Messenger Plus! Live 4.00
#16
oui c'est la 235 que j'ai telechargé
#17
alOrs mOi j'ai un piti sOucis ^^ càd que j'ai installé windows live messenger + messenger plus live 235 et quand je me connecte sur ma session msn j'ai mon pseudo qui n'est pas en cOuleur ainsi que ceux de mes contacts... pOurtant dans la barre j'ai bien " plus "
Que faire ? aidez mOi au plus vite merci beaucoup:rolleyes:
#18
D'après ce que j'ai vu, les codes de couleurs ont changé sur Messenger Plus! Live.
Plus de codes farfelus en $%''`` etc etc... mais de jolies balises styles BBCode ( exemple : [c=blue]Texte[/c] ) Donc va falloir refaire les codes de couleurs
#19
Une nouvelle version de Messenger Plus! Live vient de sortir. Il s'agit de la version 4.01.240 qui serait compatible avec l'interopérabilité Yahoo! Messenger.
Changelog * Scripts: added Contact::Network property to identify contacts from Yahoo Messenger * Messenger Plus! Live now refuses to start on previous beta versions of Windows Live Messenger * Added compatibility for the "Clean Messenger" patch * Clicking "Apply" in the preferences to select a new language closes the preferences window to make sure the changes are applied properly * More resistant to Smiley Central, although if you install or uninstall it after Messenger Plus! Live, you'll have to reinstall Messenger Plus! afterwards * Emotion sounds are not played when another user is current logged in Windows * "Auto replace" quick texts enclosed in ## characters now work properly for text smaller than 3 characters * The Messenger Lock preference's section has been reorganised * Every character entered while the command helper window is displayed is properly inserted in the edit window * The Quick Icons panel is back! this was initially planned for version 4.10 but all your messages convinced me that I couldn't delay this feature anymore * The panel now has a fixed size and provides a scrollbar to navigate in your list of emoticons. It loads faster this way and helps keeps things organized * Custom emoticons are rendered a little bit bigger than before to help recognition (as 6 foot tall emoticons seems to be the trend nowadays) * You now have an option to replace Messenger's emoticon panel by the Quick Icons one (when clicking on the emoticon icon in the toolbar or pressing Ctrl+E) * Customization of the panel is much easier and understandable than before. You can create as many customised sections as you want , each with their own names. Use this to group emoticons by theme, frequency of use, etc.. * Fixed: closing the sound panel while a sound is being loaded for preview can crash Messenger * You can now choose to display 20 sounds at a time in the sound panel * Scripts: Menu buttons now generate CtrlClicked events * Scripts can now be installed in Windows Vista and on limited Windows XP accounts (remember that Vista support is still experimental though) * Scripts: LstBoxSelChanged and LstBoxDblClicked events are properly generated * Global shortcuts can now be associated to personalized statuses * Double clicking on a script pack or a sound pack in Windows Vista works properly (in Vista, it currently requires administrator privileges, you can bypass it by importing the files directly from the Messenger Plus! windows). If you still fail to import a * Fixed: commands or scripts that send messages while a message is already typed in the edit window causes emoticons to be lost * Scripts: the Messenger::MyName property can be changed even when the user is using a personalised status with a name tag * Scripts: the OnEvent_ContactMediaChange and OnEvent_MyMediaChange events are fired when the media is removed * Fixed: audio and video requests are not automatically accepted when "Auto Accept" is enabled * Fixed: Messenger is not launched properly with MSN Explorer when Messenger Plus! Live is installed * Compatible with MSNP14 (currently enabled when you sign-in for Yahoo Messenger interoperability). Messenger Plus! can now interact with Yahoo Messenger users exactly like it interacts with Windows Live Messenger users (remember however that your Yahoo use * Fixed: very short emotion sounds sometimes don't "stop" and the link doesn't change to Play when the sound has ended http://www.msgpluslive.net/download/
#20
Hop c'est parti pour Messenger Plus! Live 4.10 qui nous reviens avec les nouveautés suivantes :
