PHP 4.3.11
Changelog de la version 4.3.11
Added Oracle Instant Client support
Added checks for negative values to gmp_sqrt(), gmp_powm(), gmp_sqrtrem() and gmp_fact() to prevent SIGFPE
Changed phpize not to require libtool
Updated bundled libmbfl library (used for multibyte functions)
Fixed several leaks in ext/browscap and sapi/embed
Fixed several leaks in ext/filepro
Fixed build system to always use bundled libtool files
Fixed MacOSX shared extensions crashing on Apache startup
La suite ici
Fixed MacOSX shared extensions crashing on Apache startup La suite ici
Télécharger PHP 4.3.11PHP 5.0.4
Changelog de la version 5.0.4
Added SNMPv2 support. (harrie)
Added Oracle Instant Client support. (cjbj at hotmail dot com, Tony)
Added length and charsetnr for field array and object in mysqli. (Georg)
Added checks for negative values to gmp_sqrt(), gmp_powm(), gmp_sqrtrem() and gmp_fact() to prevent SIGFPE. (Tony)
Changed foreach() to throw an exception if IteratorAggregate::getIterator() does not return an Iterator. (Marcus)
Changed phpize not to require libtool. (Jani)
Updated bundled oniguruma library (used for multibyte regular expression) to 3.7.0. (Moriyoshi)
La suite ici
Updated bundled oniguruma library (used for multibyte regular expression) to 3.7.0. (Moriyoshi)La suite ici
Télécharger PHP 5.0.4
Site Officiel
Source: Fileforum.com
