Winamp 5.22
#16
Retrouver le patch fr de winamp 5.23 (build 672) sur le lien
http://winampfr.com/?newzyland=478
#17
Winamp 5.24 avec son changelog astronomiquement.... court.
Changelog Télécharger Winamp 5.24 Full Fixed: [in_midi] crash bug & potential security vulnerability Télécharger Winamp 5.24 Lite
#18
EDIT : 23/06/2006 à 06h10 Quote:
Petite modification ....... Téléchargement : ici Last edited by mustang89; 23-06-2006 at 06:11. |
#19
Winamp 5.25
* New: Unicode filename and title support * New: M3U8 (Unicode) playlist support * New: [ml_pmp] Playback now works for playsForSure and Creative NJB devices * New: [ml_pmp] "Copy to Library" - transfer songs from any device to your local library (uses CD rip settings) * New: [pmp_usb] USB Drive/Portable device support * Improved: [in_mp3] streaming id3v2 support * Improved: 24bit EQ support * Improved: [in_mp3] 24bit MP3 playback, 64bit internal precision * Improved: [in_mp3/in_mp4] 24bit AAC playback * Improved: fullscreen video seekbar * Improved: [ml_pmp] Only relevant columns shown in song views * Improved: [ml_pmp] "Getting Metadata" now much faster * Improved: ATF updates * Improved: DC filter on spectral visualization, to remove bass bias * Fixed: Burning files that require resampling * Fixed: multiple copies of Winamp when opening too many files/folders from explorer * Fixed: freeze when exiting via System Tray icon * Fixed: Delay/hang when loading dead stream url's * Fixed: [enc_lame] broken vbr presets * Fixed: [gen_ff] layerfx not being redrawn on colortheme change * Fixed: [gen_ff] gradient drawing glitch and crash * Fixed: [gen_ff] custom color themes bug * Fixed: [gen_jumpex] hang when suspending or hibernating * Fixed: [in_cdda] cutoff of last few sectors * Fixed: [in_midi] truncated playback of some MIDI files * Fixed: [in_mod] title display bug for module streams with no title * Fixed: [in_mp3] crash when editing ID3 tags * Fixed: [in_mp3] ID3v2 and ID3v1 Comment & Genre tags shared * Fixed: [in_mp3] Inaccurate Time Remaining display for AAC files * Fixed: [in_wm] DRM Video playback on certain hardware * Fixed: [in_wm] freezeup when seeking a paused wma * Fixed: [in_wm] Hang with dead WMV link in pledit in Repeat mode * Fixed: [ml_disc] CD ripping / playlist generation bug * Fixed: [ml_playlists] losing stream titles * Fixed: [ml_playlists] sort by title * Fixed: [ml_playlists] Send To from local media to ml playlist replaces instead of enqueues * Fixed: [ml_playlists] Enqueue as default broken in left pane * Fixed: [ml_playlists] Playlist title > rt-click > New Playlist = broken * Fixed: [ml_playlists] tracklength bug * Fixed: [ml_playlists] playlist paths issue * Fixed: [ml_pmp] Transfers stalling after encountering a dupe * Fixed: [out_ds] volume not hitting 0dB when using log or hybrid volume control * Fixed: [pmp_ipod] Artist list on iPod not sorting "The" correctly * Updated: [gen_jumpex] Jump-to-File 0.97.5 * Updated: [gen_ff] Freetype 2.2.1 * Updated: [libmp4v2] MPEG4IP mp4v2 1.5
#20
Oui et ? Finale ? bêta ? RC ?
