Les nouveautés sont nombreusex, mais elles ne sont que mineures pour l'instant, car Patchou travaille déjà sur une version 5.0 qui offrira une interface mieux travaillée et cohabitera mieux avec les patchs de personnalisation tels que A-Patch ou MessPatch.
La version 4.80 offre des améliorations, dans la gestion et la création des skins pour Windows Live Messenger.
Voici le changelog assez long pour tout connaître des changements de cette version :
Messenger Plus! Live 4.80.356 (31/01/2009)
* This version is entirely compatible with the final version of Windows Live Messenger 2009 (build 1202). Yes, that includes chat logging, emotion sounds, skins, scripts and so on
o The "Show contacts as Idle" option will properly display "Idle" for your contacts' status in chat windows but not in the contact list. For that reason, an "(Idle)" indicator has been added in the contact list's tooltip (Messenger 9 only).
o The Messenger Plus! menus displayed by buttons added in the windows of Messenger are more properly aligned.
o Skins: when a skin that redefines the shape of a window in Messenger is loaded in Messenger 9, the window frame present in Vista is properly removed.
o Skins: vertical gradient colors cannot be created for Messenger 9, only horizontal gradients are supported.
* The new UIB encoded version of the windows' styles and definitions is completely supported by Messenger Plus!.
o For skinners, this means that Messenger Plus! will decode the files automatically when extracting the resources and will re-encode them automatically when added in a skin. For everybody else, it means Messenger Plus! will still rock in 2009!
o Notes about UIB decoding: in order to make things as simple as possible for the skin developers, Messenger Plus! generates definition files and style files almost identical to what you used to see in Messenger before. One of the differences you'll notice is a <*PlusSkin*/> tag on top of each file: do not remove it or alter it.
o Skins: if you used to write some strange exotic syntax in your windows' files which was previously accepted and parsed by Messenger, Messenger Plus! may not be so tolerant. The opposite is also true as Messenger Plus! may accept things that Messenger did not (like character escaping in strings such as "\n"). In the end, most developers won't ever notice a difference though.
o Skins: Windows Definition files and Windows Styles files can still be included separately in your skins. If one of the two files is missing, Messenger Plus! will decode the internal UIB file in order to get the missing piece before re-encoding everything (this may slow down Messenger a little at the first occurrence).
o Skins: the skin trace file will now include more precise information when a loading error occurs as Messenger Plus! is doing the parsing itself. Also, note that if a window file cannot be parsed properly, the original one from Messenger will now be used instead.
* Information for all add-on and patch developers working on Messenger: in order for you to keep on working on your software, I have decided to allow you to encode and decode UIB files for your own use.
o "MPTools.exe", which is available in the Messenger Plus! directory, will take care of your UIB needs. All you have to do is specify the source and destination files and MPTools will do the rest.
o You have two ways to use this feature: if your add-on/patch requires live modifications to the windows files based on some user options, Messenger Plus! will need to be installed on your users' computers and your software will need to call MPTools before and after you modify the file. If you only need fixed changes to be applied on one given version of Messenger, you can decode, modify and re-encode the files yourself and distribute the final UIB file which won't require Messenger Plus! to be installed.
o Although both solutions will work perfectly fine, doing live encoding and decoding with MPTools will always be the recommended for many reasons, the first one being that your add-on will benefit from all the future update automatically and will stay compatible with the next versions of Messenger. Note that MPTools.exe cannot be redistributed and used on its own though, Messenger Plus! needs to be installed for the tool to work (you can either link it from your software or download/install it automatically, with the /Silent switch or not, you decide).
o Check out the new "Encoding and Decoding UIB" section of the skinning documentation for more details.
* Compatibility with all previous beta versions of Windows Live Messenger 9/14/2009 has been removed (more than a year of betas for this one!).
* Contacts from Yahoo! Messenger are now handled better by Messenger Plus!.
* Messenger Plus! now displays many of its windows using the specific color selected for each contact. Display pictures are also displayed in contact related popup notifications (can be turned off in the preferences).
* The Contact Information window now displays an animation for animated display pictures.
* When chatting with more than 2 people, the size of the header in chat logs is now reduced.
* When chatting in a group in Messenger 2009, whenever possible, Messenger Plus! creates a single chat log file associated to the group.
