwidth, enabled mmx qpel support that was misteriously disabled in 1.0.x. All optimizations could lead to a 25% speedup, and something closer to 12% in average. - {core}: Fixes to the CBR/ABR rate controller, it should work much better with bvops now. - {core}: Fix to the 2pass2 code that could cause doubling the overflow. - {dshow}: Support for brightness control. - {vfw}: Many small improvements. Télécharger Xvid 1.1.0 bêta 1 (compilée par Koepi) Source : Betanews.com
| Pb lecture de xvid avec bsplayer | LeMoi | Logiciels | 1 | 02-01-2006 08:40 |
| XviD 1.0.1 | LeMoi | Actualité | 0 | 07-06-2004 10:32 |
| XviD 1.0 (la version finale, quoi !) | LeMoi | Actualité | 6 | 17-05-2004 20:08 |
| XviD 1.0.0 RC4 | LeMoi | Actualité | 2 | 05-04-2004 19:16 |
| K-Lite Codec Pack 2.10 | Benjy | Actualité | 9 | 26-10-2003 18:50 |
Source :