Changelog Messenger Plus! Live 4.10.250 (11/11/2006) * Compatible with the public beta version of Windows Live Messenger 8.1 (can't be sure about the final but it should be alright). * Supported internal registry settings are now documented on msgpluslive.net. This gives access to more than 20 different kind of settings to the most hardcore Messenger users. * Commands are now recognized even when some characters are automatically replaced by custom emoticons. * The search feature in the sound panel can now display multiple pages and does not display "get random sound" entries. * Added an internal message to help skinning applications interact with Messenger Plus!. * Quick texts now always properly parse emoticon codes. * Enabled scripts are now displayed first in the preferences panel. * Floating contact windows can now be hidden for a couple of seconds when clicking with the middle mouse button on them. Useful when you want to temporarily access something that's behind the windows. * If Messenger crashes when started, every installed script is disabled as a precautionary measure and a message is displayed. * Added Arabic language with full right-to-left support. Every window in Messenger Plus! is properly mirrored when this language is selected (as long as support for RTL languages is installed in your Windows). * Fixed: the XML event log file can be corrupted by new external mail events depending on the language file Messenger Plus! is using. * Fixed: event notifications and sounds don't work properly with Remote Desktop. * Fixed: the setup displays a system error instead of a user friendly error when launched on Windows 2000. * Fixed: Messenger may crash the first time a user signs-in after installing Messenger Plus! if old external mail settings are imported from Messenger Plus! 3. * Fixed: no overwrite message is displayed when saving a display picture file from the Contact Info window with an existing file name. * Fixed: contact names sometimes appear as "1" in the windows of Messenger Plus! when Yahoo Interop is activated. * Fixed: no more unnecessary extra space character when inserting bbcode tags with a keyboard shortcut. * Fixed: scripts can't be imported when the Scripts directory does not exist. * Fixed: Quick Icons panel doesn't display when a parenthesis is typed after a carriage return has been inserted in the message. * Fixed: receiving multi-line messages with plain-text chat logging turned on can freeze Messenger. * Fixed: commands don't work in quick texts that contain smart tags (like (!N)). * Fixed: false name change notifications in the event viewer for Yahoo Messenger contacts upon signin. * Fixed: on systems with several screens, Messenger Plus! windows that are minimised on smaller screens sometimes restore bigger than they should. * Fixed: Messenger Plus! can mix-up the settings of different contacts who have very similar email addresses. * Scripts: added Messenger::CustomEmoticons property to access the custom emoticons of the current Messenger users. * Scripts: added "Emoticons" and "Emoticon" objects. They are both pretty straightforward to use (see documentation). * Scripts: an error is now logged in the Script Debugging window when an exception is thrown in Interop.Call. * Scripts: when importing a script that's already installed, if some files are locked in the script's directory, Messenger Plus! restarts Messenger to unlock the files and complete the installation procedure (can be useful in cases where an ActiveX is loaded and refuses to unload when the script is stopped). * Scripts: added EnterPersonalizedStatus and LeavePersonalizedStatus events to notify when the user activates or disables a personalised status. * Scripts: added PlusWnd::RegisterMessageNotification. This new function can be used by more advanced scripters who want to receive specific messages processed by their windows. * Scripts: DataBloc:GetAt and DataBloc:SetAt use unsigned values now. * Scripts: sending WM_SETTEXT to an interface window changes both the caption and the title of the window. * Scripts: Interop.GetLastError() now works properly (see documentation). * Script: Interop.Call and Interop.Call2 now accept parameters ranging from 0x80000000 to 0xFFFFFFFF. * Scripts: added a flag to MsgPlus::CreateWnd to allow the creation of RTL windows. * Scripts: .NET 2.0 assemblies are now registered properly even when .NET 1.0 or 1.1 is also installed in the system. * Scripts: added ChatWnd::AddContact() to invite contacts to join existing chats. * Scripts: a special error is logged in the debug window when Interop.Call is used on functions that are not declared as __stdcall. Script developers: do NOT ignore these errors, they will cause instabilities and eventually crash Messenger in random places. * Scripts: creation of a new application called "Interface Tester". It allows script developers to test their interface files and preview the result as when loaded in Messenger Plus!. It can also validate xml files against the interface schema file. The software can be downloaded from a link in the new version of the Scripting Documentation. * Several other internal improvements. Télécharger Messenger Plus! Live 4.10