* The "enhance copy/paste" feature now doesn't do anything with pictures and lets Messenger handles it.
* A new icon is displayed in tabbed chats for group chats.
* Windows 7 is now properly reported by (!VER). Messenger Plus! is currently reported to work on this OS.
* The Multiple Accounts option (polygamy) is now compatible with the Windows 7 jump list tasks (tasks are sent to the Messenger that was launched in last).
* A couple of things have been improved internally to ensure the reliability of the sound modules in Messenger Plus! (especially when using emotion sounds).
* Emotion sounds are not automatically played anymore when Messenger is locked.
* The Greek language is now part of the official distribution.
* Setup is now faster if many of scripts and skins are installed.
* Fixed: the Messenger Plus! icons may not be added in the Messenger windows if a skin is enabled but failed to load.
* Fixed: spin controls in the emotion sound wizard are inversed.
* Fixed: Messenger Plus! windows don't look good when a very bright color is selected in Messenger. The color of titles in all windows has been darkened too.
* Fixed: in Messenger 8.5, the names of contacts that are using Messenger 2009 may be displayed incorrectly by Messenger Plus!.
* Fixed: Messenger may crash on startup if a hooking error occurs (problem introduced in version 4.70).
* Fixed: when several user sessions are active and Messenger Plus! needs to restart Messenger (when importing a skin for example), the Messengers of all the user sessions are closed.
* Fixed: "Format Codes" button not added in the the Chinese Messenger options.
* Fixed: the password parameter for command line encryption with LogViewer.exe requires password that have a minimum length of 4 characters.
* Fixed: /PlusSkin="" is ignored and does not prevent the current skin to be loaded.
* The "Use the default scene" option available in chat windows is now supported by Messenger Plus!. Note however that Messenger 2009 has a bug preventing this option to work properly sometimes when changed and requiring the chat window to be closed and reopened. Messenger Plus! always sticks to the option as you selected it.
* Scripts: Image elements now support GIF pictures. Use the new AllowAnimate attribute to automatically animate the picture on screen.
* Scripts: MsgPlus.DisplayToastContact now supports an additional "Contact" parameter to allow Messenger Plus! to colorize the toasts your script display according to a contact's profile.
* Scripts: added a new "ProfileColor" property to Contact objects. You can use this to know what color is currently associated to a specific contact (according to its Messenger profile).
* Scripts: added a new "BaseColor" property to PlusWnd objects. Use it if you want to modify the base color of your windows, for example, to match contact specific colors.
* Scripts and Skins: the <AllowAutoUpdate> element now also takes effect if no Build Number or Update Id is specified.
* Scripts. Fixed: DataBloc::ReadInterfacePtr() does not work as expected.
* Skins: the Resource Extractor has been improved for Messenger 2009.
o The "rcanim", "rcbmp" and "rcchar" resource identifiers are now recognized and handled properly.
o Cursors are extracted.
o Strings from "msgres" are extracted.
o Added basic consolidation mode (third check state in the Resource Extractor window, looks like a square). Use it to produce consolidated windows files that can be used safely in your final skin. Things like strings are not replaced in this mode (for localisation reasons).
* Skins: the skininfo schema file has been modified for Messenger 2009.
o Strings from "msgres" can now be modified.
o The cursors specified in "msgres" can be replaced.
o Remember that the version number of the new Messenger is 14.0 and not 9.0 (keep that in mind when writing your <Restrictions> elements).
* Skins. Fixed: Metadata is not applied properly when replacing pictures that did not any Metadata in the first place.
* Skins: the tabbed chat bar can now be skinned with the picture of your choice, displayed in mosaic and colorized if required. Check out "PlusSkin\ResGroup\TabbedChatBar" for more details.
o Note: the "MessengerPlus\TabbedChatBar" option element has been deprecated and it is recommended that you do not use it (it may not produce good results in Messenger 9).
* Skins. Fixed: Build and Revision can be inversed when reading the Information\Compatibility element.
* Skins: thanks to research done by Willz, a new element named "FrameCount" has been added to picture's Metadata. You can use it when replacing or adding animated pictures.
* Skins: the Resource Extractor now supports the new resource types introduced in Messenger 2009 (which are used transparently while consolidating the windows data).
* Skins: the color map file generated by the Resource Extractor now specifies "ref" for color ids that are references to other colors.
