La longue (comme d'habitude désormais
) liste des changements est disponible sur cette page, et le logiciel en lui-même est disponible sur celle-ci (zip, installeur et sources)
Informatique (logiciels)eMule 0.42cPar LeMoi, le 06-03-2004 à 19:28
5 commentaires pour “eMule 0.42c”
- Mar 5th, 2004 -
bluecow: Fixed rehashing on change of Daylight Saving Time (DST) [MightyKnife]. To disable this patch, add "AdjustNTFSDaylightFileTime=0" in "[eMule]" section in preferences.ini file.
- Mar 3rd, 2004 -
bluecow: Fixed bug with colors and known-type in searchlist control after files were canceled and/or added/removed from share.
bluecow: Fixed bug with sorting by category in download listview.
Unk: USS will temporarly be limited to a minimum of 10K until we correct a couple issues at lower speeds.
- Mar 2nd, 2004 -
bluecow: Fixed bug in UDP socket with ReaskFilePing which was not answered for files which were uploaded only.
bluecow: Fixed bug in IP filter; adjacent ranges with different levels were merged.
Unk: IRC now handles sound events. (/sound [*.wav] [message]) (Sounds are stored in "../eMule/Sounds/IRC" dir)
Unk: Fix KadID bug which created some clusters and reported bad user counts..
- Mar 1st, 2004 -
Unk: Packets for the UDP socket send queue now have a lifetime now to keep from creating a backlog of packets.
- Feb 29th, 2004 -
Ornis: fixed a bug, that resumed 2 (instead of 1) files for the function "start next paused file, when a files completes"
Ornis: correction in the statistics for source-type passive - and several minor GUI fixes
bluecow: fixed invoking the comment page
Ornis: fixed Chicane webinterface template, to be able to start downloads from searchresults
Unk: Fixed a IRC crash bug thanks to reports from several irc ops..
Unk: Fixed the IRC Accept links from friends only option.
Unk: IRC default name gets a pseudo random nick on connect to avoid nick collisions.
Unk: Extra IRC filter options.
- Feb 28th, 2004 -
bluecow: Fixed flaw in exception handling which did not immediatly disconnect a client which sends invalid file data packets.
bluecow: Fixed bug in UDP socket with processing of a received file status.
bluecow: Fixed several flaws in Kad window with connect and bootstrap function/buttons.
Unk: Put back ping info for USS and small adjustment to USS - zz
Unk: Removed some debug info in the upload bars
Dispo en DL ici : http://www.emule-project.net/home/pe...=1&rm=download
Source = Open-Files : http://www.open-files.com/forum/inde...howtopic=15605
desole mais maintenat c la 0.42d
a telecharger ici
http://vcheck.emule-project.net/en/download.php
bye
