Communauté Informatique NDFR.net : WinAmp 5 Beta 1 - Actualité
WinAmp 5 Beta 1
Old 17-10-2003, 09:11
Werner's Avatar
Werner Werner is offline
cOWboy attitUDe
WinAmp 5 Beta 1
Lien direct de la news : WinAmp 5 Beta 1
La beta 1 de WinAmp 5 est disponible depuis hier soir. La version finale devrait sortir au moins en deux versions dont une pro payante qui permettra le ripp rapide, la gravure et a priori la lecture de DVD.
Voici la "petite" liste des nouveautés (en anglais) :
* modern skin updates :
- fixed win98 crash with desktopalpha skins
- fixed pledit jumping on top of main window when docked and interacting with config drawer
- fixed avs hiding main window when docking to editor
- fixed vis gammagroup filtering
- fixed bgr color for pledit scrollbar background in v1.0 skins
- fixed rare crash on skinswitch
- added timers resolution autodetection
- added configuration of text scrolling speed
- added vis_cfg action to toggle vis cfg window via button
- fixed config drawer tabs moving the app when not selected
- added enable docking checkbox and docking distance editobox in prefs
- added tooltip checkbox in prefs
- fixed tooltip stealing focus from popup menus
- added support for noresize flag in embedwnd so that it spawns the right container
- added notransparency flag for embedwnd, made milkdrop use it
- fixed potential aot reset by embedwnd (ie, milkdrop)
- fixed slow text ticker, made it use timerclient_getSkipped to have consistent speed regardless of timer resolution
- added timer resolution in prefs page
- added link ratio & alpha in prefs page
- fixed empty popups in pledit menubar, commandbuttons and ml menubar when no playlist or devices are available
- fixed "mono" display when nothing playing, made songinfo update faster after clicking play
- separated link position & link width for main winshade window, changed default to link all
- removed move="1" for song title display on main window normal and shade modes
- fixed click on beatvis that would sometime fail to toggle active status
- added gammagroup xml param to vis objects
- made switching to windowshade open undocked video & vis when video is playing or vis is visible, docks back when coming back to normal mode
* made library able to update info on files that dont support tag writing when tag writing is checked
* fixed burning bug when using certain .WAV output settings
* enabled burning on multiple devices simultaneously
* made Winamp check to see if AVS or milkdrop is running fullscreen before starting video playback, and remove
fullscreen if necessary
* made AVS and Milkdrop check for video playback before going fullscreen (milkdrop uses fake mode, AVS complains)
(to avoid DirectDraw crash)
Vous pouvez télécharger WinAmp 5 Beta 1 sur cette page.
Source : WinAmp-FR.com (Entre autres...)
Old 17-10-2003, 10:09
stan's Avatar
stan stan is offline
Touriste professionnel
Re: WinAmp 5 Beta 1
Merci de l'info.
Je suis en train de la tester, elle a l'air pas mal , et au moins elle fonctionne chez moi, pas comme la 2.91 qui ne veut plus rien savoir
Old 17-10-2003, 12:47
Re: WinAmp 5 Beta 1
le skin de la news a l'air pas mal, ça changera du skin moche des versions précédentes...
Est-ce que y a tjs des dizaines de petis modules avec chacun leur fenêtre ?
Old 17-10-2003, 14:01
darkwafr darkwafr is offline
Send a message via MSN to darkwafr
Re: WinAmp 5 Beta 1
hello à tous
Format, merci de ce petit clin d'oeil et de cette news tout ça
juste un truc, quand les sites disent "la gravure et a priori la lecture de DVD" ...ben
je rajouterai juste que
En version gratos la gravure ne marche pas, l'encodage en AAC non plus en mp3 tres moyen ( gruge obligatoire"
quand à la lecture des DVD, c'est pas prévu pour l'instant, rien n'est décidé
j'ai les beta testeur qui sont sur la version beta 5 et ..pas de DVD pour l'instant
commentaire perso : de faire un produit payant c'est pas tres malin vu la concurrence.
Par contre cette version est tout de meme tres legere, a la robustesse du noyau de winamp 2 donc c'est chouette ...vivement la finale en novembre
A+
Old 17-10-2003, 14:17
MrDaweb MrDaweb is offline
Re: WinAmp 5 Beta 1
C'est clair qu'il faut mieux sortir un produit gratuit tout en faisant couler la boite...
