Communauté Informatique NDFR.net : Winamp 5.12 sort... et sait lire la TNT - Page 2 - Actualité
Old 31-01-2006, 00:24
Pfuit... Winamp 5.13 et un nano-changelog
Changelog
Whats new:
* Fixed [in_mp3] extremely critical security vulnerability
Télécharger Winamp 5.13 Full (5.2 Mo)
Télécharger Winamp 5.13 Lite (875 Ko)
Old 31-01-2006, 09:35
streets's Avatar
streets streets is offline
KiLL BiLL
merci pour le nano chang log :rolleyes:
edit:
Old 31-01-2006, 10:02
Une minute de retard, msieu 1for
Old 31-01-2006, 11:00
Tiens, j'avais même pas vu
Old 31-01-2006, 21:15
Et hop... Après la version 5.13, c'est au tour de Winamp 5.2 bêta de se faire patcher...
Donc, en gros, Winamp 5.2 Bêta build 393 vient juste de sortir avec les nouveautés/corrections suivantes
Changelog
* Fixes a memory leak when using playlist winshade mode in the modern skin
* Fixes in_mp3 security hole
* Added experimental skin-colored icons to media library tree
* Changed the "Devices" parent node (in media library) to "Rip & Burn"
* Portable Media Player fixes
* Miscellaneous fixes
Télécharger Winamp 5.2 Bêta build 393 Full (5.37 Mo)
Télécharger Winamp 5.2 Bêta build 393 Lite (1.05 Mo)
Old 10-02-2006, 23:32
et hop... Winamp 5.2 beta 427
Changes in version 5.20.427:
* New: [ml_pmp] Synchronization the Media Library with your portable media player Compatible with iPod, Creative, and Microsoft Plays For Sure devices
* New: [enc_aacplus] Coding Technologies aacPlus High Bitrate encoder available in Winamp Pro
* New: [enc_aacplus] aacPlus (HE-AAC) in MP4 container
* New: [enc_aacplus] Using Coding Technologies encoder for LC-AAC
* New: [in_mp3] gapless MP3 playback
* New: [installer] multi-user profile options
* New: [installer] remembers your previous installer settings
* New: [in_wave] in_wave 3.0
* New: right-to-left playlist display
* Improved: new ATF functions and tags
$repeat(x, count) - creates a string with x repeated count times
$lpad() - same as $pad, but adds padding to the left
$decode(...) - switch/case function. example: $decode($fileext(%filename%),MP3,MPEG-1 Layer 3,MP4,MPEG-4 Container,Other)
$IfStrEqual(string1,string2,result) - if string1 and string2 are equal, displays result. case insensitive
$IfStrEqual2(string1,string2,result,else) - if string1 and string2 are equal, displays result, otherwise displays else. case insensitive
%folder% - top level folder name of the file
* Improved: Stereo beat visualization for modern skins
* Improved: [in_midi] provides metadata to media library
* Improved: [in_mod] provides metadata to media library
* Improved: [in_mp3] unicode id3 tags
* Improved: [in_mp3] preliminary id3v2.4 support
* Fixed: broken playlist sorting
* Fixed: playlist problems with multi-line tags (e.g. %comment%)
* Fixed: shuffle with only one song in playlist
* Fixed: ghost seek slider appears if Winamp loses focus during seeking
* Fixed: video options from video window right-click context menu
* Fixed: playlist winshade international character support
* Fixed: fullscreen video display international character support
* Fixed: [enc_lame] bit reservoir
* Fixed: [enc_lame] cutoff of last frame
* Fixed: [gen_ff] playlist winshade memory leak
* Fixed: [gen_ff] GDI Object leak with Current Skin prefs page
* Fixed: [in_midi] not following winamp's title formatting options
* Fixed: [in_midi] reset button blocks further access to config
* Fixed: [in_mod] not following winamp's title formatting options
* Fixed: [in_mp3] incorrect version identification (showed 5.18 in 5.12)
* Fixed: [in_mp3] incorrect information shown for AAC+ files
* Fixed: [in_mp3] reading incorrect id3 comment tag
* Fixed: [in_mp3] sometimes failing to read last id3 frame
* Fixed: [in_mp4] loss of album art when modified metadata
* Fixed: [in_vorbis] not following winamp's title formatting options
* Fixed: [in_vorbis] registry usage (now multi-user profile safe)
* Fixed: [in_wave] 32bit floating point WAV playback distortion
* Fixed: [in_wm] changes made with Attribute Editor not updating in ML/Playlist
* Fixed: [vis_milk] missing files from distro (you can stop bugging us now, Rovastar
* Fixed: [vis_milk] 100% cpu usage when paused
* Updated: [enc_lame] LAME 3.97b2
* Updated: [gen_ff] FreeType 2.1.10
* Updated: [enc_aacplus] Coding Technologies aacPlus encoder v7.2.0a
Télécharger Winamp 5.2 Beta build 427 Full
Télécharger Winamp 5.2 Beta build 427 Lite
Old 15-02-2006, 23:57
gelflings gelflings is offline
Winamp 5.2 beta build 440
http://download.nullsoft.com/winamp/..._beta_full.exe
et avant la sortie (prévue pour le jeudi 23 dans la nuit.....winampfr.com va annoncer un truc ......(c'est assez fun !)
* New: [in_nsv] Using Coding Technologies AAC playback within NSV container
* New: gen_tray v1.0 (thanks DrO)
* Fixed: m3u playlist handling security vulnerability (thanks to NSFOCUS)
* Fixed: [gen_ff] regions on components don't work
* Updated: [gen_ff] libpng 1.2.8
Les gelflings sont zen...sauf quand on leurs prends le choux
Winamp 5.04 Toitoine Actualité 12 29-07-2004 09:32
WinAmp 5.0 Finale streets Actualité 50 26-12-2003 22:40
Après la RC2 la RC8 de WinAMP 5 Werner Actualité 8 21-11-2003 18:00
Winamp 5 beta 2 streets Actualité 0 29-10-2003 00:42
WinAmp 2.90 Beta & WinAMP 3 Build 498 Werner Actualité 16 03-04-2003 04:02
