Communauté Informatique NDFR.net : NeroVision Express 2.1.2.9 - Actualité
Old 30-04-2004, 23:28
Lien direct de la news : NeroVision Express 2.1.2.9
Une nouvelle version de NeroVision Express, partie intégrante de Nero 6 dont il constitue le 2ème pack, est disponible.
Une mise à jour du pack 1 et du pack 3 sont prévues aussi incessament sous peu normalement
Le long changelog :
Features Added
  • VOB file import does now import the complete content of the same title set
  • In the application settings the user can now define the destination path for imported video content
  • DVD double layer support added for DVD+VR
  • Improved *.VOB file import
  • Support of VOB files containing multiple segments
  • Nero ShowTime now displays the special keys of a multimedia keyboard are supported
  • By clicking on menu in Nero ShowTime the user will now see the playlist from which the playback is started from
  • Pan & Scan function is added in Nero ShowTime
Bug Fixes
  • Fixed a problem which occurred when trying play back a DVD-VIDEO disc with Windows Media Player 8/9 and NVE was installed
  • Improved error handling of not DVD-VIDEO conform video files
  • Fixed a problem that burn process failed immediately, for DVD +VR, if no disc is in the recorder
  • Fixed the problem that black frames were shown at merge point when merging several video clips into one
  • Fixed the problem that video menu template “Island” was not shown for some reason
  • Fixed the problem that NVE reports “burn process fails” for DVD +VR on DVD+R media, even the process was completed correctly
  • Fixed a problem which occurred if a capture device has a not supported colour format setting
  • Some generic improvements for DVD double layer
  • Add some Improvements for capturing from DV cameras
  • Fixed a crash after add a transition in a slideshow
  • Fixed that *.VOB file import failed after analysis
  • Several GUI optimisations
  • GUI optimized for multibyte character operating systems
  • Add a warning message before importing if hard disk contains insufficient free space
  • Fixed the wrong order after import of a VOB file
  • Fixed a compatibility problem with Windows Media Player 9
  • Fixed that NVE does not clean the TEMP files created due importing *.VOB files
  • Fixed that NVE does cache already imported *.VOB files again
  • Fixed that adding *.VOB file for DVD-VIDEO project fails with error message
  • Changed message box to download new menu contents to an info message
  • Fixed that NVE hangs after aborting the import
  • Fixed that VOB files recorded by Sony CE recorder are imported incorrectly
  • Added some languages translations in Nero ShowTime
  • Image adjustment can be done while a file is playing back in Nero ShowTime
En attendant, vous pouvez télécharger NeroVision Express 2.1.2.9 sur cette page et admirer le nouveau design du site de Nero en attendant sa nouvelle version
Nero 6.3.1.20, NeroVision Express 2.1.2.18 1for-matik Actualité 3 17-09-2004 13:59
Nero UltraEdition 6.3.1.17, NeroVision Express 2.1.2.16 LeMoi Actualité 5 03-07-2004 12:19
Nero 6.3.1.15 et NeroVision Express 2.1.2.12 en français nantesph Actualité 4 06-06-2004 12:29
Probleme avec nerovision express abbou Logiciels 14 23-11-2003 19:47
NeroVision Express Enfin en Telechargement streets Actualité 1 21-11-2002 21:10