Le changelog que tu viens de mettre est celle de Winamp 5.25 bêta 787. Faudra un peu plus de précisions (et les liens de téléchargements)
#21
Hop la bêta build 801 de Winamp 5.25 vient de sortir avec ce changelog
Changelog Télécharger Winamp 5.25 Bêta build 801 Full Fixes the following 5.25 specific bugs: - bad Layer 1 & Layer 2 playback (double speed + distorted) - slow enqueue/play from media library views - hiliting of playlist entries for jump-to-file broken - open playlist from media library broken (in playlist editor) - saving playlists to PLS format Télécharger Winamp 5.25 Bêta build 801 Lite
#22
Winamp 5.25 Bêta build 812
Changelog Télécharger Winamp 5.25 Bêta build 812 Full changelog between build 801 and build 812 warning when selecting 24bit output fixed: [ml_disc] Play tracks after CD Ripping fix fixed: [ml_local] bg scan crash when media library DB isn't loaded fixed: [ml_history] Ctrl+H shortcut fixed: registry keys created even on unregistered file types fixed: systray tooltip not showing fixed: crash on uninstallation fixed: [in_wm] freeze when stopping streams that have rebuffered fixed: freeze when exiting Winamp while minimized fixed: burning with 24bit enabled fixed: [in_dshow] AVI >2GB fix fixed: [playlist] PLS loading fix Télécharger Winamp 5.25 Bêta build 812 Lite
#23
Winamp 5.25 Bêta build 825
Changelog between build 812 and build 825 Télécharger Winamp 5.25 Bêta build 825 Full Fixed: playlist extension registry writing Fixed: remote playlists nested within a playlist Fixed: dialog fixes (font change had knocked some things out of whack) Fixed: xp themed dialogs Fixed: rogue winamp agent registry Run key Fixed: [dsp_sps] 24 bit fix Fixed: [in_dshow] seek to key frame Fixed: [in_mp3] do Viz after DSP Fixed: [in_mp3] made genre dropdown bigger again (only effects pre-XP os's) Fixed: [gen_jumpex] Crash when clicking 'switch to vis/video' button Fixed: [gen_ml] tree icon fixup (working around an OS bug that was causing CreateDIBSection to sometimes crash (divide-by-zero in ICM32) using V4 bitmap header struct) Fixed: [ml_local] fix for setting the watch folders extension list Fixed: [ml_local] fixed crash when trying to create a new view before mldb has loaded Improved: expanded 24bit warning Updated: [gen_jumpex] jtfe 0.97.7h (build 57) Télécharger Winamp 5.25 Bêta build 825 Lite
#24
Winamp 5.25 beta build 843
Changelog Winamp 5.25 Bêta Build 843 Full build 834 -> build 843 * Fixed: unicode titles for streams (build 834-specific bug) * Fixed: [in_mp3] icecast utf-8 stream title support * Fixed: [in_mp3] lame vbr header reading (build 834-specific bug) * Fixed: [ml_local] crash when deleting files (via watcher) before ml has loaded * Improved: bumped up gain of spectral analyzer * Improved: [in_mp4] better sample duration calculation when the decoder is outputting at a different samplerate than specified in the MP4 data * Improved: [pmp_usb] metadata reading in background, general touch-ups * Improved: [in_mp3] faster preparation during burning, transcoder support * New: [in_mp3] replaygain support for MP3 playback (enable in Prefs > Playback) * New: [ml_rg] replaygain scanner (beta only, for now - access via Send To menu) * Updated: [enc_lame] LAME 3.97b3 Build 825 -> 834 : * Fixed: [in_mp4] detection of HE AAC in file info box (Alt+3) * Fixed: [enc_aacplus] more compatible HE AAC MP4 file creation * New: "Close Winamp" option after installation (after clicking 'Send') Winamp 5.25 Bêta Build 843 Lite
#25
Winamp 5.25 build 857 Bêta (toujours)
changelog Télécharger Winamp 5.25 Bêta build 857 Full * Fixed: crash when aacPlusDecoder.w5s isn't present * Fixed: Sonic Engine install under Win98SE/ME * Fixed: ReplayGain preamp resets to -6.0 dB (b843-specific) * Fixed: ReplayGain info not being saved for files with id3v1 tags only (b843-specific) * Fixed: [in_mp3] %bitrate% & time display in pledit for mp3 streams (5.25-specific) * Fixed: [in_wm] freeze on seek with right keyboard cursor (5.25-specific) * Fixed: [ml_disc] auto add ripped files to mldb (5.25-specific) * Fixed: [ml_rg] crash on unsupported formats (b843-specific) * Fixed: [ml_rg] Abort button now working (b843-specific) * Improved: fixes for video plugin detection * Improved: [in_mp3] minor id3v2.4 tag reading fixes * Improved: [in_mod] 24bit/surround/stereo options moved to Prefs > Playback * Improved: [in_mp3] increased streaming info box size * New: aac/m4a/ogg replaygain support * New: [in_mp3] aac/mp3 replaygain in alt+3 dialog box * New: [ml_pmp] auto-transcoding for incompatible formats * New: [ml_playlists] added 'playlist entry' and 'read extended info' to menus * Updated: Sonic Burning/Ripping Library (requires reboot) Télécharger Winamp 5.25 Bêta build 857 Lite
(pas à pas) n'importe quelle radio/TV sur winamp | gelflings | Logiciels | 0 | 21-05-2006 17:17 |
WinAmp 5.0 Finale | streets | Actualité | 50 | 26-12-2003 22:40 |
Après la RC2 la RC8 de WinAMP 5 | Werner | Actualité | 8 | 21-11-2003 18:00 |
Winamp 5 beta 2 | streets | Actualité | 0 | 29-10-2003 00:42 |
WinAmp 2.90 Beta & WinAMP 3 Build 498 | Werner | Actualité | 16 | 03-04-2003 04:02 |
