les changements par rapport à la version 3.2.2.0 (en anglais):
Ajouts :
Proper support for DL media
Support for 'Calculate Optimal' and 'User Specified' Layer break positions for DL media
'Structure' Protection checking for protected discs (Normal and Aggressive modes)
Automatic 'Transfer Length' setting - Manual setting is used when it fails
Book Type / Bit setting for BenQ, LG, LITE-ON, Nu Tech/QSI and Ricoh drives
Detection of OS upgrades (i.e. 95 -> XP) so as to reinitialise the default I/O Interface
Bus type is now displayed where the drive string is. i.e. '_NEC DVDRW 3500AG 2.15 (G (ATA)'
Option to automatically delete the image after you've burnt it
A 'Hint' when you hover over the source 'Sectors' text in ISO Write mode. Shows number of sectors on each layer
ISO Write modes info window now displays the Layer 0 Data Zone capacity on DL discs
File splitting options to the IFO mode context menus
'Safe Mode' - Press F7 while the splashscreen is up
Ability to 'Pause' the ripping process. Hit the 'stop' button as usual and then hit 'Pause'
Ability to Drag and Drop into the 'Create DVD MDS File' window file list box
Ability to Drag and Drop into the ISO Write mode 'Source' box
Support for reading DVD Decrypter's original .DVD files - now used by CloneCD when making DVD images
Support for Pioneer 120S drives that 'forget' where the laser is and display lots of 'Pack Header Not Found' errors
Support for converting Mode 1 NON 2048 bytes per sector images on-the-fly to DVD standard whilst burning
Support for burning images containing CSS information - 2054 bytes per sector - CSS information is discarded
'Pack Header Not Found' logging is now disabled/re-enabled automatically
MDS creation code to make proper 2 layer MDS files for discs that have 2 layers!
MDS loading code to make use of info (see above) for DL recording (Perfect 1:1 backups!)
Some of the special code that's run as part of the DoItFast4U CLI switch
The program now only checks for updates once per day - saves pointless hammering of the server
'Create DVD MDS File' window listbox now scrolls if entries are too long
File mode 'Detect Mastering Errors' now works like IFO and ISO modes and still checks each VOB/CELL ID change even when the file isn't supposed to be protected
Handling of ripping process in IFO mode. It now wont care if the 'VTS Cell Address Table' doesn't match the PGC
Browsing for a destination folder will now default to the closest folder to the currently selected one instead of going to the desktop
Clicking on the hdd icon to the left of destination will now open the closest folder to the currently selected one instead of doing nothing if that exact folder didn't exist
Added a little work around for Plextor PX-712A drives that can come up with a 'failed to get varient' error during authentication
Code for 'Opening' of device in SPTI mode
Protected DVDs (ones with corrupt IFO tables) could/would have had one of the corrupt PGCs being selected as the 'Main Movie' one
Unused cells from the start of a PGC would have been copied in IFO mode when they shouldn't have been
Data buffer overflow when setting the hardware read error retries count
Burning 2352 sector images in 2048 mode (and some other weird combinations!)
Firmware lookup on rpc1.org for DVDRAM drives would fail to find any results
Problem of CTRL+A not working in ISO Read/Write information panels
Alignment of file sizes in File mode if the file name length is longer than the normal 12 characters
The URL to rpc1.org was wrong in some places, this has been corrected
Ajouts :
Support for burning images containing CSS information - 2054 bytes per sector - CSS information is discarded Changements :
Code for 'Opening' of device in SPTI mode Réparé :
Liste de miroirs pour télécharger DVDDecrypter 3.5.0.0
Site officiel
Source : Unité-Vidéo
1 commentaire pour “DVDDecrypter 3.5.0.0”
* Added: Dialog box to remind users to load the MDS file instead of the ISO file - it's good practice and is vital for nice DL burns
* Changed: Structure Protection code to find more instances of 'suspect' areas on the disc
* Changed: Some of the Automatic 'Transfer Length' code. It now checks for additional possible errors in the output from the API call
* Changed: Previous workaround for Plextor PX-712A authentication problem caused problems for old drives that hang on a 'Rezero' command (Status bar always displayed 'Almost Ready'). The command now only runs on Plextor DVDR drives
* Fixed: Access violation errors caused by nasty IFO files on some of the newer discs
* Fixed: 'Browse' was always visible in the 'File' menu
* Fixed: Potential issue with getting the disc size from the ISO9660 file system (only used in ISO Read mode on DVD+RW discs)
* Fixed: 'Cracking CSS' dialog box showed very inaccurate progress information
* Fixed: CSS cracking was repeating itself on files it shouldn't have been
