nLite v0.99.8 beta 5
#16
Il faut que tu ailles les télécharger, après tu les places dans un dossier et vas les récupérer avec nLite.
Pour le téléchargement des mises à jour, suffit de passer par le "centre de téléchargements" de Microsoft.fr. |
#17
#18
Bon, voilà je sais que cela va en ravir quelques-un :
nLite 1.0 beta 1 general Windows XP x64 Pro Support Patches page nLite Processing Priority option Program Files path Clean MUI Languages support entries XPize uAE integration support Turkish translation Win2k mxdr_ file report Win2k C-Index error pop RVMPack copy issue Win2k3 manual install Chinese lang issues in specific removal setup PressAnyKey prompt removal few services name entries (ipx mostly) Server Unattended options enabled for Win2k server (#0000001) : Tcpip patch (also now shows current value) (#000000 : win2k missing inf files on browse (#0000022) : refresh after slipstream (#0000026) : gsicon.exe integration (#000002 : driver install popup (for all windows) (#0000035) : Windows 2003 SBS winnt.sif components Tape drives driver Administrative templates Document Templates UPDATE : Ports (files and services removed, be careful) UPDATE : IPX (more files removed) UPDATE : Color Schemes (more entries removed) (#0000030) : Sysprep Compatibility (#0000002) : Desk Clean Reg leftover SUSPENDED : NetDDE (some problems, will be back) Téléchargement : nLite 1.0 beta 1. Source : site officiel et Fileforum.
#20
nLite 1.0 Bêta 2
Changelog Télécharger nLite 1.0 Bêta 2 v1.0 beta 2 general - new: Macedonian language - new: Corrupted CAB auto recovery - fix: net*inf file missing on browse in win2k - fix: Advanced Keep box - fix: UsbPort Patch (swapped settings 250/500) components - new: Active Directory Service - new: Ali IDE BUS Driver - new: AOL ART Image Format Support - new: Beep Driver - new: CMD IDE Bus Driver - new: Intel IDE BUS Driver - new: Modem Support - new: Network Provisioning Service - new: Toshiba IDE Bus Driver - new: VIA IDE Bus Driver - upgrade: Internet Explorer (Movie Maker was dependant) - upgrade: Accessibility - upgrade: Multi-port serial adapters - fix: Help (System Restore) - fix: Ethernet Drivers (Netgear brand kept) Source : nLiteOS
#21
Bon je vais me lancer avec cette nouvelle version, j'ai tout préparé le rép XPSP1, l'update SP2, les maj d'après le SP2, reste plus K
#22
Comme il l'est spécifié sur le site, cette nouvelle version tient plus du correctif et celà se ressent notament au niveau du changelog
nLite 1.0 bêta 3 general Azeri language Non-English expanding bogus CAB corruption warning Next-Back rarely disabled when shouldn't components UPGRADE : Application Compatibility (more reg entries removed) -- Téléchargment : nLite 1.0 Bêta 3 Sources : Site officiel et Kool Lite Tools.
#23
Bon bien rebelotte, il y a juste à lire le commentaire de nuhi, pour comprendre pourquoi en si peu de temps on se retrouve avec deux bêtas
nLite 1.0 bêta 4 Integrating hotfixes hangs suspended: DR Watson (under investigation) -- Téléchargment : nLite 1.0 Bêta 4 Sources : Site officiel et Kool Lite Tools.
#24
Allez, après une pause, nLite 1.0 Bêta 5
Changelog Même lien que ci-dessus
general - new: Direct Hotfix Integration (takes less space and supports more older versions of KB*.EXE with white icon) - new: Option Don't save copy of current preset in ISO - new: Windows 2000 Advanced Server support - fix: Better task separation (doesn't patch anything if you don't select components page, patches page and admin rename) - fix: UsbPort patch (should work for all now) - fix: Hotfix integration after nLightenment (when rerunning nlite after nlite to integrate hotfixes) - fix: RAID/SATA integration for some whome drive was undetected (let me know if yours is not ok, x64 still reboots for some, adding other method soon) - fix: Driver Signature popup for some - fix: Reduced SFC Popups if left enabled (if you get any let me know when, don't use sfcscannow) components - new: Disk and Profile Quota - new: File System Filter Manager - new: Private Character Editor - new: DirectX Diagnostic Tool - new: TAPI Application Support - update: Extra Fonts (Luna theme font excluded now) - update: NTBackup don't need Removable storage any more - fix: File & Settings Wizard was dependable on Manual Install - fix: Windows x64 many components failed to install on certain setting combination
#25
Après un peu plus d'un mois, voici une nouvelle version bêta de nLite.
Servez-vous... nLite v1.0 bêta 6 general - new: IE7 Beta 1 direct integration support (xp sp2) - new: DEP Unattended option - new: Sereby's German Hotfix Pack v1.3+ support - new: Greek and Russian (non-Cyrillic) language translation - fix: Textmode Driver (nvraid post install reboots) - fix: Direct integration for KB896344,KB890046,KB898461,KB893357 - fix: German pack integration (SetupHotfixesToRun included) - fix: Compress error popup with small files - fix: SFC Enabled full support - fix: Main files uppercased components - new: ActiveX for streaming video - new: Intel Indeo codecs - new: Teletext codec - new: IP Conferencing - upd: TAPI App Support (removes more) - upd: CTF Loader -> Text Services Framework (removes more) - upd: WMP (now keeps MP3 codec) - fix: DRWatson (back and fixed) - fix: Printer drivers in Win2k (seemed like not removed) Téléchargement : nLite v1.0 bêta 6 (1.22 Mo) Source Kool Lite Tools et site officiel.
#26
Tant qu'ils corrigent encore des bugs de ce calibre, j'ai vraiment pas envie de l'utiliser pour faire des CDs d'installation ... si c'est pour que ce soit plus galère qu'une install normale non merci !
Vivement la 1.0
#27
Et hop, la 1ère Release Candidate de nLite 1.0 vient de sortir
Changelog de nLite Télécharger nLite 1.0 RC1 v1.0 RC1 general - new: Hebrew and Serbian translations - new: Remove CAT files Hotfix Integration option - new: Turn Off Firewall Unattended option - update: Textmode driver doesn't need unattended - update: Processing Advanced Remove files even if no component selected - fix: Windows x64 support - fix: Driver Integration subdirectories - fix: RVM pack support (SXS error) - fix: Input string error (i.e. win2k rollup hotfix) - fix: Tweaks - fix: some remaining SFC popups components - new: Joystick Support - new: Logitech WingMan drivers - new: Microsoft SideWinder drivers - new: Network Setup Wizard - new: User Account Pictures - new: Logon Notifications - new: Remote Installation Services (RIS) - new: MSMail & MAPI - update: IPX Protocol (removes more) - update: 16bit support (removes more) - fix: Mobile phone driver kept (also keep Ports for Mobiles) Source: nLiteOS
Nlite 0.99.1 beta | Scorpio | Vos news | 22 | 06-03-2005 17:48 |
nLite 0.99 beta | Werner | Actualité | 9 | 09-10-2004 18:30 |
Office 2003 Beta 2 Technical Refresh | Werner | Actualité | 1 | 24-06-2003 15:34 |
Béta test d'Office 11 | ZK' | Actualité | 8 | 26-10-2002 14:47 |
CpuIdle Beta 6 9x/ME/NT/XP | ---DjNico--- | Actualité | 1 | 21-10-2002 12:20 |
