Auto Gordian Knot 1.53 beta Update
Lien direct de la news : Auto Gordian Knot 1.53 beta Update
Le célèbre logiciel d'encodage Auto Gordian Knot, vient de sortir en version 1.53 beta Update. Ce logiciel vous permettra d'encoder facilement et gratuitement vos DVD au format DivX ou XviD.
hidden options are displayed in the log files that are being processed are displayed in the log file mode can work with 24fps sources added hidden file ".audio_id" to override audio stream in file mode (see hidden_option.txt) TS sources are handled more properly when opening in AutoGKTélécharger Auto Gordian Knot 1.53 beta Update (1.51Mo, gratuit) Source : Free-Codecs.com
Et encore une beta, je me suis dit (et aussi grâce à Toitoine^^) que cela ne servai à rien de la newsé.
Bah voici les changement de la version, AutoGK 1.54 beta log file is cleaned up and most of VDubMod scripts logged there can only be viewed when enabled via ".debug" hidden file audio stream comments removed in file mode muxing options of AC3 audio tracks for ESS-based standalones players changed slightly tuned resizing parameters for highly compressible sources added PID detection for TS which do not have PAT/PMT via bbSummary (I modified bbInfo 1.9) some bugs fixed in handling of second audio in file mode 60fps progressive sources are now either kelp at original frame rate or restored to 24fps if 3:2:3:2 dupe pattern found added one more optional line to ".autocrop" hidden file to specify starting frame for autocrop operation (useful if beginning logo or into has different AR) bundled with Avisynth 2.5.5 (works ONLY with it) bundled with XviD 1.0.2 Télécharger AutoGK 1.54 beta (3.29Mo, gratuit) Source : Free-Codecs.com |
enfin une version stable
:changelog - added hidden file option ".adjustsubs" that resize _bottom_ subs so that they are not squashed and in place properly (option works only for burnt-in subs) - added support for launching AutoGK Assistant (the same way as Hidden Options Tool via CTRL-F9) - info window contains all shortcuts used in AutoGK - added missing FDecimate.dll and new KernelDeInt to the installer - fixed bug when "all" subs were selected but only first ones were processed (for external subs) http://len0x.btothec.com/web3/index....download&cid=1
Déterrage, parce que AutoGK est arrivé à maturité, et un nouveau post n'est à mon avis pas nécessaire.
On en est maintenant à la 1.92beta, et la dernière version stable est la 1.60. Mais le plus important c'est que depuis (à peu près) la version 1.85, AutoGK contient un spyware. Il s'agit de DAE, un "BrowserHelperObject" pour IE qui comme tant d'autres récolte des infos et les balance chez maman alias ReponseTarget. Pour les non-utilisateurs d'IE, aucun problème, et pour les autres, vous pouvez toujours utiliser ce petit programme, testé et approuvé, qui va virer DAE entièrement de votre système (ou utiliser un anti-spyware). Si vous n'en voulez vraiment pas, vous pouvez toujours rester à la version 1.60 qui marche trrrrrrrès bien. Thread à propos du spy sur doom9. Site officiel. Source : forum@doom9.org.
encore une beta : AutoGK (Auto Gordian Knot) 2.00 beta
Télécharger AutoGK (Auto Gordian Knot) 2.00 beta Source : FileForum
L'aventure prend fin
| Auto Gordian Knot 1.42 beta | SantX | Actualité | 0 | 25-06-2004 20:22 |
| Auto Gordian Knot 1.41 Beta Update | Toitoine | Actualité | 0 | 15-06-2004 14:12 |
| Auto Gordian Knot 1.35 Beta Update | Toitoine | Actualité | 2 | 08-06-2004 13:17 |
| AutoGK (Auto Gordian Knot) 1.21 Beta | Toitoine | Actualité | 6 | 15-05-2004 00:22 |
| Béta test d'Office 11 | ZK' | Actualité | 8 | 26-10-2002 14:47 |
Source :
