La liste des changements :
- Data type profiles have now been updated.
- Added Support for more devices, you can find more detailed information on our development page at http://www.alcohol-soft.com/devsupp/.
- Support XP-Theme changing, when you change the theme of XP/2k3 itself, the color of alcohol software is also changed.
- Added Alcohol-Safe-Mode (ASM) function. Even if the device driver is not installed properly you can still use alcohol without emulation functions and "native device control interface". You would receive a message dialog "Loading Alcohol device drivers failed! Emulation options and native driver interface of Alcohol 120% will not be available!"
- Added Slovenian Language.
- Fixed some minor bugs.
- Fixed the BSOD which may happen when Roxio drivers are installed. e.g. MediaPlayer 9, Easy CD Creater 5/6 and ...other applications from Roxio.
- Fixed the pnphlp.vxd BSOD problem in win9x platform.
- Fixed compatibility problems of drive layer found in win9x platform.
- Fixed compatibility problem while emulating certain RingPROTECH protected games.
- Fixed some blacklisting problems.
