Voici les nouveautés :
Fixed problem with Matroska files with only audio streams Sometimes audio stream names with Ogg files was corrupted, fixed Selected audio output device will now be remembered when switching audio streams Sometimes skin would revert back to base skin, should be fixed now Fixed problem with freezing when seeking Movie length was displayed as 0 after stop, fixed Last subtitle line was still displayed after switching subtitles off, fixed AC3 filter will be visible now in filter list If video window was left on secondary monitor and in full screen mode, position wasn't remembered, fixed chapters from ini files should now be read like in 0.8xx versions ini shutdown option wasn't working, fixed fixed bug with resolution switching in full screen mode fixed freezing problem with some skins under Windows 98
filters defined in bspfilters.dat will now be loaded even if other libraries are required (for ex. xvid.ax require xvidcore.dll), just put them all in .\filters directory added option to open locked (in use) files subtitle position will now also work when 'Draw subtitles to overlay surface option is checked' Subtitle language for subtitles in Matroska files is now properly displayed
Vous pouvez trouver ici des skins pour le personnaliser.
Télécharger BSPlayer 1.00.809 (2Mo, gratuit)
Source : MajorGeeks
4 commentaires pour “BSPlayer 1.00 RC1 Build 809”
merci de l'info au passage, tu m'as devancé
