- Optimisations pour les processeurs simple core qui accélèrent l'encodage de 14 à 80%.
- Optimisations pour les processeurs Dual Core, HyperThreading et pour les systèmes multiprocesseurs qui accélèrent l'encodage jusqu'à 250 % (Dual Core + HT).
- Nouveau mode d'encodage haute qualité.
- Le mode DivX HD autorise un bitrate maximal de 6 Mbps.
- Corrections de bugs.
- Meilleur support du MPEG4.
- Gestionnaire de téléchargements permettant de télécharger plusieurs vidéos en même temps et de les lire progressivement.
- Fonction pour graver les fichiers DivX directement depuis le lecteur.
- Gestionnaire de médias pour organiser sa vidéothèque DivX.
Changelog Divx 6.1
New:
- Full support for single CPU, HyperThreaded (HT), dual CPU (SMP) and dual core processors. Encoding performance is improved up to 180% for HT CPUs and up to 250% for Dual Core + HT.
- Mutlithreading is enabled in the DivX decoder for DirectShow when the option to 'Reduce CPU spikes using one frame delay' is enabled and post-processing is applied.
- Optimizations have been added for processors supporting SSE2 extensions.
- A new "High Performance" encoding mode has been added.
- A new "1-Pass Target Quantizer" mode has been added.
- The codec now includes a Lanczos resize filter for very sharp resizing.
- The Feedback Window now displays VBV level and has variable axis for PSNR plots.
- The Feedback Window now contains controls for changing VBV bitrate, performance mode and psychovisual enhancement in real time during encoding.
- DivX High Definition profile now permits average bitrates of up to 6 Mbps.
- MPEG quantization has been improved.
- Brightness, contrast, and saturation controls are now respected by the DivX decoder for DirectShow.
- The DivX decoder for DirectShow now respects the option to "Output YUV 4:2:0 when supported."
- It is now possible to exclude the Settings Manager by using RegEdit to add the process name to the list under: HKLM\Software\DivXNetworks\DivX\SMExclusions.
Changed:
- The performance of "Extreme Quality" and "Insane Quality" modes has been improved.
- "Fastest" mode now achieves better compression and produces video compliant with certified encoding profiles.
- Quarter-pixel motion estimation has been enhanced for performance and is now available in all modes from "Balanced" through "Insane quality" when "Unconstrained profile" is selected.
- Item descriptions in the encoder GUI have been improved for all languages.
- Generic MPEG-4 playback support has been improved.
New:
Changed:
Télécharger le pack DivX Play 6.1 (codecs DivX 6.1 et lecteur DivX Player 6.0) pour Windows (10,9 Mo)
Télécharger le pack DivX Create 6.1 (convertisseur DivX 6.0.3, codecs DivX Pro 6.1 et lecteur DivX Player 6.0) pour Windows (12,5 Mo)
Télécharger les codecs DivX 6 (convertisseur DivX, codecs DivX et support de lecture DivX) pour Mac (4,64 Mo)
Source : DivX labs
13 commentaires pour “DivX 6.1”
New in this version
Une vitesse d'encodage améliorée (jusqu'à 350%:rolleyes: plus rapide que DivX 6.0).
Optimisations pour les processeurs récents (dual-core, Hyperthreading) et moins récents.
Meilleure qualité d'encodage.
Support de nouveaux modes d'encodages avec possibilité d'ajouter ceux qui seront proposés par la communauté DivX.
New:
- A new encoder preset option allows you to quickly configure the encoder based upon your preference for encoding speed and video quality
- The DivX community codec replaces the current free version of DivX, offering a wider range of performance and quality options for free through encoder presets
- Multithreaded resize filters have been added for improved performance on all HyperThreaded (HT), dual CPU (SMP) and dual core processors
- A new "Enhanced multithreading" option capable of increasing encoding rate depending on system configuration and encoding environment
- A new "Enhance texture" psychovisual enhancement method that improves picture details around keyframes and reduces the appearance of stray blocks under fast motion when encoding at lower bitrates
- MMX optimizations for the MPEG quantization method
- The DivX decoder can anonymously check for updates to the DivX codec, ensuring you are always notified of newer versions
Fixed:- Fixed a problem where multiple instances of the feedback window would cause the encoder to fail
- Fixed a problem where very old DivX 5.0 content might not be decoded correctly
- The encoder GUI now adapts to screen resolutions of 800x600 or lower
ChangedMais on nous annonce une compression 350%:rolleyes: plus rapide et un gain de qualite...
Allez M. DivX, encore un petit effort et on pourra mettre un film sur une disquette en qualité DVD et avec les sous titres et les bonus
• New :
- Improved B-frame decision.
- Improved rate control for very high bitrates.
- Improved Japanese encoder translations.
• Fixed :
- Fixed a problem where some systems would crash as the Psychovisual Enhancement method was modified in the encoder configuration window.
- Fixed a problem that caused cropping to reduce performance.
- Fixed an issue where adjusting the VBV_bitrate slider in the Feedback Window would reset the VBV buffer occupancy.
- Fixed a problem where the decoder would fail if both smooth playback and YUV output were enabled in the Decoder Configuration Utility.
- Fixed a post-processing issue in the decoder for multi-threaded systems.
- Fixed a handle leak in the decoder.
Personellement j'encode avec BVRP " DivX Video Duplicator Pro" qui d'origine à un codec divx 5.02
J'ai testé en mettant divx 6.02. Resultat les *.avi tiennent moins de place, je code sur 700 mo et j'ai environ 550 mo mais la qualité est désastreuse.
Je suis revenu à la 5.02
J'ai peut-être loupé quelque chose ?
Quelques nouveautés et optimisations sont au menu avec un filtre d'accentuation (sharpening) lors de la lecture. Compatible avec n'importe quelle vidéo au format DivX 3, 4, 5 ou 6. Cette fonction renforce la netteté des textures mais requiert un processeur plus puissant.
Les performances d’encodage sont également revues à la hausse. Selon les tests de DivX Networks, un gain de 30 à 50 % se fait ressentir par rapport à la version 6.2.2, avec des pointes à 63 % pour les Pentium 4 dual core en mode « full deblocking ».
Télécharger Divx 6.2.5 (uniquement pour Windows) sur le lien habituel
