Communauté Informatique NDFR.net : WinRAR 3.60 Bêta - Vos news
WinRAR 3.60 Bêta
Old 01-04-2006, 02:18
WinRAR 3.60 Bêta
Hop, nouvelle version, nouveau topic.
Aujourd'hui (ou on va plutôt dire hier) est sorti la 1ère version beta de WinRAR 3.60.
Pour rappel, gnagnagnagnagna... l'un des meilleurs logiciel de compression... bref
Changelog
Version 3.60 beta 1
1. Multithreaded version of RAR compression algorithm improves
the compression speed on computers with several CPU,
dual core CPU and processors with hyperthreading technology.
Multithreading is enabled by default, but you can disable it
in "General" part of "Settings" dialog.
In the command line mode you can control multithreading with
-mt switch.
2. WinRAR can display the folder tree panel allowing to navigate
in disk and archive folders. Use "Options/Folder tree" submenu
to enable the folder tree. It can be configured separately
in file and archive management modes.
Folder tree replaces "Browse for folder" command previously
available in "File" menu and uses its Ctrl+T keyboard shortcut.
3. Now WinRAR "Rename" command also works with ZIP archives.
Previous versions could rename files only in RAR archives.
4. Added decompression of LZH archives created with "-lh7-" algorithm.
5. New "Remove duplicate folders from extraction path" option
in "Settings/Compression" dialog.
If this option is on and you unpack an archive which root folder
has no files and only one 'somename' folder and if destination
folder is new or empty and also ends with '/somename', WinRAR
will exclude one 'somename' from resulting 'somename/somename' path.
6. New "Define volume sizes..." button in "Settings/Compression".
This button activates "Define volume sizes" dialog. Here you
can customize the list of predefined volume sizes associated
with "Split to volumes, bytes" field in archiving dialog.
7. Speed of RAR general compression increased for some data types.
Depending on data type and size the gain may achieve 5 - 15%.
8. New "Rename automatically" option in the extraction dialog
and command line -or switch to rename extracted files automatically
if file with the same name already exists. You can also enable
the auto-renaming mode directly from the overwrite confirmation
prompt with "Rename All" button.
Renamed files will get names like 'filename(N).txt',
where 'filename.txt' is the original file name and 'N' is a number.
9. "Set modification time" option in "Advanced" part of extraction
dialog is accessible also for ZIP archives. Previously it could be
changed only for RAR archives.
10. "Multithreading" option added to "Benchmark and hardware test"
command, so you can compare performance of usual and multithreaded
versions of RAR compression algorithm.
11. New 'ch' (change archive parameters) command line mode command.
Its purpose is to apply switches like -av, -tl and -cl to archive.
12. New 'cv' command line mode command. It provides the command line
interface to WinRAR "Convert archives" command. It is supported
only by winrar.exe, not by rar.exe.
13. New command line -sl and -sm switches to set size
limits of processing files.
14. New command line -fcu[file] switch allows to read archive
comments from Unicode files. It also modifies behavior
of "cw" command, setting the comment output format to Unicode.
15. 7Z added to list of formats stored without compression
when using -ms switch without a parameter.
16. Switch -e[+] is now supported by most of command line
operations including extracting and deleting files. Previously
it was supported by only archiving command.
17. It is allowed to use environment variables in archive name
in archiving dialog, in destination path in extraction dialog,
in folder names on "Compression" and "Paths" pages in WinRAR
settings. For example, you can enter '%temp%' in "Folder for
temporary files" field.
Que celui qui trouve que j'abuse de la fonction changelog me le dise
Télécharger WinRAR 3.60 Bêta 1 en anglais (même pas 1Mo.... 1007 Ko)
Source : Fileforum
N.B: Cette news n'a aucun besoin d'être publié dans la rubrique Actualités...
Old 01-04-2006, 05:35
Non, non t'abuses pas, mais t'aurais pu le traduire ce changelog
Old 01-04-2006, 18:55
Mais pourquoooooiiii ? :rolleyes:
Old 01-04-2006, 19:27
Idem :confused:
Old 01-04-2006, 19:33
PARCEEEEEE QUEEEEEEEEEEEEEEEEE
Ca sert à rien... à moins que tu veuille quand même publier une news sur un logiciel en bêta
Old 04-04-2006, 18:50
Le multithread dans WinRAR ça peut être bien sympa
Vous en voyez beaucoup des logiciels de compression multithreadés ? Pourtant le processus s'y prête vraiment bien ...
