La changements apportés par cette version :
Corrections :
- Admin : when editing a user from a class that has groups defined, clicking OK would incorrectly change the 'groups' property of the user account.
- (0000207) Admin : An exception could occur when deleting servers/domains in the left treeview with the popup menu.
- Admin : menu item 'Actions' was not translated.
- Server : could not use the account tags when user logs on (ie. tags like $USR_CLASS, $USR_ACCOUNT ... in access rights were not replaced).
- Could not delete users and groups using unicode characters not supported by your local charset.
- Admin/Server : fixed several issues with the use of MBCS.
- (0000212) Admin : change 'KBytes' to 'files' when ratio method is set to files so credits are not multiplied by 1024 when displayed on user's side.
- Server : Transfer Limit was applied for download and upload if download limit was enabled.
- Server : Memory leak when using Merge://
- (0000213) Admin : Some times column headers are not shown in ListViews (activity, user list, group list, etc..)
- Admin : Option "use the same schedule every day" in Time of day access may not be checked even if the same schedule is used every day.
- Server : using schedules like '15h00-10h00' in time of day access didn't work.
- Server : Option "Redirect wrong login" didn't check the password of the redirected account.
- Admin : "Import Domain" now also imports banned IP list.
- Admin : added 64KB for Speed Limits in user settings.
- New tags :
- $SRV_STATSCONNECTIONS, $DOM_STATSCONNECTIONS: total number of connections
- $SRV_STATSLOGINS, $DOM_STATSLOGINS, $USR_STATSLOGINS: total number of logins
- $DOM_WHO: list of users connected to the domain
- Admin/Server : Manual changes through interface in server/domains/users/groups are now saved immediately instead of waiting 30 seconds (cache).
- $USR_RATIOUP, $USR_RATIODOWN & $USR_RATIOCOUNTMETHOD returns 'None' if ratio is disabled.
- SIZE command now returns 'Not found', instead of 0 for directories.
g6_fs_ftp.dll now uses SIZE command to check if a file exists, then LIST command if SIZE command is not supported by the remote FTP server. - Admin : simple administrators are no more allowed to view domain properties.
- Admin : Access rights list is sorted so that entries without virtual path are at the end.
- Languages.sib updated :
- Various extended added.
- TBannedFilesForm.Label3 -> TBannedFilesForm.Label_FileMask
- TDomainLogForm.Label_Security -> TDomainLogForm.Label_LogType
- TBanIPForm.CB_Reason -> TBanIPForm.ComboBox_Reason
- TSettingsAdminForm.Edit_LogFile -> TSettingsAdminForm.ComboBox_LogFile
