Au menu des nouveautés : l'intégration avec Windows Vista, de nouvelles fonctions et des corrections de bugs.
Changes in Version 3.70 Beta 1, 10 January 2007:
1. Numerous Windows Vista compatibility changes:
a) help format changed from old HLP to newer HTML based CHM;
b) GUI self-extracting modules attempt to request for administrator permissions if they cannot create destination folder under current user account;
c) Log file rar.log and WinRAR theme files are stored in %APPDATA%\WinRAR folder instead of WinRAR program files folder.
Exported settings file settings.reg is also stored in %APPDATA%\WinRAR folder by default, but it is possible to select another folder in "Save WinRAR settings" and "Load WinRAR settings" dialogs.
WinRAR searches for registration key and settings.reg both in its program files folder and in %APPDATA%\WinRAR;
d) Vista compatibility changes in WinRAR shell integration.
2. Added support for ISO 13346 (UDF) file format. This format is frequently used in ISO images of DVD disks.
3. Added Unicode support for ISO 9660 files, so WinRAR should handle non-English file names in .iso files better.
4. Design changes in window displaying archiving and extraction progress:
a) it provides more space for file names, allowing lengthy names;
b) it displays the current archive name in separate line, allowing much longer archive names than before;
c) when archiving, it displays the current comression ratio in separate line;
d) it can use both standard Windows and classic WinRAR progress bars. Turn on "Windows progress bars" option in WinRAR "Settings/General" dialog to use standard progress bars. By default this option is on if some Windows visual style is active and off if Windows Classic theme is selected.
Windows progress bars are two color only, so they do not indicate the current compression ratio. But now the ratio is displayed in separate line;
e) "Mode..." button moved to bottom of window.
5. GUI self-extracting modules support following command line switches:
-d set the destination path
-p specify a password
-s silent mode, hide all
-s1 same as -s
-s2 silent mode, hide start dialog
-sp specify parameters for setup program
6. GUI self-extracting modules do not pass the entire command line to setup program like they did in previous versions. If you need to get access to entire command line of SFX archive, parse sfxcmd environment variable which contains this command line.
7. New switch -sc[objects] allowing to select character sets for archive comments and list files. It replaces -fcu switch introduced in RAR 3.60, which was removed from list of supported switches. Now you need to specify -scuc instead of -fcu to use Unicode comments. Unlike -fcu, -sc also supports OEM and ANSI charset.
8. New "Save archive copy as..." command in "File" menu. This command may be useful if you opened an archive from Internet directly in WinRAR and then decided to save it on local disk.
9. "Word wrap" command added to "View" menu of WinRAR internal viewer, so you can change the wrapping mode of already opened viewer window.
State of this option is not stored between viewing sessions. If you need to change the default word wrap mode, use WinRAR "Settings/Viewer" dialog.
10. Buttons "Up" and "Down" added to "Organize profiles" dialog. Using these buttons you can change position of selected profile in the list.
11. Operation progress is displayed when adding the recovery record.
12. If WinRAR is minimized to tray and mouse is over its icon, WinRAR diplays a message about the current operation progress. In previous versions it included only percent done, now it also contains the time left information.
13. Console RAR displays "Calculating the control sum" message when calculating CRC32 control sum for newly created RAR volume. Previous versions also calculated the volume control sum, but did it silently.
14. Archives history list in "File" menu allows Unicode names, providing more reliable support for non-English archive names.
15. Stack overflow vulnerability has been corrected in password processing module of console RAR and UnRAR. GUI WinRAR is not affected. We are thankful to the iDEFENSE LABS for reporting this bug.
Pour l'instant disponible uniquement en anglais, elle peut être téléchargée avec le lien suivant :1. Numerous Windows Vista compatibility changes:
-s1 same as -s
Télécharger WinRAR 3.70 Bêta 1 (1,13 Mo, anglais)
3 commentaires pour “WinRAR 3.70 Bêta”
Bêta 3 :
1. It is possible to set the string value "AppData" in Registry key HKEY_CURRENT_USERSoftwareWinRARPaths to override the default %appdata%WinRAR path for WinRAR settings. For example, if you wish to store theme files in WinRAR folder,set this value to "c:Program FilesWinRAR".
2. Total progress bar is displayed when unpacking UDF ISO files.
3. In previous versions archive icons were not changed when selecting a new WinRAR theme in Windows Vista.
4. WinRAR displays a warning if resulting archive is self-extracting and archive size exceeds 4 GB. Windows cannot run executables of such size.
5. Corrections in ISO processing code.
Bêta 2 :
* Positions of "Mode" and "Cancel" buttons in archiving dialog have been exchanged
* Fixed: Beta 1 could truncate names of files decompressed from ISO 9660 archives by one character
* Fixed: Progress bars in archive conversion window did not work correctly with "Windows progress bars" option turned on
* Fixed: "Load WinRAR settings from" dialog did not display if settings.reg was not present in %appdata%\WinRAR folder
settings" dialogs.
HKEY_CURRENT_USER\Software\WinRAR\Paths to override the default
%appdata%\WinRAR path for WinRAR settings.
set this value to "c:\Program Files\WinRAR".
d) Vista compatibility changes in WinRAR shell integration;
e) New "Request administrative access" option in "Advanced" page
of "Advanced SFX options" allows to create SFX archive,
which will request the administrative access when started
in Windows Vista.
Command line equivalent of this option is -iadm switch.
progress:
c) when archiving, it displays the current compression ratio
in separate line;
theme is selected.
in separate line;
switches:
-d<path> set the destination path
-p<pwd> specify a password
-s1 same as -s
-sp<par> specify parameters for setup program
7. New switch -sc<charset>[objects] allowing to select character
in the list.
