Communauté Informatique NDFR.net : Sun xVM VirtualBox 1.6.0 - Actualité
Old 03-05-2008, 02:48
Lien direct de la news : Sun xVM VirtualBox 1.6.0
On peut finalement dire adieu à Innotek car Sun nous offre ce soir une nouvelle version de VirtualBox dont le nom a fusionné avec son ancien virtualisateur alias xVM.
Niveau nouveautés pour une version 1.6.0, on pourra noter la disponibilité du logiciel pour Solaris et surtout MacOS X après un très long état de stase en version bêta, le support du Seamless Mode pour les distributions Linux et Solaris, l'ajout de controlleurs SATA virtuels (jusqu'à 30 disques durs virtuels montable à chaud ! ) sans oublier un support experimental du PAE (Physical Address Extension).
Pour le reste du changelog c'est par ici :
Changelog
VirtualBox 1.6.0 (released 2008-04-30)
This version is a major update. The following major new features were added:
* Solaris and Mac OS X host support
* Seamless windowing for Linux and Solaris guests
* Guest Additions for Solaris
* A webservice API
* SATA hard disk (AHCI) controller
* Experimental Physical Address Extension (PAE) support
In addition, the following items were fixed and/or added:
* GUI: added accessibility support (508 )
* GUI: VM session information dialog
* VBoxHeadless: renamed from VBoxVRDP
* VMM: reduced host CPU load of idle guests
* VMM: many fixes for VT-x/SVM hardware-supported virtualization
* ATA/IDE: better disk geometry compatibility with VMware images
* ATA/IDE: virtualize an AHCI controller
* Storage: better write optimization, prevent images from growing unnecessarily.
* Network: support PXE booting with NAT
* Network: fixed the Am79C973 PCNet emulation for Nexenta guests
* NAT: improved builtin DHCP server (implemented DHCPNAK response)
* NAT: port forwarding stopped when restoring the VM from a saved state
* NAT: make subnet configurable
* XPCOM: moved to libxml2
* XPCOM: fixed VBoxSVC autostart race
* Audio: SoundBlaster 16 emulation
* USB: fixed problems with USB 2.0 devices
* MacOS X: fixed seamless mode
* MacOS X: better desktop integration, several look’n’feel fixes
* MacOS X: switched to Quartz2D framebuffer
* MacOS X: added support for shared folders
* MacOS X: added support for clipboard integration
* Solaris: added host audio playback support (experimental)
* Solaris: made it possible to run VirtualBox from non-global zones
* Shared Folders: made them work for NT4 guests
* Shared Folders: many bugfixes to improve stability
* Seamless windows: added support for Linux guests
* Linux installer: support DKMS for compiling the kernel module
* Linux host: compatibility fixes with Linux 2.6.25
* Windows host: support for USB devices has been significantly improved; many additional USB devices now work
* Windows Additions: automatically install AMD PCNet drivers on Vista guests
* Linux additions: several fixes, experimental support for RandR 1.2
* Linux additions: compatibility fixes with Linux 2.6.25
Sun xVM Virtualbox 1.6.0 est donc officiellement multiplateforme, disponible sous Windows, MacOS X (Processeurs Intel uniquement) et toutes les distributions dérivées d'Unix.
Télécharger sun xVM Virtualbox 1.6.0 Multilangues
Old 06-06-2008, 20:53
Sun xVM VirtualBox 1.6.2
Lien direct de la news : Sun xVM VirtualBox 1.6.2
1ère version de maintenance pour le logiciel de virtualisation récemment tombé sous la tutelle de Sun Microsystem, j'ai nommé VirtualBox.
Dans cette version 1.6.2, Sun se permet de faire quelques corrections sur les nouveautés apportées par la branche 1.6 : Les performances du SATA sous Vista, la compatibilité avec le kernel 2.6.26 ou encore quelques problèmes de crash du module virtualbox sous Linux.