* Skins: the number of encrypted RLE files the Resource Extractor was not able to process fell from 158 in the last beta to 2 in Messenger 2009! (and it's because those two produce an empty result so for now, I prefer considering them as un-processed). This special kind of RLE file has a variable size, the content is generated dynamically with the size requested by Messenger at any given time. Once decrypted, "_var" is attached to the name of the file to make sure you don't forget about it when modifying the resource (if you replace those by pictures, make sure your pictures are big enough to avoid looking pixelized).
* Skins: added "ResetUserScenes" value in the "Options\Messenger" element. It's considered to be "true" by default and is used to remove the currently selected scene from all the user profiles when a skin is selected. Disable this option if your skin is meant to be used in conjunction with scenes.
* Skins: you can now add a "SkinOptions" element in "PlusSkin" resource groups. Use it for conditional skinning of Messenger Plus! resources based on the skin's properties.
* Skins: because Messenger 2009 restricts the command ids that can be sent from sub-windows to parent windows (like the top toolbar in the contact list), a work-around has been added to Messenger Plus!. Instead of adding a "cmdid" attribute, you need to add a specially formatted "accvalue" attribute. For example, instead of cmdid=7460 you'll need to add accvalue="Messenger Plus! CmdId: 7460".
.o The "Show contacts as Idle" option will properly display "Idle" for your contacts' status in chat windows but not in the contact list. For that reason, an "(Idle)" indicator has been added in the contact list's tooltip (Messenger 9 only).
.o Notes about UIB decoding: in order to make things as simple as possible for the skin developers, Messenger Plus! generates definition files and style files almost identical to what you used to see in Messenger before. One of the differences you'll notice is a <*PlusSkin*/> tag on top of each file: do not remove it or alter it.
Télécharger Messenger Plus! Live 4.80
1 commentaire pour “Messenger Plus! Live 4.80”
Messenger Plus! Live 4.82.368 (30/06/2009)
* Messenger Plus! is now entirely compatible with Windows 7 (RC minimum) :
o The Messenger Lock feature has been fixed. A new icon is added to the tray in Windows 7 if an unlock keyboard shortcut is not specified.
o The default Messenger Lock icon in Windows 7 has been changed to blend in better in the new UI (hourglass: shell32.dll,323).
o Note: the jump list of Messenger will work properly when using the Multiple-Accounts (polygamy) option but you'll get the options for only one of your Messenger clients.
o Tabbed chats display a proper preview (peek) picture with a list of currently opened chats. Chats waiting for input are colorized in the thumbnail and Alt+Tab or Win+Tab combinations also display the proper picture.
o A couple of other minor fixes here and there to make the Windows 7 experience complete.
* The settings of your scripts and skins can now be exported from the preferences panel and re-imported back.
o Only the settings of the scripts/skins are exported and not the scripts/skins themselves.
o As far as scripts are concerned, only the scripts that put their settings where they're supposed to (see MsgPlus.ScriptRegPath) will be concerned by this new feature.
* This release is contest-ready!
o In this version, you will see a new golden icon in your Messenger toolbar. Those who participated in the contest 2 years ago will probably remember what this is.
o A "Play and Win" menu has been added in the contact list.
o The 2009 Contest is not open yet, it will be in about a week from now. Remember to give it a try in July!
* The bug present in beta versions of IE8 has been fixed in IE8 Final. The workaround for displaying long chat logs in the Log Viewer has been removed.
* Navigation arrows are now added in Windows 7 for tabbed chats, below the Aero Peek thumbnail in the task bar. Use them to switch from one chat to the next.
* Fixed: the background of the title bars of Messenger Plus! windows does not display correctly with bright colors.
* When a directory is selected in the Log Viewer, the log currently displayed is removed from the screen.
* Fixed: default Messenger sounds for event notifications and new external emails aren't played by Messenger Plus! in Messenger 2009.
* Scripts. Fixed: scripts may be automatically started and marked as "running" the first time Messenger is restarted after a script has been updated, even if the script is disabled.
* Skins. Fixed: new border areas specified in <Dimensions> do not work in Messenger 2009 Final.
* Skins: Fixed: the <FrameCount> element in <MetaData> is not used if specified without any other meta data.
* A couple of stability fixes. Runaway, from the river to the street.
