Winamp 5.2
Winamp 5.2
Lien direct de la news : Winamp 5.2
Et hop, c'est en ce jour de beau temps (en Alsace, tant pis pour les autres) que la nouvelle version de Winamp sort après nombre et nombre de Bêtas.
Alors en gros, qu'apporte-t-il de nouveau ? Eh ben la grosse nouveauté et peut-être bien le support en natifs des baladeurs numériques tels que l'iPod et autres Archos etc etc... Mais aussi une refonte complète de la librairie, l'ajout de nouveaux codec de compression audio (HE-AAC et toute la clique..) Bref maintenant le changelog * New: [ml_pmp] Synchronize your Media Library with your portable media player Compatible with iPod, Creative, and Microsoft Plays For Sure devices * New: [enc_aacplus] Coding Technologies aacPlus High Bitrate encoder available in Winamp Pro * New: [enc_aacplus] Coding Technologies aacPlus (HE-AAC) in MP4 container * New: [enc_aacplus] Coding Technologies LC-AAC encoder * New: [gen_ml] icons in treeview * New: [ml_online] Dynamic AJAX Internet Media Hub * New: [in_nsv] Using Coding Technologies AAC playback within NSV container * New: [in_mp3] gapless MP3 playback * New: [installer] multi-user profile options * New: [installer] remembers your previous installer settings * New: [in_wave] in_wave 3.0 * New: right-to-left playlist display * Improved: new ATF functions and tags, including: $repeat(x, count) - creates a string with x repeated count times $lpad() - same as $pad, but adds padding to the left $decode(...) - switch/case function. example: $decode($fileext(%filename%),MP3,MPEG-1 Layer 3,MP4,MPEG-4 Container,Other) $IfStrEqual(string1,string2,result) - if string1 and string2 are equal, displays result. case insensitive $IfStrEqual2(string1,string2,result,else) - if string1 and string2 are equal, displays result, otherwise displays else. case insensitive %folder% - top level folder name of the file * Improved: Stereo beat visualization for modern skins * Improved: [gen_ff] new vis modes available to skinners * Improved: [gen_ml] CD drive info view (Rip & Burn) * Improved: [gen_tray] gen_tray v1.0 (thanks DrO) * Improved: [in_midi] provides metadata to media library * Improved: [in_mod] provides metadata to media library * Improved: [in_mp3] unicode id3 tags * Improved: [in_mp3] preliminary id3v2.4 support * Fixed: broken playlist sorting * Fixed: playlist problems with multi-line tags (e.g. %comment%) * Fixed: shuffle with only one song in playlist * Fixed: ghost seek slider appears if Winamp loses focus during seeking * Fixed: video options from video window right-click context menu * Fixed: playlist winshade international character support * Fixed: fullscreen video display international character support * Fixed: m3u playlist handling security vulnerability (thanks to NSFOCUS and Information Risk Management Plc) * Fixed: [enc_lame] bit reservoir * Fixed: [enc_lame] cutoff of last frame * Fixed: [gen_ff] regions on components don't work * Fixed: [gen_ff] playlist & video focus bug * Fixed: [gen_ff] playlist winshade memory leak * Fixed: [gen_ff] GDI Object leak with Current Skin prefs page * Fixed: [in_midi] not following winamp's title formatting options * Fixed: [in_midi] reset button blocks further access to config * Fixed: [in_mod] not following winamp's title formatting options * Fixed: [in_mp3] incorrect version identification (showed 5.18 in 5.12) * Fixed: [in_mp3] incorrect information shown for AAC+ files * Fixed: [in_mp3] reading incorrect id3 comment tag * Fixed: [in_mp3] sometimes failing to read last id3 frame * Fixed: [in_mp3] id3v2 album art loss when editing tags * Fixed: [in_mp4] loss of album art when modifying metadata * Fixed: [in_vorbis] not following winamp's title formatting options * Fixed: [in_vorbis] registry usage (now multi-user profile safe) * Fixed: [in_wave] 32bit floating point WAV playback distortion * Fixed: [in_wm] changes made with Attribute Editor not updating in ML/Playlist * Fixed: [vis_milk] missing files from distro (you can stop bugging us now, Rovastar * Fixed: [vis_milk] 100% cpu usage when paused * Updated: [gen_jumpex] DrO's Jump To File Extension 0.97 * Updated: [enc_lame] LAME 3.97b2 * Updated: [gen_ff] libpng 1.2.8 * Updated: [gen_ff] FreeType 2.1.10 * Updated: [enc_aacplus] Coding Technologies aacPlus encoder v7.2.0a ![]() ![]() ![]()
Des problèmes ? Le chat NDFR est disponible. Des problèmes pour y accéder ? Voici le tuto. Le Best Of "QUOTES" du chan IRC: C'est par ici Sur n'1fo[r-matik] : Astuce : Activer le bloqueur de pub/tracking natif sur Firefox ![]() Last edited by 1for-matik; 16-03-2016 at 23:52. |
Support de l'iPod ?
