Pour les intéressés, voici le changelog énorme depuis la dernière version "officielle" du RipPack :
** Build 1822 ** (10/07/2004) [FIX] Added Kernel Deinterlace to New SaveAVS window. [FIX] Many bugs in the "Filters" window (especially to add a new filter). [CHG] New format for filters .xml files (same as AVSEdit) [CHG] New paths to apps (new dirs): BeSweet, DGMPGDec, vStrip, chapterExtractor, DVDDecrypter [FIX] Icon recreation when Explorer crashes on win2000/XP [CHG] Hack to add more key frame interval when splitting .avi. [FIX] New SaveAVS: Denoising comments in script. [FIX] New SaveAVS: "-> RESIZE" was not Read Only when opening an ini file. [ADD] New SaveAVS: Some hints in Memo to help users. [FIX] Error message when closing application. [FIX] Remove VDMod error message when srt file was empty. [FIX] SrtFile was not updated in the registry if deleted in "Options" tab. [FIX] When deleting Registry settings, dgdecode name was "lost" [CHG] Since not used anymore "Use alternative MPEGDEC dll" check box was removed [FIX] SaveAVS: IVTC warning doesn't appear anymore inadvertently. [FIX] XVid zones settings not erased if settings file exists. [CHG] New SaveAVS: More infos on IDCT choices. [CHG] New SaveAVS: Window is now Desktop centered. [CHG] Number of saved profiles increased to 16 [FIX] Splitting is no longer cuts off last few seconds of video [FIX] Comp test results for XviD 1.0 without b-frames improved [FIX] Double click on tray icon is no longer affects other icons ** Build 1811 ** (06/07/2004) [CHG] Dll name chosen by ppl in Options tab is now used ('dgdecode.dll' for example). [FIX] Merge from 0.28.8 version (len0x). [CHG] DVD2AVIdg/MPEG2DEC3dg now DGIndex/DGDecode. [ADD] Number of CD (from 1/4 to 3) ** Build 1806 ** (29/10/2003) [FIX] Credits script was not saved correctly when choosing Save & Encode option in new SaveAVS window. ** Build 1805 ** (27/10/2003) [ADDED] New SaveAVS window: now , infos are saved in XML files. ** Build 1804 ** (10/01/2003) [FIX] bug "array index out of bounds" in the job control [FIX] paths problems when suddenly applications could not be started and moreover you couldn't change the path on the path tab. [ADD] undot() filter which is used by default [CHG] SetWorkingDir is not working properly on some systems, so it was removed from avisynth script [ADD] option to save avi from each pass of divx5 [ADD] job name contains name of the final avi now ** Previous Builds ** (09/03/2003) [FIX] Now Vorbis quality & Audio Language values cannot be added by users. [FIX] If Encode window is shown & no job is added then no more error message. [ADD] Dialog Window to choose Language first time the program is loaded. [ADD] Position of Splitter in MainWindow saved in .ini file. [FIX] Style of Queue window saved & restored properly. [CHG] Options CheckBox.checked moved to .ini file. [CHG] Audio panels updated + eliminated delay in -ota parameter [CHG] Ogg renamed to Vorbis [ADD] Splitter in Queue Window to resize Jobs List [FIX] One Job always selected in Queue Window. [FIX] Up & Down buttons on Queue Job window. [FIX] Standard dialogs in English [FIX] Duplicate JobQueue when Hiding MainForm. [ADD] OGM & MKV support [ADD] Vorbis audio [ADD] OTA, Presets, Boost in Transcoding Audio Parameters. [ADD] Encode: Azid & Lame personal settings saved. [ADD] Chapters [ADD] Tray Icon when minimized [ADD] Load, save, delete, move Jobs in Queue Window |
Attention, avant d'installer cette version, désinstallez toute version précédente de GK et effacez les clés dans la base de registre. Et pour les inquiets, non, pas besoin de toucher à quoi que ce soit d'AutoGK, il n'a rien à voir avec GK.
Source : forum @ doom9.org.
2 commentaires pour “Gordian Knot 0.29.1822 alpha”
En fait, ouais.:mad:.
Non mais, je passe pour quoi moi maintenant ?
