NDFR : CDBurnerXP 2.2.5
CDBurnerXP est un logiciel de gravure gratuit, permettant de graver vos CD-R, CD-RW et DVD+R/RW. Il est capable de graver des cd de données, audio (à partir de fichiers wav, mp3, ogg, wma), des images ISO, de faire des copies "à la volée"...
Ce soft est conçu pour Windows 98SE, ME, 2000, XP seulement. Quelques problèmes subsistent pour Windows 98SE et ME, mais l'auteur y travaille .
Vous pouvez consulter des screenshots de ce logiciel ici
Voici les nouveautés apportées par cette version :
  • Added possibility to make ISO images, this can be started from the ISO Writer menu.
  • Updated the development environment to Service Pack 6, I hope this will make the application to work better under Win98 and WinME.
  • New background in the main window.
  • Rewritten the check update, now it uses the html protocol, this should eliminate problems with downloads.
  • Added a button in the toolbar for starting the ISO Creator.
  • Changed the layout of Data Writer, Audio Writer and DVD Writer windows.
  • Added a new size meter to see how much is added to the compilation.
  • Added popup menus for adding sessions to the CD.
  • Added popup menus for adding and deleting files from the compilation.
  • New buttons for moving up, creating directories, select all and deselect all files in the file view.
  • Added function for detecting previous sessions on the media, if there is a previous session the program will ask if it should import the latest session.
  • Added a new button for inverting selected files in the file window.
  • Added a new button for filtering files after there extensions.
  • Changed the icons in the main toolbar.
  • Changed the icons in the Audio Ripper.
  • Removed the sidebar, all the functions are added with popup menus or in the toolbar.
  • A completely new installer for CDBurnerXP Pro.
  • Added options for CDBurnerXP Pro. (There will be more options in further releases).
  • Corrected an error when deleting a file that was already added to a compilation.
  • Added resize functions to Data Writer, Audio Writer, DVD Writer and ISO Creator.
  • Corrected an error that occurred when trying to convert nrg files bigger than 2GB.
  • Corrected that nothing changed when selected different data modes in CDWriter.
  • Addedmore options to CDBurnerXP Pro.
  • Added a system info button to the about dialog.
  • And much more…
Télécharger CDBurnerXP 2.2.5 (15.9 MB, gratuit pour une utilisation non commerciale)
Source : MajorGeeks
2 actualités similaires
  1. Informatique (logiciels) CDBurnerXP 2.2.7
  2. Informatique (logiciels) CDBurnerXP 2.2.6
13 commentaires pour “CDBurnerXP 2.2.5”
  1. Steven a dit (le 28-05-2004 à 20:13)
    j'utilise nero, et il me plai bien
  2. shp13 (non inscrit) a dit (le 28-05-2004 à 20:15)
    salut,
    c'est possible d'avoir un lien vers la page de téléchargement au lieu du lien direct vers le fichier ?
  3. Toitoine a dit (le 28-05-2004 à 20:23)
    Nero est très bien, mais payant ...
    Originally Posted by shp13
    salut,
    Oui, désolé, ici, va dans la catégorie Download
  4. Spycam a dit (le 28-05-2004 à 20:31)
    salut,
    L'idéal dans une news informant une nouvelle version d'un logiciel ce serait :
    Nom du logiciel.
    1. Nom du logiciel.
    2. Description du logiciel.
    3. Type de logiciel ( démo, shareware, freeware ...).
    4. Si possible, screenshot.
    5. Extrait du changelog ( une citation ou une reformulation et non pas un lien ).
    6. Lien vers la page de téléchargement.
    7. Source.
    C'est tout.
    [EDIT] C'est bon ? tout est là ?
  5. shp13 (non inscrit) a dit (le 28-05-2004 à 20:47)
    Spycam : pas d'accord sur le d.
    par respect celui qui héberge le fichier il me semble que c'est la moindre des choses que de ne pas mettre un lien direct vers le fichier mais plutôt vers la page d'accueil ou de téléchargement ; il me semble que ça fait partie de la netiquette non ?
    Toitoine : tu avais déjà mis ce lien ("CDBurnerXP est un logiciel de gravure...") c'était juste pour remplacer l'autre
  6. Toitoine a dit (le 28-05-2004 à 20:49)
    Oui, mais je n'ai pas pu avoir l'URL de la page de Download
  7. shp13 (non inscrit) a dit (le 28-05-2004 à 20:53)
    en fait je demandais juste que tu remplaces le lien vers le fichier par l'url de la page de téléchargement OU de la page d'accueil
    normal que tu n'aies pas l'url de la page de download, le site utilise des cadres
  8. Spycam a dit (le 28-05-2004 à 21:14)
    J'ai hésité à le mettre. :rolleyes:
    Bon je supprime le d ( Lien direct vers le logiciel avec l'extension et la taille. ).
    Netiquette >> à lire.
  9. Toitoine a dit (le 28-05-2004 à 21:15)
    Ok, dans ce cas, comment je fais pour avoir directement la page de Download ?
  10. LeMoi a dit (le 28-05-2004 à 21:49)
    d'accord pour les petits logiciels, ou pour les 'gros' logiciels avec une liste de mirroirs, mais si le programme est très connu (genre Nero, eMule, etc.), et que ça risque d'évoluer si qqun lit la news en voulant prendre cette version et non la denière (je sais pas si je suis clair la )
  11. Spycam a dit (le 28-05-2004 à 22:28)
    Traduction :
    LeMoi est d'accord pour les petits logiciels et pour les gros avec des mirroirs.
    Il n'est pas d'accord pour les programmes très connus et ceux qui évoluent vite.
  12. shp13 (non inscrit) a dit (le 29-05-2004 à 01:37)
    quelque soit le logiciel je sais que je préfère toujours aller sur le site de l'éditeur pour plusieurs raisons :
    - si je ne connais pas le programme je m'attarde un peu sur le site, je regarde s'il y a des screenshots
    - je vérifie le type de license (demo, shareware, freeware, open source)
    - je suis sûr d'avoir la dernière version même si un correctif est sorti à la dernière minute
    LeMoi : dans le cas d'une évolution il y a de grandes chances pour que l'ancien lien ne fonctionne plus, tous ne font pas comme Nero qui conserve quelques anciennes versions lorsqu'une nouvelle sort
    à mon avis : lien direct uniquement si tu héberges le fichier
    Toitoine : la page de téléchargement est ici mais dans ce cas il vaut mieux laisser un lien vers la page d'accueil
  13. LeMoi a dit (le 29-05-2004 à 14:27)
    pour ma part, (bon, c'est vrai que j'y pense pas tout le temps...), mais j'essaye de mettre un petit screenshot si le logiciel est pas trop connu, j'essaye de préciser autant que possible si c shareware/démo/gratuit dans la news, et de faire une maj de la news ou une autrenews après si un correctif sort rapidement (cf. abc 2.6.6 avec la 2.6.6a peu après)
    mais bon, c vrai que j'oublie
Afficher l'actualité “CDBurnerXP 2.2.5” sur le forum
