D'après ATi-Power, ce serait une version anglaise avec le Catalyst Control Center.
Si vous êtes patient, vous aurez les pilotes sur le site officiel ce soir ou demain, sinon jetez-vous sur le lien plus bas.
Changements apportés par les pilotes ATi Catalyst 5.8
- Battlefield 2: Geometry corruption or missing textures are no longer noticed when playing the game for an extended period of time under Windows XP with an ATi Radeon® X800 XT installed
- 3D Mark03: Enabling Powerplay mode and running the 3DMark03 or 05 in a loop no longer results in an error message being displayed
- Area51_2.3dc: Playing the game under Windows XP no longer results in the NPC and guns appearing distorted, flashing or missing. Further the polygons no longer pop in and out of the display
- GTA: Vice City: Setting the desktop and the game display option to 1024x768 32bpp and attempting to play the game under Windows XP MCE, no longer results in an Invalid Pixel Format message being displayed after approximately 5 minutes of game play
- Lineage 2: Playing the game under Windows XP no longer results in display corruption being noticed
- Movie Maker 2: Connecting an external video source using the S-video composite connectors, no longer results in the Movie Maker 2 application intermittently failing to capture video, when selecting the Capture from Video Source
- MU Online: Opening a chat window and playing the on-line game no longer results in hesitation being noticed when pressing the Enter key
- Quake 3: Enabling SmartShader™ followed by attempting to do a mode change while playing the game, no longer results in the game failing to respond
- Star Wars Knights of the Old Republic: Running the Dantoonie level of the game no longer result in hesitation being noticed
- Terathon: Starting the Terathon 3D engine and selecting a single player demo, no longer results in the 3D engine failing to respond under Windows XP
- Trackmania Sunrise: Playing the game under Windows XP no longer results in the operating system failing to respond, when attempting to exit the game after leaving the PC idle for an extended period of time
- Warcraft III: Playing the game under Windows XP with the display rotated by 90 degrees CCW, no longer results in display corruption being noticed
- Performing an overwrite of the video driver install, no longer results in the Hydravision Multidesk feature being unable to load
- Video mode and Overscan can now be enabled when connecting a TV as the secondary display device and setting the display resolution to 640x480 32bpp 60Hz and extending the desktop
- The Select by Signal Format is now the default setting when connecting a TV to an ATi display adapter
- Catalyst™ Control Center: Updates to saved profiles is now available
- Catalyst™ Control Center: Connecting a TV using the S-Video connector no longer results in the Apply button found in the TV properties of the Catalyst Control Center being active when no changes are made to the TV properties
- Catalyst™ Control Center: An intermittent service error message is no longer displayed when starting up the Windows XP MCE operating system
- Connecting a TV as the secondary display device and a CRT as the primary display device, no longer results in the Video mode and Overscan option not functioning properly when extended desktop is enabled
- Catalyst™ Control Center: Double clicking anywhere on the Catalyst™ Control Center background after changing the color correction to the Full Screen 3D option no longer results in a full screen preview
- Hesitation is no longer noticed when attempting to resume from an S3 or S4 state with Analog tv
- Random display corruption is no longer noticed when playing a raw audio/video capture for the first time
- Configuring Windows Media Encoder 9 as ATi AVStream Analog capture and ATi AVStream Analog Audio capture, followed by selecting a TV channel as input, no longer results in the both the Input and Output windows going black when Start Encoding is clicked
- The DVB-T channel scan time no longer appears to be slow
- Catalyst™ Control Center: Graphic truncation is no longer noticed under the Desktop and Display Setup of the Display Manager, in the German edition of the Catalyst Control Center
- Catalyst™ Control Center: The text found in the Overlay/VIDEOVISION section of the Catalyst™ Control Center is no longer cut-off for the Turkish edition of the Catalyst™ Control Center
