Communauté Informatique NDFR.net : Diskeeper Professional v8.0 Build 478 - Actualité
Old 24-01-2004, 16:40
Werner's Avatar
Werner Werner is offline
cOWboy attitUDe
Lien direct de la news : Diskeeper Professional v8.0 Build 478
Math me fait savoir par message privé qu'une mise à jour pour Diskeeper Professional Edition dans sa version 8.0 est disponible. Aucune information sur les changements apportés. Après avoir installé la mise à jour ci-dessous vous passerez en Build 478...
Old 24-01-2004, 19:17
Re : Diskeeper Professional v8.0 Build 478
oui, elle date d'au moins une semaine
et la version server aussi est passée en build 478
et dans le readme de la version admin, on peut lire :
C. CHANGES IN THIS RELEASE
1. Build 477 includes changes to the format of the data
files collected by Diskeeper Administrator Edition. When
you install this version over an existing Diskeeper
Administrator installation, any previous data files are
automatically converted to the new format.
Note, however, that if you uninstall an earlier version of
Diskeeper Administrator before installing this version, you
must manually run the data conversion program included in
this release. To manually run the data conversion program,
double-click the XMLCONV.exe file located in the Diskeeper
Administrator installation folder.
This manual step is also necessary if you have manually
copied older Diskeeper Administrator data files into the
Diskeeper Administrator data storage area. (By default, this
is Program Files\Executive Software\Diskeeper Administrator
\Controller\Data.)
2. Diskeeper Administrator Edition can now PushInstall Diskeeper
Server Standard Edition to Windows 2000 Advanced Server and
Windows NT 4.0 Enterprise Server.
3. Icon information is now properly updated with the Full Refresh
option.
4. Under certain circumstances, previous versions of Diskeeper
Administrator would display status messages twice. This has
been corrected.
5. A situation that could prevent Diskeeper Administrator from
controlling Diskeeper on remote machines has been corrected.
6. Changes have been made to address a situation where XML
files were not loading properly under certain circumstances.
7. A number of cosmetic changes have been made to clarify icons,
messages and other text displayed by Diskeeper Administrator
Edition.
8. Erroneous "Insufficient Free Space" messages are no longer
displayed.
9. Changes have been made to the PushInstall feature to handle
timeout problems when earlier Diskeeper versions were being
uninstalled from slower computers.
10. Event log messages have been modified to report more useful
information.
11. The Daily Alerts Report now functions properly.
12. The Performance/Reliability Report has been changed to
correctly report all the defragmented disk volumes and
the free space figures displayed.
13. Saved reports are now properly formatted when reopened.
14. The PushInstall feature now creates an ADMIN$\Temp folder
on the target machine if the folder does not already exist.
15. Diskeeper Server Enterprise Edition has been added to the
list of Diskeeper editions that can be PushInstalled to
remote computers on your network.
16. Improvements have been made to the method used to gather (or
enumerate) Active Directory information to display in the
Machine pane of Diskeeper Administrator. These changes result
in fewer system resources being used during the Active
Directory enumeration. Also, the Active Directory information
will not be enumerated until you click on the Active Directory
icon in the Machine pane. In previous versions, this
enumeration was done each time the Diskeeper Administrator
service was restarted.
17. Earlier versions of Diskeeper Administrator performed a full
network enumeration (gathering machine and Diskeeper
information from all the machines on the network) each time
it was started. To improve performance on large networks, this
has been changed. Diskeeper Administrator now enumerates the
domains only when the you expand the domain in the Machine
pane of the Diskeeper Administrator display. This change also
reduces the amount of memory used by Diskeeper Administrator.
18. Since the full enumeration is no longer done when Diskeeper
Administrator is started, it is necessary to manually perform
a full refresh to update the Diskeeper information shown by
the icons in the Machine pane. To perform a full refresh,
select Refresh Group Info from the Group menu, then choose
the Full refresh option. The default refresh is a Quick
refresh, which checks for new or removed machines on the
network, but does not gather Diskeeper scheduling information
from remote machines.
19. A third type of account has been added to the Account
Information dialog. In addition to "Domain" and "Workgroup"
accounts, you can enter login information for "Local Admin".
This option is for System Administrators and I/T staff that
have a local username/password (with Administrator privileges)
on all their systems in the domain, rather than using a
Domain-wide username/password.
20. Changes have been made to the Diskeeper Administrator polling
process. Polling is now only performed on remote machines that
have been scheduled by Diskeeper Administrator for
defragmentation. Machines that have been independently
scheduled are no longer included in the polling process.
pour la pro, j'ai pas trouvé
Old 25-01-2004, 15:14
Spycam's Avatar
Spycam Spycam is offline
Spectre de ces lieux
Il y a une erreur pour le lien "Math", il pointe vers le téléchargement.
Old 25-01-2004, 15:21
corrigé :rolleyes:
Diskeeper 7 Build 430 Werner Actualité 9 16-07-2003 00:21
Diskeeper 7 Build 428 Werner Actualité 1 21-03-2003 18:23
Diskeeper 7 (build 422) Werner Actualité 1 21-11-2002 01:29
Diskeeper Lite v7.0 (build 418) Werner Actualité 5 20-10-2002 20:16