C'est Apple qui va encore râler ![]() Avec une version comme celle-ci, je vois très peu de barrières qui empècherait un iPodiens de changer son vieu lecteur mp3 iTunes ;p Bravo pour l'information !
Mais ta remarque a du sens. Maintenant que l'iPod (et quasiment tous les autres lecteurs mp3 du marché) est supporté deubaze dans Winamp, ça devrait faire encore plus de bruit...
Et en plus il est modeste... Sinon moi j'ai un souci sans le patch bah il est en FR mon winamp ^^ mais bon c'est pas bien grave xD
H@kk@s
Normal que ton winamp soit en français si tu as fait une installation directement sur la version 5.12 + son patch fr. On pourrait voir une nouvelle version 5.20 d'ici aujourd'hui et demain donc on peut dire que la version téléchargée avant hier n'etait pas la bonne. |
Ne parlons pas trop vite
![]() Quote:
Ne sachant pas installer un plugin winamp, bref. Mais là, si c'est déjà intégré à une version de base de Winamp qui est quand même un lecteur mp3 de grande renommée, et que les petits utilisateurs s'amusent à sharer de msn en msn, Apple va râler dix fois plus fort que d'habitude ^^ Ce n'est que mon avis.
en même temps les utilisateurs peu avancées utilisent Windows Media Player et le cas échéant Itunes si ils ont un Ipod
:rolleyes: ![]() |
Vous etes bon pour la retélécharger via le site officiel de winamp.com ou via le lien suivant (version datant du 23/02/06):
http://download.nullsoft.com/winamp/...amp52_full.exe |
Si c'est le même Walkman qu'on a offert à Yannick Noah, je pars vite en courrant
![]() Mais euh c'que j'veux dire par utilisateurs peu avancés, j'en tiens exemple de mon frère qui utilise winamp (parce qu'on lui a dit que c'était trop super waouh et j'imagine que selon lui, en utilisant winamp il va améliorer la qualité sonore de nos enceintes hein !), et que bref, il a un iPod et est obligé de passer également par iTunes. Maintenant que Winamp adopte la compatibilité (sans utilisation de plugin), il va être tout joyeux =)... ... s'il le remarque...
Le patch de francisation pour la version 5.20 est sorti cette nuit après un gros travail de traduction de la médiathèque.
Merci veekee et les autres ![]() A télécharger d'urgence : ICI |
Salut
![]() Tiens c'est marrant je pensais que le développement de Winamp devait être arreté après la version 5.0, en comblant toutefois les failles de sécurité...la je vois plein de nouveautés ? |
Mais pour la peine, le logiciel est toujours appelé Nullsoft Winamp et non pas AOL Winamp (à moins que je me trompe ![]()
Moui le développement a bel et bien repris après quelques versions 5.0x pas bien folichonnes en nouveautés (compréhensible, ca doit faire plus de 10 lignes de code je pense et il faut un peu de temps pour rentrer dedans...).
Plus de génial Justin donc mais je trouve que la nouvelle équipe fait du très bon boulot, et comme d'hab, toutes les AOL-features sont désactivables. Winamp still rocks.
petit rappel des faits >1997 Nullsoft nait >1999 Nullsoft est racheté par AOL 100 millions de dollars en action (à l'époque c'etait bien >2002AOL décide de faire leur version..donc impose la 3..et se plante >2004 Làs, l'équipe originelle de Winamp voit trois gros membres se barrer (à 6 mois d'intervalle). Retour au noyau de la version 2 (avec le support des jolis skins >2005 AOL met en chantier "AMP comme AOL media Player" un truc lourd..abandonné en octobre et comme AOL n'a que ce lecteur et toute cette communauté....ils continuent je suis d'accord avec vous quand l'équipe de départ s'est barré je me suis demandé si c'etait pas la fin mais là la 5.1 est super, la 5.2 encore mieux. C'est aussi ça que j'aime chez ce lecteur cette constante envie de faire mieux et que tout soit désactivable si on veut (vous voyez ce que je veux dire ? nero 7 c'est trop lourd je voudrais revenir à Nero juste le truc qui grave..tout leger..ben non pas possible... Bref on va avoir des nouvelles surprises ...
Les gelflings sont zen...sauf quand on leurs prends le choux ![]() |
Winamp 5.04 | Toitoine | Actualité | 12 | 29-07-2004 09:32 |
WinAmp 5.0 Finale | streets | Actualité | 50 | 26-12-2003 22:40 |
Après la RC2 la RC8 de WinAMP 5 | Werner | Actualité | 8 | 21-11-2003 18:00 |
Winamp 5 beta 2 | streets | Actualité | 0 | 29-10-2003 00:42 |
WinAmp 2.90 Beta & WinAMP 3 Build 498 | Werner | Actualité | 16 | 03-04-2003 04:02 |
