BSplayer 1.2 Build 815 et BSplayer Pro 1.2
Lien direct de la news : BSplayer 1.2 Build 815 et BSplayer Pro 1.2
Voici la toute dernière version du célèbre lecteur multimédia, BSPlayer.
BSPlayer est un lecteur multimédia universel permettant de lire la plupart des formats video/audio. Entre autres fonctions il permet des réglages video, audio, sur les sous-titres, de faire des captures, de gérer des signets, etc. Les changements de la version gratuite pan scan settings are now remembered fixed some problems with file association fixed bug in skin engine, some skins were not properly loaded fixed -nsub command line option, was working properly only for current file fixed some problems with subtitles, last line was still visible in some cases after subtitles were turned off some changes in subtitle loading, added more strict checking, so subtitle for another movie shouldn't be loaded anymore some other bug fixes and internal changes added more friendly interface to bspfilters.dat and improved filter management a lot, it's now possible to define black list (filters in black list won't loaded), white list (only filters in white list will be used), VSFilter and similar filters will now be loaded (optional), it's also possible to define which filter will be used for playing specified media type, you can also register, unregister filters and set merit from BSplayer added support for Audio CDs and CDDB added option to set default audio stream, by index and iso-6392 language code (language code only for mkv files) added option to define more subtitle paths, path can also be relative (ex. '..\subtitles') added option to set default subtitle, by index and iso-6392 language code (language code only for mkv files) added option to set default audio stream for every item in playlist Les changements supplémentaires de la version pro network buffer for mkv files was always enabled, fixed improved support for tuner devices, added channel list and channel scan, you can also set channel names, channel list is integrated in playlist Télécharger BSplayer 1.2 Build 815 ou BSplayer Pro 1.2 Site officiel : BSplayer Source : FileForum |
Bonne/Mauvaise nouvelle ?
Oulà, ça sent pas bon ça, le seul qui pouvait rivaliser avec MPC devient douteux, bon ben , c'est décidé, mon HDD sera MPC only...
tu aurais pu traduire LeMoi !!! pense à ceux qui ne savent pas lire l'anglais (moi ce n'est pas mon cas )
Puisque c'est pas ton cas et que tu te proposes si gentiment, nous attendons la traduction ...
en gros The Core Media Player vient d'acquérir BSplayer et BSplayer deviendra donc TCMP 5
et tout ceux qui ont acheté une licence devront en racheter une autre. Info ou intox ? |
De toutes façons la version payante de TCMP (du moins jusqu'a présent) n'avait comme avantage que la lecture des DVD.
Bon en attendant BSPlayer a quand même été mis à jour (de plus le topic semble avoir disparu sur leur forum???) :
Version 1.30 (build 818), Pro et free : partial support for Unicode file names some changes to be more compatible with new DivX 6 Media Format, no direct support for menus and other features yet added option to add all files in current directory to playlist, so when one file is opened all files will be added to playlist and you can quickly view next or previous with 'Next' and 'Previous' shortcuts files that are still recording or downloading will now be reopened at the end, so playback will continue some other bug fixes and changes Pro : added simple teletext viewer some bug fixes with TV tuner and capture http://www.bsplayer.org/index.php?p=download |
version 1.31 (b819) fixed bug in 'advanced graph building mode', player crashed if DivX 6 was installed and 'Support decoding of Generic MPEG-4 video' in DivX decoder was disabled version 1.32 (b820) ??? Même lien
Version 1.37 du 11/12/2005
support for utf8 encoding in external ssa subtitles VobSub subtitles can now be moved, like normal ones some VobSub subtitles were not displayed, fixed mp3 shoutcast fixes, some streams didn't work some fixes with tuner/capture, wrong name displayed after capture etc... Added 'always on top' option for control window fixed problem with desktop mode when icons were hidden pan scan was not remembered properly, fixed some other bug fixes
BSPlayer 1.01 build 811 | LeMoi | Actualité | 4 | 14-09-2004 23:37 |
BSPlayer 1.00 RC1 build 808 | LeMoi | Actualité | 8 | 29-04-2004 20:34 |
BSPlayer 1.00 RC1 build 803 | LeMoi | Actualité | 20 | 22-02-2004 22:17 |
BSPlayer 1.00 RC1 build 800 | LeMoi | Actualité | 11 | 12-11-2003 11:14 |
