Communauté Informatique NDFR.net : WinRAR 3.60 Bêta - Vos news
Répondre
WinRAR 3.60 Bêta
Ancien 1 April 2006, 02h18
Avatar de 1for-matik
1for-matik 1for-matik est hors ligne
Lieu: Au Pays de la choucroute
Envoyer un message par ICQ à 1for-matik Envoyer un message par AIM à 1for-matik Envoyer un message par Yahoo à 1for-matik Envoyer un message via Skype™ à 1for-matik
WinRAR 3.60 Bêta
Hop, nouvelle version, nouveau topic.
Aujourd'hui (ou on va plutôt dire hier) est sorti la 1ère version beta de WinRAR 3.60.
Pour rappel, gnagnagnagnagna... l'un des meilleurs logiciel de compression... bref
Changelog
Version 3.60 beta 1
1. Multithreaded version of RAR compression algorithm improves
the compression speed on computers with several CPU,
dual core CPU and processors with hyperthreading technology.
Multithreading is enabled by default, but you can disable it
in "General" part of "Settings" dialog.
In the command line mode you can control multithreading with
-mt switch.
2. WinRAR can display the folder tree panel allowing to navigate
in disk and archive folders. Use "Options/Folder tree" submenu
to enable the folder tree. It can be configured separately
in file and archive management modes.
Folder tree replaces "Browse for folder" command previously
available in "File" menu and uses its Ctrl+T keyboard shortcut.
3. Now WinRAR "Rename" command also works with ZIP archives.
Previous versions could rename files only in RAR archives.
4. Added decompression of LZH archives created with "-lh7-" algorithm.
5. New "Remove duplicate folders from extraction path" option
in "Settings/Compression" dialog.
If this option is on and you unpack an archive which root folder
has no files and only one 'somename' folder and if destination
folder is new or empty and also ends with '/somename', WinRAR
will exclude one 'somename' from resulting 'somename/somename' path.
6. New "Define volume sizes..." button in "Settings/Compression".
This button activates "Define volume sizes" dialog. Here you
can customize the list of predefined volume sizes associated
with "Split to volumes, bytes" field in archiving dialog.
7. Speed of RAR general compression increased for some data types.
Depending on data type and size the gain may achieve 5 - 15%.
8. New "Rename automatically" option in the extraction dialog
and command line -or switch to rename extracted files automatically
if file with the same name already exists. You can also enable
the auto-renaming mode directly from the overwrite confirmation
prompt with "Rename All" button.
Renamed files will get names like 'filename(N).txt',
where 'filename.txt' is the original file name and 'N' is a number.
9. "Set modification time" option in "Advanced" part of extraction
dialog is accessible also for ZIP archives. Previously it could be
changed only for RAR archives.
10. "Multithreading" option added to "Benchmark and hardware test"
command, so you can compare performance of usual and multithreaded
versions of RAR compression algorithm.
11. New 'ch' (change archive parameters) command line mode command.
Its purpose is to apply switches like -av, -tl and -cl to archive.
12. New 'cv' command line mode command. It provides the command line
interface to WinRAR "Convert archives" command. It is supported
only by winrar.exe, not by rar.exe.
13. New command line -sl and -sm switches to set size
limits of processing files.
14. New command line -fcu[file] switch allows to read archive
comments from Unicode files. It also modifies behavior
of "cw" command, setting the comment output format to Unicode.
15. 7Z added to list of formats stored without compression
when using -ms switch without a parameter.
16. Switch -e[+] is now supported by most of command line
operations including extracting and deleting files. Previously
it was supported by only archiving command.
17. It is allowed to use environment variables in archive name
in archiving dialog, in destination path in extraction dialog,
in folder names on "Compression" and "Paths" pages in WinRAR
settings. For example, you can enter '%temp%' in "Folder for
temporary files" field.
