Communauté Informatique NDFR.net : Pc qui se fige , reset obligatoire - Windows Vista
Old 16-04-2008, 12:54
juninho juninho is offline
Question Pc qui se fige , reset obligatoire
J'ai remarquer que lorsque je regarde une vidéo avec VLC ou WMP, mon Pc sous Vista Ultimate se fige.
A part faire un "reset" pour tout restaurer... .
Mon OS est à jours pourtant... .
J'ai une Geforce 8400GS
Voici ma config:
CPU-Z 1.41 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name AMD Athlon 64 X2 6000+
Code Name Windsor
Specification AMD Athlon™ 64 X2 Dual Core Processor 6000+
Package Socket AM2 (940)
Family/Model/Stepping F.3.3
Extended Family/Model F.43
Brand ID 4
Core Stepping JH-F3
Technology 90 nm
Core Speed 2992.8 MHz
Multiplier x Bus speed 15.0 x 199.5 MHz
HT Link speed 997.6 MHz
Stock frequency 3000 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache (per processor) 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache (per processor) 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache (per processor) 2 x 1024 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge ATI RS690/RS690M rev. 00
Southbridge ATI SB600 rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Memory Frequency 332.5 MHz (CPU/9)
CAS# Latency (tCL) 5.0 clocks
RAS# to CAS# (tRCD) 6 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Bank Cycle Time (tRC) 19 clocks
Command Rate (CR) 2T
System
System Manufacturer MICRO-STAR INTERANTIONAL CO.,LTD
System Name MS-7327
System S/N To Be Filled By O.E.M.
Mainboard Vendor MICRO-STAR INTERANTIONAL CO.,LTD
Mainboard Model MS-7327
BIOS Vendor American Megatrends Inc.
BIOS Version V1.4
BIOS Date 05/28/2007
Memory SPD
Module 1 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Corsair
Module 2 DDR2, PC2-5300 (333 MHz), 1024 MBytes, Corsair
Software
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
DirectX Version 10.0
ce sont surtout de grosse vidéo en mpeg, .avi. ( > 600Mo)
Ce souci arrive uniquement sous Vista et pas sur Xp ( je suis en dual boot).
Mes pilotes sont à jours.
Le souci arrive autant avec VLC qu'avec Windows média Player... .
Ps: OS Officiel... .
Merci
Old 17-04-2008, 16:18
Tilt56 Tilt56 is offline
gestion différente entre Vista et XP, pistes possibles : économie d'énergie qui se déclenche, surchauffe processeur, pilote de la carte graphique ...
L'installation du SP1 pourrait peut être résoudre le problème.
geforce 8400gs, vidéo, vlc, wmp
Windows XP se fige... (Quand je lis un divx) Oberion Logiciels 1 03-08-2006 00:41
Le SP2 pas obligatoire. H@kk@s Vos news 19 03-03-2005 18:09
Le SP2 obligatoire dès le 12 avril Benjy Actualité 54 26-02-2005 19:42
Clavier figé lors du démarrage de l'installation OS DreamOn Matériel 2 10-03-2004 13:25
