Communauté Informatique NDFR.net : musikCube 0.92.1 - Page 2 - Actualité
musikCube 0.92.1
Old 10-04-2005, 15:24
whynot's Avatar
whynot whynot is offline
Originally Posted by Samva
whyn0t, je te conseille rythmbox que j'utilise en tant que lecteur de MP3 tout le temps sur ma Debian box
Ben heu oui mais là on me dit que " Rappelons, que pour compiler Rhythmbox, il vous faut avoir Gnome2 avec GTK+ 2.2"
Et veux pas de gnome moi. Oui je suis chiant mais je tiens à garder ma pitite lfs propre avec mon chtit fluxbox tout léger.
Et tant que j'y suis, j'ai trouvé aussi muine (gnome aussi), et beep media player qui m'a pas l'air top top...
Old 10-04-2005, 15:48
Effectivement il faut Gnome car Rhythmbox est basé sur certains éléments de Gnome (gstreamer en tête si je ne m'abuse), dans tous les cas si tu as l'occasion de l'installer sur une quelconque machine tu te rendras compte que musikCube en est très proche
Old 08-05-2005, 11:10
SantX's Avatar
SantX SantX is offline
I'm watching you...
Et une nouvelle mise à jour, une ..
MusikCube 0.92.3
playlist ordering is remembered
tunage vars $RATING and $GENRE added
reload tags no longer hangs
TagLib moved to core_Internal.dll and outside musikCore
added sources type "Collected" to show a history of songs played, including those that aren't in your main library. you can also use this sources item to modify songs that do not exist in the main library.
"Show All %" changed to "Show All Songs"
selection box "Show All %" bug(s) fixed
fixes typo "existant" should be "existent"
fixes the bug where dynamic playlists would switch around if they were selected and a new song was started.
fixes buggy searching while sources panel is scrolled
enabled marquee selection in playlist.
fixes a crash when upgrading from musikCube 0.91.x
double clicking fields in selection boxes now queues them in now playing if "Double Clicking a Song Queues it in Now Playing" is selected in the preferences.
currently playing songs are ALWAYS highlighted now.
fixes strange bug where two identical items in the now playing would be drawn with a slightly different font.
fix for sources plugin integration. OnSources() is only sent if user left click the sources item. also added WM_SOURCESUNSEL message so plugins can defocus items in the sources panel.
fixes a long running problem where new users couldn't add files to their database. this only occured when non ASCII letters were in the user's username.
fixes tray icon crash
removed balloon tip "pop" sound
Téléchargement : musikCube 0.92.3
Sources : Kool Lite Tools & site officiel.
- Albert Einstein -
Old 24-05-2005, 10:15
SantX's Avatar
I'm watching you...
MusikCube 0.92.4
right click -> play next, play now, enqueue, replace now playing, and replace now playing and play in both the playlist and selection box views.
fixes the bug where the tray icon would disappear if explorer crashed
fixes some bugs where the database would be queried twice instead of once.
fixes a nasty bug where deleting files from multiple libraries could work incorrectly.
fixes bug where rating a song in the playlist may not work correctly
fixes bug where incorrect tag properties could be displayed
fixes some random crashes people were experiencing with the option "double clicking an item queues it in now playing" option selected.
pressing F5 requires the selected dynamic playlist
dropping files on a device drives no longer crashes
times played is now incremented when the song starts, instead of when it ends.
clicking on the time elapsed in the playing area now toggles display between time elapsed and time remaining
code to put list of currently used genres from the database at the top of the genre pulldown in the tag properties dialog box
wrapped OpenURL in a try...catch block -- Tunage should no longer throw a message box if it fails due to lack of internet connection.
Téléchargement : musikCube 0.92.4
- Albert Einstein -
Old 07-06-2005, 17:12
SantX's Avatar
I'm watching you...
Comme j'adore apparement newser les quelques mises à jour pour moi-même, voilà :
MusikCube 0.92.5
fixed support for mapped network drives;
fixed filename case in the Tag Properties window;
fixed some "play next" crashes;
fixed the crash when moving playlists down (thanks DiGiTaLFX);
fixed some potential bugs with musikCore::Library creating crossfaders, equalizers, and playlists;
fixed bug where equalizer settings were not being saved on a per song basis when "Same Equalizer for all Songs" was not checked;
fixed bug where all selection boxes could disappear. if they are all closed, they will be reset to default upon next launch;
fixed a bug where plugging in a removable device when hidden would cause the sources panel to draw scrambled;
fixed the bug where hiding devices wouldn't take effect until musikCube was restarted;
fixed bug where press next or prev track would start playback if stopped;
fixed a bug where synchronization would fail if the collectes sources item was selected;
fixed filesize display in playlist: "MB" instead of "mb";
fixed equalizer drawing corruption when switching between 6 and 18 band mode;
pressing DELETE in the collected window actually deletes them from the collected library;
major overhaul of the now playing control;
fixed a lot of bugs relating to mcAmp, including those that made the sound suddenly cut out;
UPDATE : volume in the main UI now updates when the mini player updates volume;
added Fine Fine's random icon;
core_APE added to the musikCore CVS tree;
cube_mcAmp added to the musikCube CVS tree;
cube_miniPlayer added to the musikCube CVS tree.
Téléchargement : musikCube 0.92.5
Sources : Fileforum & site officiel.
- Albert Einstein -
Old 07-06-2005, 18:13
Faux, je l'ai mis à jour chez moi avant que tu ne la newse
Old 07-06-2005, 19:04
SantX's Avatar
I'm watching you...
Huhuhu, une réponse après les mises à jour , je commençais à croire que plus perssonne ne lisait le topic ...
- Albert Einstein -
