Communauté Informatique NDFR.net : Winamp 5.04 - Actualité
Winamp 5.04
Old 28-07-2004, 09:42
Toitoine's Avatar
Toitoine Toitoine is offline
Samouraï...pas le dernier
Winamp 5.04
Lien direct de la news : Winamp 5.04
Le célèbre lecteur audio et vidéo Winamp vient de sortir en version 5.04. Grâce à Winamp, vous pourrez lire toutes sortes de fichiers audio et vidéo. Ce player est habillable à souhait et possède un excellent système de plug-ins...
Notez que cette version n'est pas encore annoncée sur le site officiel.
Changelog
- JTFE v0.96
- Added Coding Technologies' AACPlus decoder
- Fixed deletion of temporary generated WAV files after a burning process on some computers
- Fixed typo in some context menu shortcuts
- Fixed slowness IPC bug caused by gen_hotkeys
- Added "clear" button in internet radio/tv views
- Added screenshots of classic/modern mode in installer
- Fixed MP3 bitrate calculation (in_mp3 was reporting incorrect lengths on some MP3s)
- Fixed incorrect length reporting on long WMA files
- Better fix for pledit/video windows showing up at startup when minimized
- Fixed db text bug when moving EQ sliders
- Upgraded MP3 encoding to LAME v3.96
- Fixed crash in WMA playback when using WMA v8 codecs
- Updated default streaming values in in_nsv
- Added Winamp.com Audio&Video views in the Media Library
- Fixed tiny memory leak in in_cdda
- Added right click context menu on "Now Playing" item in Media Library
- Added script/ActiveX disabling for Media Library's minibrowser (on by default)
- Fixed memory leak on MP3 files with messed up ID3v2 tags
- Fixed visualization when playing CD tracks
- Fixed proxy user : pass @ server : port string getting cut when playing Shoutcast streams
- Made in_dshow not to handle mms:// streams ending with .wma
- Fixed %tracknumber% tag for CD tracks
- Fixed some crash bugs in in_mp4
- Fixed playlist generation when ripping full CDs
- Added "import playlist from folder" in Media Library
- Updated Media Library preferences screens
- Added new SPS presets from Cockos, Inc. (pitch shifters, etc)
- Added basic streaming (download) support for M4A/MP4 HTTP streams
- Added monitoring of fullscreen apps, disables always on top temporarilly
- Added IPC_IS_WNDSHADE
- Added gen_ml rating ipcs
- Added ratings from playlist context menu (acts on selected entries)
- Added ratings from song ticker context menu (acts on current track)
- Added rating hotkeys in gen_hotkey
- Fixed saving read-only playlists
- Fixed double separator lines in gen_ml id3less item context menu
- Fixed refresh of view losing query after removing dead files & background scan
- Added escaping of ", ', [ and ] in ml queries : uses %HH where HH is the hex char code (uses %% for '%')
- Added sdk support for multiple audio/video tracks in video input plugins (see wa_ipc.h for ITrackSelector class)
- Added multiple audio avi support (right click video window, select "Audio Tracks")
- Fixed multimonitor problem when toggling a windowshade on one monitor while playing a fullscreen video on the other
- Added ML_IPC_EDITQUERY and ML_IPC_EDITVIEW
- Fixed pledit drawing bug under winxp/cleartype
- Fixed crash in id3 reading of zero byte files
- Fixed crash in sps when exiting winamp before closing the open/save dialog
- Added IPC_PUSH_DISABLE_EXIT, IPC_POP_DISABLE_EXIT and IPC_IS_EXIT_ENABLED
- Fixed gen_ml crash when inserting item with length -1
- Made gen_ml much more resistant to databases that have been corrupted
- Fixed ml nuke
- Added disabling of "keep on screen" option when going into a different resolution because of a fullscreen application (ie: a game)
- Made ui : preferences global hotkey open the prefs to the previously opened page
- Fixed a few preferences cosmetic 'bugs'
- Modern skin updates
Télécharger Winamp Lite 5.04 (735 Ko)
Télécharger Winamp Full 5.04 (4,35 Mo)
Télécharger Winamp Pro 5.04 (4,35 Mo)
Télécharger le patch FR (1,42 Mo)
Source : MajorGeeks
Old 28-07-2004, 18:44
Super les 2 nouvelles rubriques dans la librairie!
Je parle de "Winamp.com Music" et de "Winamp.com Videos" qui propose plus de 1500 streams de chansons entière disponible pour 2 sortes de bandes passante!
Ainsi qu'une réapparition de certaines fonctions disparue dans Winamp 5.01.
Chouette
Old 29-07-2004, 00:32
gelflings gelflings is offline
Ainsi qu'une réapparition de certaines fonctions disparue dans Winamp 5.01>>Ah bon lesquelles ?
Old 29-07-2004, 00:55
Bah elles sont p'tites et principalement visuelles
Bon bref
Old 29-07-2004, 00:59
Tu veux dire que Winamp gère a nouveau la webcam et qu'on peut donc vrombüler de la ficelle en rythme et le montrer a tout le monde ?
Old 29-07-2004, 01:03
En quelques sorte... Si j'arrive à filmer mon slip et à le balancer en stream (cf. le topic d'office 2003 SP1) je serai content
Old 29-07-2004, 01:05
Tu aura slip streamé et strip filmé c'est ce qu'on appelle le sleeping...
(ce que les survivors ne font pas assez)
Old 29-07-2004, 01:07
Mdrrrrrrrrr Samva
C'est la fête du slip (stream) que veux tu de plus
Old 29-07-2004, 01:11
Bon trève de HS, j'ai trouvé a l'execution que Winamp 5.04 était plus rapide que son prédécesseur, simple remarque eronnée de ma part ou réelle rapidité ?
Old 29-07-2004, 01:17
Réelle rapidité... Ils l'avaient annoncé cette petite prise d'adrénaline... Enfin j'ai vu ça sur l'autre site à Veekee et Cie.
Old 29-07-2004, 01:47
Gargamelch's Avatar
The Smiling Penguin
Je dirais même que la 5.04 Lite est la digne héritière de la 2.91
Faible conso de mémoire et temps processeur minime, ça a pas l'air mal
Old 29-07-2004, 01:58
Bah adopte alors
Old 29-07-2004, 09:32
1formatik >> Bah elles sont p'tites et principalement visuelles >> dont c t'en sais rien ou quoi
PS un visuel trainait sur les ressources mémoires de WMP, winamp, itunes et autres lecteurs
problème visualiseurs sur Winamp 5.04 Yttrium889 Logiciels 4 26-08-2004 20:39
Winamp 5.04 zoorin Logiciels 7 20-08-2004 22:34
Après la RC2 la RC8 de WinAMP 5 Werner Actualité 8 21-11-2003 18:00
Winamp 5 beta 2 streets Actualité 0 29-10-2003 00:42
WinAmp 2.90 Beta & WinAMP 3 Build 498 Werner Actualité 16 03-04-2003 04:02