- Setting the desktop resolution to 1024x768 32bpp and using the DVI connector to hot-plug an HDMI display device, no longer results in an error message being displayed
- Using the ATi recommended speed option found in the Overdrive™ tab of the Catalyst™ Control Center, no longer results in the engine and memory clock values being the same as the default values
- Using the DVI connector for a DFP display device, and the S-Video connector for a TV, no longer results in the driver returning the wrong display mappings when unplugging the DFP display device and extended desktop is enabled
- Catalyst™ Control Center: The Set Desktop Area To, is no longer enabled and the resolution list is no longer available, when hot-unplugging a secondary display device under Windows XP
- Playing an MPEG file on a secondary display device that is connected to the DVI port, no longer results in the lower portion of the playback window being missing
- Hesitation in the Aquarium screen saver is no longer noticed when the ATi Multimedia Center™ is running
- Using a limited account under Windows XP and changing the SmartShader™ aspect from none to black and white, no longer results in a general protection fault
- Creating a custom hot-key for rotation no longer results in the custom hot-key to become unavailable for the secondary display device, when extended desktop is enabled and both display devices are set to 1280x1024
Télécharger les pilotes ATi Catalyst 5.8 (33 Mo, anglais)[MAJ] Les pilotes sont maintenant disponibles sur le FTP d'ATI
Télécharger les pilotes ATi Catalyst 5.8 avec Control Center pour Windows XP (33,6 Mo, anglais)
Télécharger les pilotes ATi Catalyst 5.8 avec Control Panel pour Windows XP (25,9 Mo, anglais)NB : le site DriverHeavendownloads est protégé par un anti-leech. Si vous avez des problèmes de téléchargement, désactivez votre firewall et utilisez de préférence le logiciel de téléchargement de votre navigateur.
[MAJ 2] Dans la foulée, les pilotes pour Linux (qui apparemment devraient apporter pas mal de changements et une plus grande facilité d'installation) sont sortis. Voir la page de téléchargements chez ATI.
NB : il existe des pilotes différents pour machines/OS 32 et 64 bits.
24 commentaires pour “ATI Catalyst 5.8 sur DriverHeaven (MAJ)”
Mais tous ces drivers alternatifs me perturbent un peu.
Qu'en pensez vous ?
Guru 3D les a d'ailleurs publié hier soir...
J'suis tombé sur un jeu où il ne le faisait pas une ou deux fois comme les autres, mais tout le temps... Il s'agit de C&C tiberian sun.
J'ai pêté les plombs, cherché l'erreur partout, ça semblait pas venir de la carte graphique vu que tout tout tout foirait (même pas possible de faire ctrl-alt-del)...
Pi quand je me suis dit "tant qu'à faire", j'ai testé les omegas, et j'ai plus eu de problèmes depuis
Ah si, quand j'avais remis des officiels tout neufs pour voir si ça allait mieux, pi c'était pas le cas
Depuis un an que la chose fût faite, rien à déplorer : çà roule
Du coup je suis obligé de me taper toute la présentation
vous pouvez dl les catalyst 5.8 sur les ftp d'ati
Avec CATALYST Control Center:
http://www2.ati.com/drivers/5-8_xp-2..._enu_25203.exe
Avec Control Panel:
http://www2.ati.com/drivers/5-8_xp-2..._wdm_25203.exe
PS: je met que les liens pour XP
Ce même jour des nouveaux pilotes pour Linux sont sortie, les 8.16.20
http://www2.ati.com/drivers/linux/linux_8.16.20.html
Ca vous change hien ?!
Le premier test des Catalyst 5.8 n'est pas très probant !
Je vais attendre les prochain Omega...
Edit : Pour ceux qui ne parlent pas Allemand et qui ont Maxthon, n'oubliez pas la fonction de traduction des pages "Menu Outils > Traductions & Services". Ca marche très bien car le test est très bien écrit dans la langue de ... hum... "Helmut Cole"
https://support.ati.com/ics/support/...uestionID=1176
edit: bas ca marche pour une fois
Ca va redorer le blason de cartes ATi pour les Linuxiens ...
EDIT : c'est bon je les ai choppé sur guru3d.com
Pas grand chose de nouveau. Bug corrigée pour :
Jeux supportés:
- Prince of Persia : Les Sables du Temps
- 3D mark03
- Pacific Fighters
- Silent Hunter 3
- Dungeon Siege 2
- Stronghold 2
- Max Payne 2.
Ne supportent pas :les Radeon X1800, 1600 et X1300 annoncés il y’a maintenant une semaine
https://a248.e.akamai.net/f/674/9448...ase_notes.html
lien vers les catalyst :
https://support.ati.com/ics/support/...questionID=640
et un changlog succins ...