Que celui qui trouve que j'abuse de la fonction changelog me le dise
Télécharger WinRAR 3.60 Bêta 1 en anglais (même pas 1Mo.... 1007 Ko)
Source : Fileforum
N.B: Cette news n'a aucun besoin d'être publié dans la rubrique Actualités...
Réponse avec citation
Ancien 1 April 2006, 05h35
Avatar de mustang89
mustang89 mustang89 est hors ligne
Agé mais toujours jeune
Lieu: Yonne, Bourgogne, France
Citation:
Originellement posté par 1for-matik
Non, non t'abuses pas, mais t'aurais pu le traduire ce changelog
Ancien 1 April 2006, 18h55
Avatar de Benjy
Benjy Benjy est hors ligne
Lieu: Rueil Malmaison (92)
Envoyer un message par MSN à Benjy
Citation:
Mais pourquoooooiiii ? :rolleyes:
Ancien 1 April 2006, 19h27
Avatar de LeMoi
LeMoi LeMoi est hors ligne
Lieu: 37°1
Envoyer un message par ICQ à LeMoi Envoyer un message par AIM à LeMoi Envoyer un message par MSN à LeMoi Envoyer un message par Yahoo à LeMoi Envoyer un message via Skype™ à LeMoi
Idem :confused:
Ancien 1 April 2006, 19h33
Citation:
Originellement posté par Benjy
PARCEEEEEE QUEEEEEEEEEEEEEEEEE
Ca sert à rien... à moins que tu veuille quand même publier une news sur un logiciel en bêta
Ancien 4 April 2006, 18h50
Avatar de Fred
Fred Fred est hors ligne
00 Agent
Lieu: MI6 HQ
Envoyer un message par MSN à Fred
Le multithread dans WinRAR ça peut être bien sympa
Vous en voyez beaucoup des logiciels de compression multithreadés ? Pourtant le processus s'y prête vraiment bien ...
... non Gaston
Ancien 5 April 2006, 00h01
Avatar de Matt
Matt Matt est hors ligne
Mitrailleuse anti-boulets
Lieu: Grenoble
Citation:
Originellement posté par Fred
7zip
Citation:
Bof ... Les algos de compression sont malheureusement relativement difficiles à paralléliser, parce qu'il y a pas mal de problèmes de synchronisation de données et car le codage est fortement dépendant de ce qui a été codé avant (c'est particulièrement le cas pour l'archivage de fichiers, nettement moins pour la compression de vidéo, où on peut quasiment paralléliser à 100% grâce aux frames clés).
J'ai fait quelques essais avec 7zip (article à venir sur mon futur site Matt, le roi du Vaporeware), y a des petites pointes à 70% de charge CPU (donc +40% par rapport à du single thread), mais en poyenne, ça tourne plutôt entre 55 et 60%.
En fait, les softs de compression qui pourraient le plus bénéficier du multithreading sont ceux n'utilisant pas le concept d'archive solide (car alors le codage de chaque fichier est totalement indépendant de celui des autres, donc on peut paralléliser dès qu'il y a plusieurs fichiers), mais :
- les archives solides sont généralement mieux compressées (logique, plus de redondance)
- dans 7zip, je n'ai pas remarqué de différence de charge entre archive solide et archive non solide, donc ça n'a pas été prévu à l'implémentation, faudrait voir comment se comporte WinRar sur ce point.
Matt 7 - 2 Boulets
Pimp My iPhone : bidouilles, sélection d'applications, fonds d'écran, personnalisation...
Infobidouille.com : actualités informatiques et tests de matériel/logiciels
"S'il n'y a pas de solution, il n'y a pas de problème." (devise Shadok)
Ancien 5 April 2006, 00h09
Avatar de whynot
whynot whynot est hors ligne
Totoro
Lieu: Grenoble
Citation:
Originellement posté par Matt
Par défaut (donc pour la majorité des utilisateurs) WinRAR n'utilise pas d'archive solide lorsqu'il compresse. D'ailleurs je trouve les archives solides chiantes car pour voir ne serait-ce qu'on .txt minable dans une archive de 200megs, il faut tout extraire. Ca doit vraiment être utilisé à des fins particulières à mon avis.
