WinRAR 3.60 Bêta
WinRAR 3.60 Bêta
Hop, nouvelle version, nouveau topic.
Aujourd'hui (ou on va plutôt dire hier) est sorti la 1ère version beta de WinRAR 3.60. Pour rappel, gnagnagnagnagna... l'un des meilleurs logiciel de compression... bref ![]() Changelog Que celui qui trouve que j'abuse de la fonction changelog me le dise Version 3.60 beta 1 1. Multithreaded version of RAR compression algorithm improves the compression speed on computers with several CPU, dual core CPU and processors with hyperthreading technology. Multithreading is enabled by default, but you can disable it in "General" part of "Settings" dialog. In the command line mode you can control multithreading with -mt switch. 2. WinRAR can display the folder tree panel allowing to navigate in disk and archive folders. Use "Options/Folder tree" submenu to enable the folder tree. It can be configured separately in file and archive management modes. Folder tree replaces "Browse for folder" command previously available in "File" menu and uses its Ctrl+T keyboard shortcut. 3. Now WinRAR "Rename" command also works with ZIP archives. Previous versions could rename files only in RAR archives. 4. Added decompression of LZH archives created with "-lh7-" algorithm. 5. New "Remove duplicate folders from extraction path" option in "Settings/Compression" dialog. If this option is on and you unpack an archive which root folder has no files and only one 'somename' folder and if destination folder is new or empty and also ends with '/somename', WinRAR will exclude one 'somename' from resulting 'somename/somename' path. 6. New "Define volume sizes..." button in "Settings/Compression". This button activates "Define volume sizes" dialog. Here you can customize the list of predefined volume sizes associated with "Split to volumes, bytes" field in archiving dialog. 7. Speed of RAR general compression increased for some data types. Depending on data type and size the gain may achieve 5 - 15%. 8. New "Rename automatically" option in the extraction dialog and command line -or switch to rename extracted files automatically if file with the same name already exists. You can also enable the auto-renaming mode directly from the overwrite confirmation prompt with "Rename All" button. Renamed files will get names like 'filename(N).txt', where 'filename.txt' is the original file name and 'N' is a number. 9. "Set modification time" option in "Advanced" part of extraction dialog is accessible also for ZIP archives. Previously it could be changed only for RAR archives. 10. "Multithreading" option added to "Benchmark and hardware test" command, so you can compare performance of usual and multithreaded versions of RAR compression algorithm. 11. New 'ch' (change archive parameters) command line mode command. Its purpose is to apply switches like -av, -tl and -cl to archive. 12. New 'cv' command line mode command. It provides the command line interface to WinRAR "Convert archives" command. It is supported only by winrar.exe, not by rar.exe. 13. New command line -sl and -sm switches to set size limits of processing files. 14. New command line -fcu[file] switch allows to read archive comments from Unicode files. It also modifies behavior of "cw" command, setting the comment output format to Unicode. 15. 7Z added to list of formats stored without compression when using -ms switch without a parameter. 16. Switch -e[+] is now supported by most of command line operations including extracting and deleting files. Previously it was supported by only archiving command. 17. It is allowed to use environment variables in archive name in archiving dialog, in destination path in extraction dialog, in folder names on "Compression" and "Paths" pages in WinRAR settings. For example, you can enter '%temp%' in "Folder for temporary files" field. ![]() ![]() ![]() N.B: Cette news n'a aucun besoin d'être publié dans la rubrique Actualités...
Idem :confused:
![]() Ca sert à rien... à moins que tu veuille quand même publier une news sur un logiciel en bêta ![]()
Le multithread dans WinRAR ça peut être bien sympa
![]() Vous en voyez beaucoup des logiciels de compression multithreadés ? Pourtant le processus s'y prête vraiment bien ...
![]() Quote:
J'ai fait quelques essais avec 7zip (article à venir sur mon futur site ![]() En fait, les softs de compression qui pourraient le plus bénéficier du multithreading sont ceux n'utilisant pas le concept d'archive solide (car alors le codage de chaque fichier est totalement indépendant de celui des autres, donc on peut paralléliser dès qu'il y a plusieurs fichiers), mais : - les archives solides sont généralement mieux compressées (logique, plus de redondance) - dans 7zip, je n'ai pas remarqué de différence de charge entre archive solide et archive non solide, donc ça n'a pas été prévu à l'implémentation, faudrait voir comment se comporte WinRar sur ce point. |
Je pensais aux archives non solides, effectivement. Dans le cas des archives solides, l'index est toujours mis à jour, c'est plutôt lourd mais ça peut donner quelques algos intéressants puisqu'on doit toujours compresser un flux de données, l'ordre n'a que peu d'importance. Après, tout dépend de l'algo de compression et en particulier de la génération des dictionnaires ...
