NDFR : ChrisTV Professional 3.70
ChrisTV est un des meilleurs logiciels pour visionner la TV sur votre ordinateur. Cet utilitaire est capable de piloter les tuners TV utilisant des drivers WDM et gère les carte à base de chipset BT8x8, Philips SAA713x ou Conexant CX23881.
Voici les nouveautés :
  • NEW Automatic Channel Scanning 'by frequency', where you can choose the frequency interval and the step (0.25, 0.50, 0.75, 1.00, 2.00, 5.00, 7.00, 8.00 mhz) of the automatic scan.
  • Improved the automatic channel scanning 'by channel number' and 'by channel table'.
  • Added the option to schedule audio (radio&tv) recording tasks - only in Professional Version.
  • MSI TV @nywhere Cards are fully supported now, for more details on configuring check ChrisTV forum
  • The recording module has been optimized and all known bugs have been removed.
  • In order to help our users to find the solutions to common problems we have added a new Settings Window - ChrisTV Tips & Troubleshooting.
  • ChrisTV Settings Window has been reorganized.
  • Added the option to hide the ChrisTV Takbar button if TV Window is set "Always on Top".
  • ChrisTV Driver Settings Window has been reorganized.
  • Added the option to reInitialize the WDM Driver on ChrisTV start, in order to fix some problems related to : noise (or no proper sound) - Medion TV Cards,no channel detection on channel autoscan or wrong video standard used on ChrisTV launch.
  • Added the option to use a special channel frequency tunning for some TV Cards, like MSI TV @nywhere Cards.
  • Improvements and fixes in the Zoom Module, on some cases the zoom wasn't set corectly after ChrisTV restart when Deinterlace Filter or Image Processing filter was enabled.
  • You can now Zoom to the center of the image by holding down CTRL key and using mousewheel in order to zoom in or out.
  • Added the option to Disable Video Renderer while using Radio Mode, so the CPU ocupancy will be lower, but the channel switch time between TV Mode and Radio Mode could increase.
  • Added the feature to export and import the ChrisTV Channel List to *.chl files.
  • Added the option to hide the channel number in the popupmenu channel list and in the TV OSD.
  • Added the option to choose the Clock Time Format for the OSD Clock.
  • Sleep Timer/Shutdown Function should work properly on all PC's configurations now.
  • Other small fixes and improvements.
Vous pouvez visionner des screenshots de ce logiciel ici
Télécharger ChrisTV Professional 3.70
Source : Warp2Search
2 commentaires pour “ChrisTV Professional 3.70”
  1. Samva a dit (le 15-05-2004 à 22:40)
    Erm, il ne vaut pas l'excellent K!TV a mes yeux mais bon.... il en faut pour tout les gouts
  2. wince a dit (le 16-05-2004 à 02:57)
    bah suis d'accord sur un point qui est le plugin canal moins...
    autrement je viens de decouvrir christv et ca pulverise ktv sur tout les points et meme la version free est a la hauteur !!
    psossible d avoir un plugin de stroumphage de canal moins sur chris ?
Afficher l'actualité “ChrisTV Professional 3.70” sur le forum