Je trouve le principe d'une version gratuite, puis d'une version payante qui apporte certains fonctions en plus très bon...
Perso pour le gravure, y a Nero, pour l'encodage, des produits bien plus adaptés (CD Ex...)
Et pour le DVD, platine de salon
Old 17-10-2003, 14:53
bargio's Avatar
bargio bargio is offline
Assassin de Spaghettis
Re: WinAmp 5 Beta 1
Ca faisait très longtemps que je l'attendais, mais franchement avec itune qui est sorti hier, qui est totalement gratuit et d'une érgonomie exceptionnelle (et puis surtout bonheur : fini les micro blancs entre les chansons comme avec winamp2), je ne vais même pas essayer de le télécharger ce logiciel
Seb
Old 17-10-2003, 17:53
Fred's Avatar
Fred Fred is offline
00 Agent
Re: WinAmp 5 Beta 1
L'interface ressemble pas mal à WMP9, c'est un peu domage ...
... non Gaston
Old 17-10-2003, 18:19
Re: WinAmp 5 Beta 1
Seb
Lol, mais il est pas mal! avec pleins d'animations dedans!!!
Old 18-10-2003, 01:23
Re: WinAmp 5 Beta 1
bon ergonomie ça se vaut, pour les microblancs, winamp peut les éviter, depuis la version 2.90 ça fait 6 mois qd meme ...
et t'as raison essaye pas de la télécharger, ça pourrait te faire craquer
euh sans etre méchant t'as pas bien compris MrDaweb
> on coule pas une boite, AOL c'est un peu autre chose que winamp je te rapelle
>on parle pas des logiciels à côté ici le challenge est de faire marcher directement. j'attends de voir ce que ça donne car je pense que ça peux s'averer tres pratique. et pour cdex : mort de rire je suis : le CDDB de winamp est plus précis..et l'encodeur de cdex...c'est la meme dll que celle de winamp alors j'aime bien ton produit adapté
pour la lecture des DVD, t'as pas bien compris mais bon..je suppose que tu voulais dire "moi j'ai power DVD auquel je suis super habitué...." et je te réponds : certes, de toute façon c'est pas sur que winamp se charge des dvd et si ça s'avere vrai, ben...on a pas encore vu
Old 18-10-2003, 02:06
bargio's Avatar
Re: WinAmp 5 Beta 1
Pour les micros blancs, faudra qu'on m'explique alors parce que j'ai la version 2.91 je crois chez moi et j'ai toujours les micro blancs, j'utilise peut etre pas l'option qu'il faut...
Et sinon niveau ergonomie, désolé, mais la gestion des playlist est catastrophique sous winamp et c'est un vrai bonheur sous iTune... Au moins on a des tags qui servent à quelque chose...
Seb
Old 18-10-2003, 12:37
Re: WinAmp 5 Beta 1
hello bargio
non je suis pas tout à fait d'accord avec toi. les playlists sont une merveille à gerer, c'est comme tout c'est une question d'habitude
que ce soit dans la fenetre des playlist, je trouve ça super simple, et dans la médiatheque l'importation est super agréable !!
alors explique moi mieux, mais je repete je poense que c'est une question d'habitude
ps pour les micro blancs, normalement une installation neuve les enleve mais voici comment les regler de façon fine
http://www.winampfr.com/plugins/pas_...ondu/fondu.php
(à moins que ce soit pas ça que tu veilles dire...
A bientôt
Old 20-10-2003, 20:31
Re: WinAmp 5 Beta 1
Eheh Winamp 5 a voir a voir, mais bon je vais tester iTunes vu que j'en entends que du bien
Foobar 0.8.1 beta 3 - WinAmp 5.03a LeMoi Actualité 0 01-04-2004 01:12
Winamp 5 beta 2 streets Actualité 0 29-10-2003 01:42
Office 2003 Beta 2 Technical Refresh Werner Actualité 1 24-06-2003 16:34
WinAmp 2.90 Beta & WinAMP 3 Build 498 Werner Actualité 16 03-04-2003 05:02
Béta test d'Office 11 ZK' Actualité 8 26-10-2002 15:47