Bon j'ai fait quelques tests avec mon modeste PIV 3.08 Ghz HT mode de compression BEST (pas solid ni autre)
dossier de 170 567 ko de png : winrar 3.5 : 2'39 163 413 ko winrar 3.6 : 2'16 163 411 ko dossier de 111 698 ko de ficher "texte" winrar 3.5 : 2'12 65 662 ko winrar 3.6 : 1'40 65 652 ko le gain de temps est donc loin d'être négligeable et on note même un faible gain au niveau de la taille ![]() je ferai le test sur un fichier unique, genre de 700mo. |
![]() Quote:
EDIT : bon ben j'ai fait un essai rapide, et en activant l'option solide. La charge CPU tourne à 88-89% en moyenne, avec des pointes à 95%. Donc il y a vraiment eu un très bon travail d'optimisation, et pas simplement une mise en parallèle de la compression de deux fichiers. Last edited by Matt; 06-04-2006 at 00:01. |
2'16 exactement pour le deuxième dossier multithreading off, donc y a apparamment un réel gain
![]() A noter que l'archive fait 65 659 ko, comprendra qui pourra ! |
Version 3.60 beta 6 1. Switch -ad did not work in GUI winrar.exe. 2. When repairing several archives, console RAR did not handle 'No' choice of overwrite archive request properly. It aborted the operation instead of skipping the current archive. ![]()
WinRAR 3.60 1. Multithreaded version of RAR compression algorithm improves the compression speed on computers with several CPU, dual core CPU and processors with hyperthreading technology. Multithreading is enabled by default, but you can disable it in "General" part of "Settings" dialog. In the command line mode you can control multithreading with -mt switch. 2. WinRAR can display the folder tree panel allowing to navigate in disk and archive folders. Use "Options/Folder tree" submenu to enable the folder tree. It can be configured separately in file and archive management modes. Folder tree replaces "Browse for folder" command previously available in "File" menu and uses its Ctrl+T keyboard shortcut. 3. Now WinRAR "Rename" command also works with ZIP archives. Previous versions could rename files only in RAR archives. 4. Added decompression of LZH archives created with "-lh7-" algorithm. 5. New "Remove duplicate folders from extraction path" option in "Settings/Compression" dialog. If this option is on and you unpack an archive which root folder has no files and only one 'somename' folder and if destination folder is new or empty and also ends with '/somename', WinRAR will exclude one 'somename' from resulting 'somename/somename' path. 6. New "Define volume sizes..." button in "Settings/Compression". This button activates "Define volume sizes" dialog. Here you can customize the list of predefined volume sizes associated with "Split to volumes, bytes" field in archiving dialog. 7. Speed of RAR general compression increased for some data types. Depending on data type and size the gain may achieve 5 - 15%. 8. New "Rename automatically" option in the extraction dialog and command line -or switch to rename extracted files automatically if file with the same name already exists. You can also enable the auto-renaming mode directly from the overwrite confirmation prompt with "Rename All" button. Renamed files will get names like 'filename(N).txt', where 'filename.txt' is the original file name and 'N' is a number. 9. "Set modification time" option in "Advanced" part of extraction dialog is accessible also for ZIP archives. Previously it could be changed only for RAR archives. 10. "Multithreading" option added to "Benchmark and hardware test" command, so you can compare performance of usual and multithreaded versions of RAR compression algorithm. 11. New 'ch' (change archive parameters) command line mode command. Its purpose is to apply switches like -av, -tl and -cl to archive. 12. New 'cv' command line mode command. It provides the command line interface to WinRAR "Convert archives" command. It is supported only by winrar.exe, not by rar.exe. 13. New command line -sl and -sm switches to set size limits of processing files. 14. New command line -fcu[file] switch allows to read archive comments from Unicode files. It also modifies behavior of "cw" command, setting the comment output format to Unicode. 15. 7Z added to list of formats stored without compression when using -ms switch without a parameter. 16. Switch -e[+] is now supported by most of command line operations including extracting and deleting files. Previously it was supported by only archiving command. 17. It is allowed to use environment variables in archive name in archiving dialog, in destination path in extraction dialog, in folder names on "Compression" and "Paths" pages in WinRAR settings. For example, you can enter '%temp%' in "Folder for temporary files" field. ![]()
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
WinRAR 3.50 Beta 1 | 1for-matik | Actualité | 19 | 09-08-2005 18:23 |
WinRAR 3.40 Beta 2 | Mytheuzen | Vos news | 4 | 07-07-2004 18:38 |
WinRAR 3.30 beta 5 | Kaspof | Actualité | 3 | 10-01-2004 00:26 |
WinRAR 3.30 Beta 4 | Werner | Actualité | 0 | 22-12-2003 14:43 |
Béta test d'Office 11 | ZK' | Actualité | 8 | 26-10-2002 14:47 |