Old 05-04-2006, 00:01
7zip
Bof ... Les algos de compression sont malheureusement relativement difficiles à paralléliser, parce qu'il y a pas mal de problèmes de synchronisation de données et car le codage est fortement dépendant de ce qui a été codé avant (c'est particulièrement le cas pour l'archivage de fichiers, nettement moins pour la compression de vidéo, où on peut quasiment paralléliser à 100% grâce aux frames clés).
J'ai fait quelques essais avec 7zip (article à venir sur mon futur site Matt, le roi du Vaporeware), y a des petites pointes à 70% de charge CPU (donc +40% par rapport à du single thread), mais en poyenne, ça tourne plutôt entre 55 et 60%.
En fait, les softs de compression qui pourraient le plus bénéficier du multithreading sont ceux n'utilisant pas le concept d'archive solide (car alors le codage de chaque fichier est totalement indépendant de celui des autres, donc on peut paralléliser dès qu'il y a plusieurs fichiers), mais :
- les archives solides sont généralement mieux compressées (logique, plus de redondance)
- dans 7zip, je n'ai pas remarqué de différence de charge entre archive solide et archive non solide, donc ça n'a pas été prévu à l'implémentation, faudrait voir comment se comporte WinRar sur ce point.
Old 05-04-2006, 00:09
whynot's Avatar
whynot whynot is offline
Par défaut (donc pour la majorité des utilisateurs) WinRAR n'utilise pas d'archive solide lorsqu'il compresse. D'ailleurs je trouve les archives solides chiantes car pour voir ne serait-ce qu'on .txt minable dans une archive de 200megs, il faut tout extraire. Ca doit vraiment être utilisé à des fins particulières à mon avis.
Old 05-04-2006, 07:20
Certes. Mais reste à voir s'ils ont implémenté la compression de deux fichiers en parallèle ou pas.
Old 05-04-2006, 19:10
Je pensais aux archives non solides, effectivement. Dans le cas des archives solides, l'index est toujours mis à jour, c'est plutôt lourd mais ça peut donner quelques algos intéressants puisqu'on doit toujours compresser un flux de données, l'ordre n'a que peu d'importance. Après, tout dépend de l'algo de compression et en particulier de la génération des dictionnaires ...
Old 05-04-2006, 19:55
Bon j'ai fait quelques tests avec mon modeste PIV 3.08 Ghz HT mode de compression BEST (pas solid ni autre)
dossier de 170 567 ko de png :
winrar 3.5 : 2'39 163 413 ko
winrar 3.6 : 2'16 163 411 ko
dossier de 111 698 ko de ficher "texte"
winrar 3.5 : 2'12 65 662 ko
winrar 3.6 : 1'40 65 652 ko
le gain de temps est donc loin d'être négligeable et on note même un faible gain au niveau de la taille
je ferai le test sur un fichier unique, genre de 700mo.
Old 05-04-2006, 23:56
Dis donc, il est pas à 2.8 officiellement ton P4 ?
Tu devrais aussi faire un test en vérouillant WinRAR 3.6 sur un seul des core virtuels, pour voir si le gain de temps est vraiment entièrement du au multithreading, ou s'il est aussi dû à d'autres améliorations de l'algorithme.
EDIT : bon ben j'ai fait un essai rapide, et en activant l'option solide. La charge CPU tourne à 88-89% en moyenne, avec des pointes à 95%. Donc il y a vraiment eu un très bon travail d'optimisation, et pas simplement une mise en parallèle de la compression de deux fichiers.
Old 06-04-2006, 00:04
2'16 exactement pour le deuxième dossier multithreading off, donc y a apparamment un réel gain
A noter que l'archive fait 65 659 ko, comprendra qui pourra !
Old 03-07-2006, 15:34
Version 3.60 beta 6
1. Switch -ad did not work in GUI winrar.exe.
2. When repairing several archives, console RAR did not handle 'No' choice of overwrite archive request properly. It aborted the operation instead of skipping the current archive.
Télécharger WinRAR 3.60 Beta 6 (Anglais, évaluation)
Old 18-08-2006, 18:49
WinRAR 3.60
-mt switch.
Page de téléchargement
WinRAR 3.50 Beta 1 1for-matik Actualité 19 09-08-2005 18:23
WinRAR 3.40 Beta 2 Mytheuzen Vos news 4 07-07-2004 18:38
WinRAR 3.30 beta 5 Kaspof Actualité 3 10-01-2004 00:26
WinRAR 3.30 Beta 4 Werner Actualité 0 22-12-2003 14:43
Béta test d'Office 11 ZK' Actualité 8 26-10-2002 14:47
