Communauté Informatique NDFR.net : La version 0.28b (v. Beta) d’eMule est disponible… - Vos news
Old 12-05-2003, 17:51
Cette version beta du très célèbre logiciel de P2P présente une liste impressionnante d'améliorations intéressantes :
  • Categories: extented choice of the function of the old "all" tab, switchable to Video,Audio,Transferring,Erroneous,...
  • Upload-, Queue- and Knownclientlists are titled with the number of the listed clients
  • different trayicon when serverconnection with a lowID (emule with blindfold, from emule+)
  • Webinterface: category support
  • Webinterface: displays completed transfers
  • Fixed mem leak when downloading server.met via HTTP[UVman]
  • Fixed another bug where an unwanted client could become a friend.
  • Fixed minor glitch with icons in tab controls on server and message window.
  • Added standard shortcuts to log and debug listview controls (Copy=Ctrl+C, Select All=Ctrl+A)
  • Websearch Filedonkey.com now supports filter by filesize-limits
  • Rewrote entire packet processing code to use exception handling and proper memory cleanup.
  • Rewrote most of the meta tag processing code to support new meta tags.
  • Fixed downloading of stopped or paused files.
  • Added passive source finding for files in download queue which were just started and not already in shared file list.
  • Fixed minor mem leaks and improper usage of delete operator [NoamSon]
  • Webinterface blocks IPs after 5 failed login attempts for 15 minutes
  • Filenamecleaning: customizable substringfilter (.ini : FilenameCleanups= )
  • option to auto-clean filenames on downloadstarts
  • If the connected server has a filelimit, announce not more files than accepted
  • Fixed bug with empty shared directories and OP_ASKSHAREDFILESDIR.
  • First Run Time wizard finally gets a "Finish" button.
  • Links in Chat (hypertextctrl) dont break on special chars anymore
  • better URL decoding (e.g. for special chars in ed2k links)
  • Fixed bug with OP_ASKSHAREDIRS where a client could ask for shared directories while there is a currently a shared files list received. Note: The viewing of shared directories of remote eMules was reset to 0.28+ because of a bug in 0.27.
  • Fixed major memory leak with compressed packets (thx Blackstar2)
  • Fixed bug with new meta tags of type "float" which were sent by servers which are offering shared files from Hybrid's 0.48+
  • Scheduler Fixes
  • Schedules can be activated directly via hotmenu (Ctrl-X) , (de)activating of the scheduler as well
  • identical shared folders are not sent multiple times anymore (under circumstances)
  • added: accurate speed measurement also on busy CPU [based on Ottavio84+Badwolf]
  • small GUI-fixes
  • Fixed resizing bug in log list controls
  • Fixed potential winsock termination bug
  • added option in extened prefs to disable source exchange messages in verbose log
  • added scheduler controls to hotmenu
  • cleared control of expand/collapse by key
  • Scheduler: fixed saving settings
  • fixed resumesame-cat & dontRecreateStatGraph - settings
  • fixed changing category-title when downloadinfos on tabs is activated
  • Fixed bug in preferences/directory control which was deleting the system's icon image list.
  • Fixed bug with non existing shared directories which could not be unshared in preferences/directories.
  • Double click in shared files list opens file with associated application.
  • When opening a file from download list or shared files list, the open command used is the same as when double clicking in Windows Explorer.
  • Fixed bug with log messages not shown at startup.
  • Added filetype icons to search- and shared files listviews.
  • Fixed bug with wrong nr. of search results shown in search tabcontrol when viewing files of different directories from remote client.
Téléchargez eMule 0.28b (exe)
Source: Generation NT
Old 12-05-2003, 19:13
liste impressionnate, euh pas plus que d'habitude ...
Old 12-05-2003, 20:02
chalouf's Avatar
chalouf chalouf is offline
fatigué
on verra ce que sa donnes
Old 12-05-2003, 20:13
ChatNoir's Avatar
ChatNoir ChatNoir is offline
Loozer résigné
D'autant que la version de la mule qui va pouvoir se connecter à Overnet est deja bien avancée. La 0.29 devrait être bien sympa.
Old 12-05-2003, 23:00
tiens pkoi c pas passé dans les news ? peyt-être trop longue
sinon, si g bien compris, la principale nouveauté vient du fait qu'il est censé être compatible avec overnet ?
Old 12-05-2003, 23:28
Provient du message de LeMoi
tiens pkoi c pas passé dans les news ? peyt-être trop longue ...
L’excès est toujours l’ennemi du bien…
Old 13-05-2003, 08:37
chalouf's Avatar
fatigué
Provient du message de rog62
Parceque elle est a chier...., non je rigole.
Old 13-05-2003, 21:02
ChatNoir's Avatar
Loozer résigné
Et bien non La compatibilité avec Overnet est prevu pour une version future mais le devellopement de cette partie du code avance bien
Old 13-05-2003, 23:07
en fait ils avaient publié le code source d'une pre-release d'emule hybrid (réseau edonkey+overnet), il y a même eu un mod mfck basé dessus mais il a vite été retiré car apparamment emule hybrid tel qu'il existait était néfaste pour le réseau et les serveurs, espérons qu'ils arrivent à résoudre le problème pour la 0.29
Old 13-05-2003, 23:10
ChatNoir's Avatar
Loozer résigné
Je pense que ça devrait etre bon, vu tout le boulot qu'ils font
Lancement de la version Bêta publique de MSN Messenger 7 rog62 Actualité 4 27-12-2004 16:48
La version 0.28a (v. alpha) d’eMule est disponible… rog62 Actualité 16 19-04-2003 09:25
K-lite en version 2.0.1 chalouf Vos news 4 25-03-2003 22:48
Version Beta claude922 Logiciels 4 23-01-2003 08:46
Béta test d'Office 11 ZK' Actualité 8 26-10-2002 14:47