Changelog
VirtualBox 1.6.2 (released 2008-06-06)
This is a maintenance release. The following items were fixed and/or added:
* GUI: fixed a bug which prevented to add more than one SATA drive from the GUI
* GUI: fixed a regression introduced in 1.6.0: the fullscreen mode was left on every guest video mode switch
* GUI: fixed several minor issues
* Networking: fixed a host interface networking regression introduced in 1.6.0
* VMM: fixed starting of VMs with AMD-V enabled
* VMM: massive performance enhancements for AMD-V
* VMM: stability improvements for AMD-V on Windows hosts
* VMM: correctly detect AMD CPUs with erratum 170 (AMD-V)
* VMM: detect inconsistent timestamp counters on certain AMD Phenom CPUs (Windows host only)
* VMM: fixed KVM check (Linux hosts only) XPCOM: fixed several races
* VMM: fixed a regression introduced in 1.6.0: Windows stuck during installation
* SATA: improved performance with Vista guests
* SATA: fixed statistics counter
* Shared Folders: several fixes (iTunes download, speed up browsing)
* ATA/IDE: fixed boot from CDROM if a medium was added while the boot menu was active
* Networking: provide an Intel PRO/1000 T Server (82543GC) network device emulation which is recognized by Windows XP guests
* Networking: fixes for the E1000 emulation (don't crash if not attached, fixed a bug in the statistics counter implementation)
* NAT: don't crash if the guest sent a DHCPRELEASE message with an invalid IP address
* NAT: fixed ARP reply for the NAT gateway and for the NAT name server if the guest IP range was changed
* Internal Networking: fixed shutdown if more than two VMs are connected to the same network
* BIOS: allow to change the DMI informatiton (see chapter 9.13, Con'guring the BIOS DMI information, page 125)
* RTC: fixed UIP emulation to prevent jumping of time in Solaris guests
* Windows host: VirtualBox installation directory corrected for 64 bits Windows
* Windows host: fixed VBoxVRDP.exe symlink
* Windows host: solved locking problems in raw partition VMDK support
* Windows host: fixed stability during high system load (page fault in KeQueryActiveProcessors)
* MacOS X host: fixed crashes under certain conditions
* Shared Folders: limited users without admin rights now also can use Shared Folders on Windows guests
* Linux hosts: fixed default runlevel for the kernel module helper script
* Solaris hosts: enabled support for VT-x and AMD-V
* Solaris hosts: dynamic loading of libdlpi fixes a problem where Solaris 10 was not able to start a VM
* Linux additions: fixed runlevels for kernel module helper scripts
* Linux additions: compatibility fixes with Linux 2.6.26
* Linux additions: fixed occasional guest kernel crash during unload of the vboxadd guest kernel module
Sun xVM Virtualbox 1.6.2 est multiplateforme, disponible sous Windows, MacOS X (Processeurs Intel uniquement) et toutes les distributions dérivées d'Unix.
Télécharger Sun xVM Virtualbox 1.6.2 Multilangues
Old 01-08-2008, 22:09
Sun xVM VirtualBox 1.6.4
Lien direct de la news : Sun xVM VirtualBox 1.6.4
2ème mise à jour pour le logiciel de virtualisation de Sun qui nous revient en version 1.6.4.
Au sommaire de cette nouvelle version : des corrections de bugs, encore des corrections de bugs, une petite amélioration et enfin... d'autres corrections de bugs.
C'est vague je sais
Voilà qui est plus explicatif :
Changelog
VirtualBox 1.6.4 (released 2008-07-30)
* AMD-V, VT-x: stability fixes
* Shared Folders: fixed host crash (Solaris host only, bugs #1336, #1646)
* Shared Folders: fixed BSOD when debugging with Visual Studio (bug #1627)
* Shared Folders: fixed BSOD when compiling on a shared folder (bug #1683)
* Shared Folders: several fixes/stability improvements
* SATA: fixed a race that could cause an occasional Windows guest system hang
* SATA: fixed spurious BIOS log messages
* Networking: fixed NIC tracing with NAT interfaces (bug #1790)
* USB: fixed crash under certain conditions when unplugging a USB device (bug #1295)
* Settings: fixed bug when converting 1.5.x settings
* RDP: fixed enabling the RDP server during runtime
* RDP: properly detect the rdesktop 1.6.0 RDP client
* RDP: fixed RDP crash (bug #1521)
* RDP: updated modified rdesktop client to version 1.6.0
* GUI: NLS improvements
* BIOS: added SMBIOS header to make Solaris and Vista recognize the DMI data
* ACPI: properly hide a disabled floppy controller
* VMM: small fixes to protected mode without paging
* VMDK: fixed handling of .vmdk images without UUIDs
* Windows hosts: fixed driver parameter validation issue in VBoxDrv.sys that could allow an attacker on the host to crash the system
* Windows hosts: installer now contains web service examples mentioned in the manual
* Linux hosts: properly deregister the Linux kernel module before uninstalling a Linux deb/rpm package
* Linux hosts: kernel module works now with Linux 2.6.27
* Linux hosts: fixed a typo in the vboxnet setup script for host network interfaces (bug #1714)
* Linux hosts: fixed usage of tar in installer (bug #1767)
* Linux hosts: fixed long guest shutdown time when serial port is enabled
* Solaris hosts: refuse to install in Sun xVM hypervisor dom0
* Solaris hosts: accept Solaris raw disks when for raw disk access
* Windows additions: made installation of shared folders more robust
* Windows additions: improved installation
* Linux additions: accept every user-defined guest video mode in /etc/X11/xorg.conf
* Linux additions: fixed startup order for recent Linux distributions (e.g. openSUSE 11)
Interessé ? Voilà le lien de téléchargement pour toutes les plateformes
Télécharger Sun xVM Virtualbox 1.6.4
Old 03-09-2008, 20:49
Sun xVM Virtualbox 1.6.6
Lien direct de la news : Sun xVM Virtualbox 1.6.6
Voilà la 3ème version de maintenance de virtualisateur de Sun, qui sort en version 1.6.6.
