Communauté Informatique NDFR.net : Sortie de Winamp 5.02 ! - Actualité
Old 06-02-2004, 21:06
streets's Avatar
streets streets is offline
KiLL BiLL
Excellent Sortie de Winamp 5.02 !
Lien direct de la news : Sortie de Winamp 5.02 !
Voilà comme promis Winampfr.com V2 nous annonce la toute dernière version de Winamp. Après la 5.01 la 5.02 et pas de mise a jour du patch fr en vue pour le moment.
Voici les nouveautés (Attention c’est long et c’est en anglais ) :
  • added a couple of gen_ml APIs
  • fixed gen_ml radio/tv cache clearing after viewing prefs bug
  • made gen_ml radio/tv keep old data when updating fails, made it not update when no
    internet is available
  • made gen_ml support some new quicksearch syntaxes: "* beck radiohead"
    will list all things matching beck OR radiohead, and:
    radiohead " [3 days ago]>" will show all things matching radiohead
    played in the last 3 days...
  • gen_ml option for any/all guess modes
  • made SPS support 24 bit samples
  • added priority setting for CD ripping
  • made CD ripping only support one rip at at time
  • added send to -> add to library for playlist (and other) send to menus.
  • better media library audio view support for no artist/no album
  • fixed enter after info box and popup menus in library
  • moved litestep options to be in classic skin prefs
  • fixed playlist editor classic redraw bug, made playlist handle mousewheel scrolling while
    moving items better.
  • made "EXE" filetype extension non registerable
  • cleaned up "disable screensaver when video is playing" option
  • latest SDKs available (AVS, Media library, new Winamp IPC calls, etc...)
  • upgraded to Gracenote CDDB v2 DLLs
  • improvements in gen_hotkeys
  • upgraded MP3 encoding to LAME v3.95.1
  • out_ds now uses winamp.ini instead of registry for settings
  • new fix for upside down videos in in_dshow
  • added OGM as supported extension in in_dshow
  • modern skins updates :
  • optimized region a bit
  • fixed handling of global alpha for unparented layouts
  • fixed tiny bug in keypress flow
  • fixed potential layer capture cancellation issue
  • fixed crash when quickly alternating alt+g and alt+w
  • fixed player not coming up to front when playing a video via external URL click
  • fixed assertion when arial.ttf (or whatever fallback font has been set) is not present in the font directory
  • fixed faulty skin font unmapping sometimes conflicting with fallback to os default gui font
  • added date and version functions to maki
  • added added timerhours="1" to text object to show 1:00:00 instead of 60:00
  • added timeroffstyle 3 and 4 to text object to display "0:00:00" and " : : "
  • upped skin version to 1.1 - you MUST use 1.1 if you recompile your scripts
  • updated maki compiler (http://bluemars.org/maki) :
  • added stack protection to maki binaries - upped the binaries version header
  • added self version check in maki binaries
  • non-existing (future) maki functions will not crash the maki runtime anymore, YAY
  • fixed unknown maki functions return values
  • fixed winamp appearing on secondary taskbar with ultramon regardless of true position
  • fixed extraneous invalidations
  • new extended jump file dialog (thanks to Darren Owen)
  • added basic MP4 AAC encoding/decoding (thanks to Menno Bakker for the help)
  • fixed unicode metadata in in_vorbis
  • fixed crash in installer code
  • removed generation of "badframes.stt" files in VP6 decoder
Télécharger Winamp 5.02 Free Lite
Télécharger Winamp 5.02 Free Full
Old 06-02-2004, 21:24
Re: Sortie de Winamp 5.02 !
Allez c'est parti mon kiki
On va aller tester cette nouvelle version!
Old 06-02-2004, 22:41
Junta_'s Avatar
Junta_ Junta_ is offline
petit d'homme
hum miam miam winamp
c parti pour le dl
merci streets.
Seichi Kirima
Old 07-02-2004, 10:25
Toitoine's Avatar
Toitoine Toitoine is offline
Samouraï...pas le dernier
Merci Streets !
On va tester ...
A+
Sotie de Winamp 5.05 SuB-Zer0 Actualité 0 28-08-2004 10:16
Winamp 5.04 Toitoine Actualité 12 29-07-2004 10:32
Après la RC2 la RC8 de WinAMP 5 Werner Actualité 8 21-11-2003 19:00
Winamp 5 beta 2 streets Actualité 0 29-10-2003 01:42
WinAmp 2.90 Beta & WinAMP 3 Build 498 Werner Actualité 16 03-04-2003 05:02