#21
#22
4.01, donc moins récente que 4.10
#23
dsl , je ferais plus attention la prochaine fois
#24
Sortie de la version 4.11.254
Changelog * Messenger Plus! now always works properly when a SOCKS server is configured in the Messenger options (can happen when installing other add-ons such as SimpLite-MSN). This fixes problems with contact events not being detected. * Every Messenger process launched in the system is now terminated if necessary during setup to prevent "file locked" problems. * Fixed: Messenger crashes if a script or a sound pack is attempted to be imported while Messenger Plus! has not been loaded properly (when the "Software Not Loaded" menu is present). * Fixed: some preferences may not be loaded and scripts may not be started when Messenger is launched automatically by another product such as Windows Live Mail. * Fixed: messages sent with multiple lines are not logged properly in Messenger 8.1 in XHTML logs (line breaks were not written properly). * Fixed: scripts that throw an exception during a DLL function call may crash Messenger if the scripting debug window is not displayed. This caused some scripts that seemed to work fine in version 4.00 to crash with version 4.01 and 4.10. * Fixed: the AlwaysReloadInterfaces registry setting does not function properly. * Scripts: parameters ranging from 0x80000000 to 0xFFFFFFFF can now be passed to Interop.Call without the need for an extra workaround. * Scripts: "null" values can now be passed to Interop.Call and are interpreted as "0" (integer). * Scripts MsgPlus.Version returns a better floating point value (see update in documentation). Télécharger Messenger Plus! Live 4.11.254
#25
g un pb avec la toute nouvelle version messenger plus live
J'ai installer messenger plus live 411, il fonctionne correctement. Mais une fois que je redémarre mon pc l'installation a disparut et je suis obligé de réinstaller. Pouvez vous m'aider svp !!! merci
#26
#27
Messenger Plus! Live 4.20
Lien direct de la news : Messenger Plus! Live 4.20
C'est aujourd'hui 1er Mars 2007 que Patchou vient de sortir la mise à jour de Messenger Plus ! Live 4.20.
Dans les nouveautés tant attendus, la compatibilité avec Windows Vista (de manière complète hein )Par exemple : le bug des fenêtres de conversation groupées (sous forme d'onglets) qui ne clignote pas dans la barre des tâches à l'arrivée d'un nouveau message. Changelog * Various visual adjustments for Windows Vista. Some of them are dependant of your system's configuration and theme settings. This includes, but is not limited to: * Animation effects when most Messenger Plus! windows open and close. * Fixed "black box" display glitch when resizing Messenger Plus! windows. * Drop-down lists (combo boxes) in Messenger Plus! windows look better. * Most "open file" and "save file" windows use the new Vista template. * No more sluggish transition effects on some of the controls when the mouse pointer passes over them. * Some windows do not display properly with right-to-left languages. * Tabbed chats don't create an empty area in Flip3D. The chat window is not part of the flip sequence but is displayed in the background. This may be improved in future releases but it all depends on the (rather limited or undocumented) new DWM API of Windows. Le reste du changelog Télécharger Messenger Plus! Live 4.20
#28
Dans les nouveautés tant attendus, la compatibilité avec Windows Vista (de manière complète hein )Par exemple : le bug des fenêtres de conversation groupées (sous forme d'onglets) qui ne clignote pas dans la barre des tâches à l'arrivée d'un nouveau message.[/QUOTE] ^^
#29
"Il y a au moins deux solutions à un problème "![]() "Internet tue des bébés loutre" Last edited by Benjy; 12-06-2008 at 11:36. |
#30
Messenger Plus! Live 4.22.274 arrive avec la prise en charge de Messenger 8.5.0517 en beta pour le momment.
Messenger Plus! Live 4.22.274 (01/06/2007)
| Tags |
| messenger, messenger plus, messenger plus live, msgpluslive, msn, msn live, msn plus live |
| Windows Live Messenger 8.0 Final | 1for-matik | Actualité | 54 | 27-11-2009 21:47 |
| Windows Live Messenger (ou MSN 8) | Slifer000 | Windows Vista | 61 | 29-06-2006 13:07 |
| MSN Messenger et Hotmail, c'est fini... | 1for-matik | Actualité | 19 | 07-11-2005 00:28 |
| Messenger Plus! 3.51.128 | Steven | Actualité | 7 | 24-05-2005 19:52 |
| MSN MESSENGER [aide...] | chalouf | Logiciels | 10 | 29-04-2003 13:30 |