Ancien 5 April 2006, 07h20
Avatar de Matt
Lieu: Grenoble
Citation:
Originellement posté par whynot
Certes. Mais reste à voir s'ils ont implémenté la compression de deux fichiers en parallèle ou pas.
Matt 7 - 2 Boulets
Ancien 5 April 2006, 19h10
Avatar de Fred
00 Agent
Lieu: MI6 HQ
Je pensais aux archives non solides, effectivement. Dans le cas des archives solides, l'index est toujours mis à jour, c'est plutôt lourd mais ça peut donner quelques algos intéressants puisqu'on doit toujours compresser un flux de données, l'ordre n'a que peu d'importance. Après, tout dépend de l'algo de compression et en particulier de la génération des dictionnaires ...
... non Gaston
Ancien 5 April 2006, 19h55
Avatar de Cougar
Cougar Cougar est hors ligne
Lieu: Orléans
Envoyer un message par MSN à Cougar
Bon j'ai fait quelques tests avec mon modeste PIV 3.08 Ghz HT mode de compression BEST (pas solid ni autre)
dossier de 170 567 ko de png :
winrar 3.5 : 2'39 163 413 ko
winrar 3.6 : 2'16 163 411 ko
dossier de 111 698 ko de ficher "texte"
winrar 3.5 : 2'12 65 662 ko
winrar 3.6 : 1'40 65 652 ko
le gain de temps est donc loin d'être négligeable et on note même un faible gain au niveau de la taille
je ferai le test sur un fichier unique, genre de 700mo.
Ancien 5 April 2006, 23h56
Avatar de Matt
Lieu: Grenoble
Citation:
Originellement posté par Cougar
Dis donc, il est pas à 2.8 officiellement ton P4 ?
Citation:
Tu devrais aussi faire un test en vérouillant WinRAR 3.6 sur un seul des core virtuels, pour voir si le gain de temps est vraiment entièrement du au multithreading, ou s'il est aussi dû à d'autres améliorations de l'algorithme.
EDIT : bon ben j'ai fait un essai rapide, et en activant l'option solide. La charge CPU tourne à 88-89% en moyenne, avec des pointes à 95%. Donc il y a vraiment eu un très bon travail d'optimisation, et pas simplement une mise en parallèle de la compression de deux fichiers.
Matt 7 - 2 Boulets
Ancien 6 April 2006, 00h04
Avatar de Cougar
Lieu: Orléans
2'16 exactement pour le deuxième dossier multithreading off, donc y a apparamment un réel gain
A noter que l'archive fait 65 659 ko, comprendra qui pourra !
Ancien 3 July 2006, 15h34
Avatar de LeMoi
Lieu: 37°1
Version 3.60 beta 6
1. Switch -ad did not work in GUI winrar.exe.
2. When repairing several archives, console RAR did not handle 'No' choice of overwrite archive request properly. It aborted the operation instead of skipping the current archive.
Télécharger WinRAR 3.60 Beta 6 (Anglais, évaluation)
Ancien 18 August 2006, 18h49
Avatar de LeMoi
Lieu: 37°1
WinRAR 3.60
-mt switch.
Page de téléchargement
Répondre
Signets
Outils du sujet
Modes d'affichage
Règles des messages
Le code BB est oui
Le code HTML est activé : non
Aller au forum
Sujets similaires
WinRAR 3.50 Beta 1 1for-matik Actualité 19 9 August 2005 18h23
WinRAR 3.40 Beta 2 Mytheuzen Vos news 4 7 July 2004 18h38
WinRAR 3.30 beta 5 Kaspof Actualité 3 10 January 2004 00h26
WinRAR 3.30 Beta 4 Werner Actualité 0 22 December 2003 14h43
Béta test d'Office 11 ZK' Actualité 8 26 October 2002 14h47
Toutes les heures sont au format GMT +2. Il est actuellement 07h33.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