Au sommaire, corrections de bugs et de rares petites nouvelles fonctionnalités...
changelog
VirtualBox 1.6.6 (released 2008-08-26)
* VMM: fixed excessive logging (bug #1901)
* VMM: AMD-V stability fixes (bug #1685)
* GUI: added support for Ctrl+Caps reversed keyboards (bug #1891)
* SATA: fixed BSODs of Windows guests on a SATA disk (bug #1941)
* SATA: fixed hard disk detection on Solaris 10 U5 (bug #1789)
* VBoxHeadless: don’t start the clipboard service (bug #1743)
* VBoxHeadless: added -vrdp parameter which allows to start the VM session without VRDP (bug #1960)
* VBoxManage: fixes to creating raw disk/partition VMDK files, now accepts removable media on Windows (bug #1869)
* VRDP: fixed communication with MS Remote Resktop Connection on MacOS X (bug #1337)
* VRDP: clipboard fixes (bug #1410)
* VRDP: fixed crash during PAM authentication (bug #1953)
* Shared Folders: fixed a regression introduced in version 1.6.2: the shared folders service was sometimes not properly installed (Windows guests only, bug #1915)
* Shared Folders: don’t deny to load a VM if a shared folder is not accessible (bug #822)
* BIOS: allow to specify empty DMI strings (bug #1957)
* OSE archive: added missing Makefiles (bug #1912)
* Linux hosts: workaround for buggy gcc-4.3 compilers (e.g. openSUSE 11)
* Linux hosts: one more fix for compiling the kernel modules on Linux 2.6.27 (bug #1962)
* MacOS X hosts: shared folders unicode fix
* Solaris hosts: fixed link issue (bug #1840)
* Windows additions: allow to downgrade the package
* Windows additions: fixed corrupted installer icon on Windows 2000 (bug #1486)
* Windows additions: fixed bug when creating intermediate directories (bug #1870)
* Windows additions: implemented /xres=, /yres= and /depth= switches for the installer (bug #1990)
* Linux additions: properly unregister the misc device when unloading the kernel module
* Linux additions: fixed startup order for recent Linux distributions again (e.g. openSUSE 11)
* Linux additions: attempt to fix the autostart issue of !VBoxClient with Mandriva guests (bug #1699)
* Linux additions: fixed detection of patched Linux 2.6.18 kernels of RHEL5 / FC6 / CentOS 5.2 (bugs #1899, #1973)
* Linux additions: added new mount flags dmode, fmode, umask, dmask and fmask allowing to override the file mode (bug #1776)
* Documentation: added a note that jumbo frames don’t work (bug #1877)
* Documentation: document special host interface names on openSUSE11 (bug #1892)
Et voilà, pour le téléchargement, le choix se fait de nouveau sur le site de Virtualbox, fini les passages par le site de Sun. A noter que les dépôts debian-based sont de nouveau disponibles.
Télécharger Sun xVM VirtualBox 1.6.6
Old 04-09-2008, 20:13
Tilt56 Tilt56 is offline
Bonsoir,
VirtualBox est proposé en version 2.0 aujourd'hui.
sun, virtualbox, virtualisation, xvm
VirtualBox 1.5.0 1for-matik Actualité 10 20-02-2008 21:07
VirtualBox 1.4.0 1for-matik Actualité 4 06-06-2007 23:53
VirtualBox 1.3.4 : Nouveau challenger dans le monde de la virtualisation ? 1for-matik Actualité 3 15-03-2007 17:08
